Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 64
Thread: MacOS 10.15 Catalina
    20,808
    Is anyone using MacOS 10.15 Catalina yet?
    Looks like Apple has finally disallowed the method we've been using to modify a copy of Arduino. We may soon have to provide a complete copy of the IDE for Mac users.
    If you have Catalina & Teensy, please reply here or just subscribe to this thread. I'm going to need feedback from anyone with Catalina as I work on solving these problems.
    Feb 2014
    Colmar, France
    2,544
    I have it running here (Catalina and Arduino 1.8.10 and Teensyduino 1.48) . Install was some days ago. I remember that there was an additional hurdle, but I got over it. Don’t remember details, so will uninstall everything and start over with documentation. Stay tuned.
    Feb 2014
    Colmar, France
    2,544
    OK, re-did everything. The struggle is twice in a similar way, once for Arduino, and once for Teensyduino.
    After unpacking the downloaded Arduino.zip and moving the App into the Applications folder, you make a first attempt to start Arduino which seems to fail already:
Name:	Capture d’écran 2019-10-14 à 16.04.15.png
    Click "Show in Finder" and then right-click the Arduino app:
Name:	Capture d’écran 2019-10-14 à 16.05.00.png
    In the now open context menu CONTROL+Click "Open" (!important!), then you see a different dialog:
Name:	Capture d’écran 2019-10-14 à 16.05.26.png
    The middle button "Open" allows you to launch Arduino. This is a one time action. From now on, Arduino can be started in the usual way.
    For the now following Teensyduino installation, see next post.
    Feb 2014
    Colmar, France
    2,544
    Open the freshly downloaded Teensyduino.dmg with a double click:
Name:	Capture d’écran 2019-10-14 à 16.06.48.jpg
    It seems that it can't be installed. But it can. Click "OK". Make a right click on it:
Name:	Capture d’écran 2019-10-14 à 16.07.15.jpg
    Again, as before with Arduino, in the now open context menu CONTROL+Click "Open" (!important!), then you see a different dialog:
Name:	Capture d’écran 2019-10-14 à 16.07.40.jpg
    Now, still as before with Arduino, click the middle "Open" button to start the installation, which then goes without struggle and hassle:
Name:	Capture d’écran 2019-10-14 à 16.07.50.png
ID:	17897Click image for larger version.
Name:	Capture d’écran 2019-10-14 à 16.07.59.png
ID:	17898Click image for larger version.
Name:	Capture d’écran 2019-10-14 à 16.08.05.png
ID:	17899Click image for larger version.
Name:	Capture d’écran 2019-10-14 à 16.08.11.png
ID:	17900Click image for larger version.
Name:	Capture d’écran 2019-10-14 à 16.08.23.png
    Start Arduino again and enjoy the integrated Teensyduino:
Name:	Capture d’écran 2019-10-14 à 16.09.08.png
    Feb 2014
    Colmar, France
    2,544
    That workaround (right click the app, control+click "open") at the first launch does actually apply to almost all apps which aren't distributed through the Apple app store. It's the same with other popular non-app store apps like Gimp, Inkscape, Eclipse, and so on.
    Bundling Teensyduino with the Arduino app will reduce the number of extra clicks (and would considerably shorten my tutorial above), but would not solve any problem at its roots. The logical steps were that Arduino deploys its IDE through the App store, first, and then in a second step, that Teensyduino would also be deployed there.
    A dumb question, doesn't Arduino has a built in mechanism to support third party boards and libraries? What do other hardware vendor do?
    Feb 2014
    Colmar, France
    2,544
    They do. But that's not enough to add all the additions (and bug fixes and improvements) which Teensyduino brings to Arduino.
    If you have Catalina & Teensy, please reply here or just subscribe to this thread. I'm going to need feedback from anyone with Catalina as I work on solving these problems.[/QUOTE]
    did a fresh Catalina install, install Arduino - open arduino and compile a example file with a Arduino board = compile fine
    install teensyduino ( allowing on security and privacy to open anyway - see attach image )
    ran the installer open a sample for teensy = error message and not compiling error ( Exception in thread "Thread-0" java.lang.RuntimeException: java.lang.NullPointerException at processing.app.macosx.ThinkDifferent$4.lambda$open Files$0(ThinkDifferent.java:98) at java.lang.Thread.run(Thread.java:748))
    my solution was to give it full disk access from system preferences - security and privacy
    now teensy compiles
    Dec 2015
    LA
    140
    Just made the mistake of updating Mac to 10.15. I looked around in the forum first but missed this thread. dang!
    The @Theremingenieur and @Balum methods don't work for me. I can't get the Security & Privacy window to show that "Teensyduino-app" line at all as above.
    Arduino 1.8.10 and Td 1.48 were working fine on Mac 10.14. but after the upgrade, Arduino quits while showing:
    Tried fiddling with various security settings but same result. Reinstalled both, same result.
    Note that apple had said they were not going to allow un-identified developers although the Arduino 1.8.10 showed as un-identified but worked with the usual cntr-open buttons before the Teensduino install.
    Dec 2015
    LA
    140
    I can report that today after doing nothing more than having the Mac sleep overnight, not turned off, Catalina, Arduino 1.8.10, and Teensduino 1.48 seem to be happy again. Perhaps all the re-arranging that the MacOS does in the background with a new system install was not complete.
    I do not know if a re-install of 1.8.10 and 1.48 was needed or not, perhaps if I had waited it would have worked? I have Arduino allowed under Accessibility, Input Monitoring, Full Disk Access and Files and Folders in Security & Privacy/Privacy. I will try to remove some of them and see what happens.
    Dec 2015
    LA
    140
    As noted above I have tried to set the highest security settings.
    Unfortunately, Full Disk Access is required.
    Accessibility is not required.
    Input Monitoring is requested once at App startup but not required AFAIK.
    Network connections is requested every time App is started, but can be denied.
    The 'Files and Folders' in Security & Privacy / Privacy preference used to be Arduino -> Documents folder. That may have to be deleted so the 'Full disk access' will work.
    good luck !
    Oct 2019
    2
    I cannot even install a new Arduino app. I get a vague message about “Arduino.app” can’t be opened because Apple cannot check it for malicious software. The (?) icon next to it does not even respond, so this must be something not very well thought out. This is with 1.8.10 from the arduino.cc website.
    EDIT: OK, grmbl. It is another instance of the "move to applications, click right and then open anyway" fake-security things.
    Dec 2015
    LA
    140
    Quote Originally Posted by rvjansen View Post
    This is not a 'fake' security thing. This is circumventing all the work Apple does to help developers make their code and your computer secure. Unfortunately, most open source developers don't use much of it. Perhaps for legal reasons they fear that code signing their apps makes them responsible for any problems.
    As it is now we have to give the Arduino app total access to our computers and hope that somebody hasn't put something in the code.
    Oct 2019
    3
    Same issue
    Quote Originally Posted by bicycleguy View Post
    I'm having the same problem, unfortunately a computer nap was not sufficient to fix mine.
    Oct 2019
    3
    edit
    Quote Originally Posted by kidkill View Post
    Edit, this is the message for me:
    Arduino: 1.8.10 (Mac OS X), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    loading libs from /Users/mein/Documents/Arduino/libraries: reading dir /Users/mein/Documents/Arduino/libraries: open /Users/mein/Documents/Arduino/libraries: operation not permitted
    Error compiling for board Teensy 4.0.
    Dec 2016
    Montreal, Canada
    3,134
    Did you see the madness Catalina did to people with gmail, random email deletions and blank sent folders. Lol apple messed up big time
    Nov 2016
    3
    Cannot get it to work here : Catalina 10.15.1 Beta (19B77a) & freshly installed Arduino 1.8.10 & Teensyduino 1.48
    I had a few times the Keyboard Accessibility popup, but Arduino didn't appeared in the accessibility menu so impossible to grant any rights.
    It stop asking after a reboot but the Arduino doesn't start.
    I have the splash screen with initialization (up until "starting...") then the app close.
    The ctrl+open tricks does nothing.
    Nov 2016
    3
    Giving full access to the harddrive actually fixed the issue, but the arduino doesn't appear in the list of app with full drive access :/
    I got the exact same message, but ignored it. I fixed my problems by going into security and giving full access to arduino :-)
    Jul 2018
    3
    Operation not allowed because of permissions
    I have the same problem, the only boards that are working are Arduino.
    Jul 2019
    4
    Upgrade to teensy 1.48 beta 1 or later ( I'm running 1.49 beta 3). Ensure you have given arduino full permissions before running the teensy installer...leave arduino open.
    Had massive issues ( i was running the catalina betas) but all is working perfectly now...
    oh and do the right click open if you get the can't verify message.
    Nov 2019
    4
    Registered to share my woes with Catalina. Right now I'm unclear where to find the teensy 1.48 or 1.49 beta, but I'll dig around.
    Salem, MA
    49
    I have the same problem as kidkill in #15,
    loading libs from /Users/hugh/Documents/Arduino/libraries: reading dir /Users/hugh/Documents/Arduino/libraries: open /Users/hugh/Documents/Arduino/libraries: operation not permitted
    Quote Originally Posted by hpyle View Post
    I have the same problem on catalina. I have tried reinstalling arduino, teensyduino, and even the beta arduino. The teensyduino does not recognize beta arduino as a supported instance. This problem is holding up my development efforts.
    Apr 2017
    Florida
    424
    I recently updated to MacOS Catalina and using my previous installs of Arduino after giving them access in the system preferences I have had no problems with it.
