Results 1 to 2 of 2
Thread: Teensy 4.0 compatible microSD connector?
    Aug 2019
    7
    Hi all. I posted this in project guidance but I think it actually fits better in this forum. I was wondering if y'all know of a compatible MicroSD solderable connector for the Teensy 4. I measured the pin pitch and I believe it's not quite the standard at around 0.95 - 1mm instead of 1.1mm. I actually purchased two different standard microSD connectors and neither of them seemed to fit the pitch properly, just to be sure. Is anyone aware of a connector that works here? Thanks!
    9,923
    See original post: Compatible-SD-card-connector-for-Teensy-4-0
    Closing this to avoid duplication
