Results 1 to 20 of 20
Thread: Teensy 4.0 USB serial lockup
    May 2015
    San Francisco
    196
    I think I'm seeing a bug in usb_serial on Teensy 4.0. When I try sending a block of text larger than 2413 bytes via the serial port, it locks up. Here's the sketch:
    #include <Arduino.h>
      if (Serial.available()) {
        int x = Serial.read();
        Serial.write(x);
    I put 2414 bytes of text into foo.txt and from the macOS terminal:
    cat foo.txt > /dev/cu.usbmodem62442801
    This command get stuck as the teensy is no longer reading bytes. Putting 2413 bytes in the file, it works fine. This and much larger text files work fine on Teensy 3.6.
    Any thoughts?
    10,092
    Paul will be doing a full overhaul of the T_4 USB stack to some degree when the functional first pass is replaced with more efficient methods that may double the speed at least once.
    There is a reported issue already { Teensy-4-0-Serial-available()-stops-incrementing }where the buffered byte count STALLS and those bytes must be read to wake the USB read stack to update the count for additional bytes to be recognized/reported. This may somehow relate to that? Maybe the exact number of bytes flushes through leaving count empty and no way to call again to wake the read stack?
    There was another oddity where reading bytes to a STRING stuck in a similar manner on an exact byte count :: Teensy4-0-does-not-receive-data-longer-than-62-characters. Odd thing was I rewrote that loop to use null terminated C string and it acted properly?
    10,092
    Don't suppose any of these three changes make any difference?
    while ( !Serial );
      while (Serial.available()) {
        char x = Serial.read();
        Serial.write(x);
    May 2015
    San Francisco
    196
    Thanks, defragster. I did try your changes to no avail.
    I suspect that the issue outlined at https://forum.pjrc.com/threads/57325...s-incrementing is the same one, I missed that thread while trying to figure out what's going on here.
    Funny thing is that I can write those 2413 bytes over and over no problem. It's a single write of 2314 that stalls it out.
    10,092
    Quote Originally Posted by blackketter View Post
    I didn't think so - but …
    If that is the case then having the Host send another Byte or so after '2314' will rewake the receive unit?
    20,808
    Which version of MacOS are you using?
    10,092
    Not seeing this repro on Windows - LED comes on then goes off with code below.
    @blackketter - does sending one more byte after wake it up - re-reading first post perhaps not as it notes text larger that 2413 ... so may not be related. What do you see with sketch below WRT LED?
    CMDLINE of file 2410 to 2414 bytes:
    echo c:\tmp\test2413.txt > \\.\com30
    or
    type c:\tmp\test2413.txt > \\.\com30
    Sketch with LED:
    // https://forum.pjrc.com/threads/57995-Teensy-4-0-USB-serial-lockup?p=218791&viewfull=1#post218791
    elapsedMillis inw = 0;
      pinMode( 13, OUTPUT );
      digitalWriteFast( 13, 1 );
      inw = 0;
    int ii = 0;
        Serial.write(x);
        ii++;
        inw = 0;
      if (inw > 2000)
        digitalWriteFast( 13, 0 );
    May 2015
    San Francisco
    196
    macOS Mojave 10.14.6
    May 2015
    San Francisco
    196
    Once it locks up I can't unlock it with further transfers. With your example code, shorter sends to the Teensy work fine (led goes on, then goes off a couple of seconds later), but once a large transfer happens, it's stuck until I reboot.
    Interestingly, when I do send the larger file, the LED doesn't come on at all (i.e. no data from that larger transfer is ever available)
    I'm seeing now that the 2413 number isn't magical. I'm able to reproduce it now with the Teensy connected directly to the MBP USB-C port with as few as 64 byte transfers (previously it was through a couple of USB hubs...)
    Doesn't happen when I paste text into the terminal while using miniterm.py. Background: I discovered this while trying to program an ESP32 using esptool.py with the Teensy as a USB serial port adapter. Works great until esptool.py tries to send a 3k packet of code.
    10,092
    @blackketter - Interesting - sounds like it is faulting?
    To see use this version of the sketch - any <FAST SPAZ> blinking?
      inw = 0;
    int ii = 0;
        Serial.write(x);
        ii++;
        inw = 0;
      if (inw > 2000)
    void HardFault_HandlerC(unsigned int *hardfault_args)
      volatile unsigned int nn ;
      while (1)
        digitalWrite(13, HIGH);
        for (nn = 0; nn < 2000000; nn++) ;
        digitalWrite(13, LOW);
        for (nn = 0; nn < 18000000; nn++) ;
    @Paul - 'Fault Blink' the code in >> T:\arduino_1.8.10\hardware\teensy\avr\cores\teensy 4\startup.c :: HardFault_HandlerC(unsigned int *hardfault_args)
    Is still active and " GPIO2_xxx "not right for 1062 with FAST IO enabled
    #if 1
    	if ( F_CPU_ACTUAL >= 600000000 )
    		set_arm_clock(100000000);
    	IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 5; // pin 13
    	IOMUXC_SW_PAD_CTL_PAD_GPIO_B0_03 = IOMUXC_PAD_DSE(7);
    	GPIO2_GDIR |= (1<<3);
    	GPIO2_DR_SET = (1<<3);
    	while (1) {
    		volatile uint32_t n;
    		GPIO2_DR_SET = (1<<3); //digitalWrite(13, HIGH);
    		for (n=0; n < 2000000/6; n++) ;
    		GPIO2_DR_CLEAR = (1<<3); //digitalWrite(13, LOW);
    		for (n=0; n < 1500000/6; n++) ;
    #else
    	while (1) asm ("WFI");
    For release should the " #if 1 " be " #if 0 " ??
    >> Or perhaps better ... :: #ifdef PRINT_DEBUG_STUFF
    - then a user could turn on debug print and get FAULT blink on pin #13? Of course that would need a comment as #13 may be otherwise tied up.
    And those reg edits to GPIO2 are pre-fast IO?
    May 2015
    San Francisco
    196
    Thanks defroster, but alas, no. A single blink when it start, then it locks up as above without any blinks.
    10,092
    Interesting - must just be hung then - I didn't test with triggering a fault.
    If you did a 'pin Change interrupt to an ISR()' that did the blink in the isr() I'm suspecting that changing that pin would execute that code then.
    May 2015
    San Francisco
    196
    I'm not following. Something to test?
    10,092
    Yes, sorry to drop that and run.
    Here is that coded to pin #19 { #define SOME_PIN 19 } - it is set PULLUP, so when that pin is set to GND it will break into the _isr and blink { more on that off } for 2 seconds if the T4 is alive. Then return to where it was.
    If it goes to unending blink off more than on with short flashes - that is a FAULT. Same code as before should go on for 2 secs when Serial input is received. then off.
    #define SOME_PIN 19
    uint jj, temp;
      pinMode( SOME_PIN, INPUT_PULLUP );
      attachInterrupt( SOME_PIN, debtt_isr, CHANGE);
      inw = 0;
    void debtt_isr() {
      volatile unsigned int nn;
      inw = 0;
      while (inw <2000)
        for (nn = 0; nn < 7000000; nn++) ;
        delay(1);
    int ii = 0;
        Serial.write(x);
        ii++;
        inw = 0;
      if (inw > 2000)
      while (1)
    May 2015
    San Francisco
    196
    Alright! Thanks! With that test the ISR blinking continues to work even after the USB serial is locked up. And no HardFault blinking.
    May 2015
    San Francisco
    196
    Also, I should have noted earlier that after the USB serial lockup my larger application continued to work.
    In fact, USB serial writes from Teensy to host continue to work and loop() continues to be called.
    It's just that available() never returns a non-zero value again.
    10,092
    That is interesting and should give Paul something to work with as far as info.
    I noticed during Beta that the MCU could seem USB Serial or loop() stalled, but _isr active when I was working out a debug_tt library to offer some debugging log and feedback options - which is where the above code came from.
    When that _isr triggers and blinks it can also Serial.print - as you found the output Serial is still active but stuff doesn't come in or loop() can be stalled somewhere - but the _isr() can be usefully activated.
    May 2015
    San Francisco
    196
    @Paul: Any clue where I could dig to see if I could find where the lockup is happening? Happy to dig in here a bit...
    May 2015
    San Francisco
    196
    Still an issue. Filed bug here https://github.com/PaulStoffregen/cores/issues/401 so this doesn't get lost.
    20,808
    Ok, I'm considering this problem solved (and no longer following this thread). Will probably close issue #401 on github soon.
    As of today, the USB serial receive code is still far from optimal. I'm now focusing my attention on the receive side. Here's the thread I'm currently following regarding improving the receive code.
