Results 1 to 2 of 2
Thread: can you share the i2c interface with the audio library?
    Can I use the "wire0" i2c pins with another i2c device (IE: Si5351 clock gen) while using the audio library with the Teensy Audio board?
    3,368
    Quote Originally Posted by scharkalvin View Post
    You should be able to as long as you don't use a device with either 0x0A (SGTL5000) or 0x1A (WM8731) addresses, since those are on the audio board. The audio board has pull-up resistors on it, so you don't have to add pull-up resistors on the Teensy. I imagine there might be a few problematic devices, but it should work.
