Results 1 to 3 of 3
Thread: Waveshaper - storing waveshape arrays in flash
    Aug 2015
    Scotland
    175
    I'm using AudioEffectWaveshaper with Teensy3.6 and the Audio Board in an audio effect project. I'm running low on memory so want to move the waveshape arrays to flash rather than RAM.
    To do this I'm using const float array []. While this seems to work the complier doesn't like it with 'warning: invalid conversion from 'const float*' to 'float*' [-fpermissive]'.
    I use VSCode with PlatformIO, if I try to compile in Arduino then it fails completely (with similar error).
    I've included a simple example below that cycles a sine wave through a couple of different waveshapers.
    My question is : is there a better way to store wave shape arrays in flash that avoids the compiler warnings/errors? Cheers, Paul
    AudioSynthWaveform       waveform;
    AudioEffectWaveshaper    waveshape1;
    AudioOutputI2S           i2s2;
    AudioConnection          patchCord1(waveform, 0, waveshape1, 0);
    AudioConnection          patchCord2(waveshape1, 0, i2s2, 0);
    AudioConnection          patchCord3(waveshape1, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;
    const float wave_shape_flat[2] = {
      -1.0,
      1.0
    const float wave_shape_chebyshev_3rd [257] =
      -1.0,-0.9375,-0.8671875,-0.796875,-0.734375,-0.671875,-0.609375,-0.546875,-0.484375,-0.4296875,-0.375,-0.3203125,
      -0.265625,-0.2109375,-0.15625,-0.109375,-0.0546875,-0.0078125,0.0390625,0.078125,0.125,0.1640625,0.2109375,0.25,
      0.2890625,0.328125,0.359375,0.3984375,0.4296875,0.46875,0.5,0.53125,0.5546875,0.5859375,0.6171875,0.640625,0.6640625,
      0.6953125,0.71875,0.734375,0.7578125,0.78125,0.796875,0.8203125,0.8359375,0.8515625,0.8671875,0.8828125,0.890625,
      0.90625,0.921875,0.9296875,0.9375,0.953125,0.9609375,0.96875,0.96875,0.9765625,0.984375,0.984375,0.9921875,0.9921875,
      0.9921875,0.9921875,0.9921875,0.9921875,0.9921875,0.9921875,0.9921875,0.984375,0.984375,0.9765625,0.9765625,0.96875,
      0.9609375,0.953125,0.9453125,0.9375,0.9296875,0.921875,0.90625,0.8984375,0.890625,0.875,0.8671875,0.8515625,0.8359375,
      0.828125,0.8125,0.796875,0.78125,0.765625,0.75,0.734375,0.71875,0.703125,0.6796875,0.6640625,0.6484375,0.6328125,0.609375,
      0.59375,0.5703125,0.5546875,0.53125,0.515625,0.4921875,0.46875,0.453125,0.4296875,0.40625,0.3828125,0.359375,0.34375,0.3203125,
      0.296875,0.2734375,0.25,0.2265625,0.203125,0.1796875,0.15625,0.1328125,0.109375,0.0859375,0.0625,0.0390625,0.015625,0,
      -0.0234375,-0.046875,-0.0703125,-0.09375,-0.1171875,-0.140625,-0.1640625,-0.1875,-0.2109375,-0.234375,-0.2578125,-0.28125,
      -0.3046875,-0.328125,-0.3515625,-0.3671875,-0.390625,-0.4140625,-0.4375,-0.4609375,-0.4765625,-0.5,-0.5234375,-0.5390625,
      -0.5625,-0.578125,-0.6015625,-0.6171875,-0.640625,-0.65625,-0.671875,-0.6875,-0.7109375,-0.7265625,-0.7421875,-0.7578125,
      -0.7734375,-0.7890625,-0.8046875,-0.8203125,-0.8359375,-0.84375,-0.859375,-0.875,-0.8828125,-0.8984375,-0.90625,-0.9140625,
      -0.9296875,-0.9375,-0.9453125,-0.953125,-0.9609375,-0.96875,-0.9765625,-0.984375,-0.984375,-0.9921875,-0.9921875,-1,-1,-1,-1,
      -1,-1,-1,-1,-1,-0.9921875,-0.9921875,-0.984375,-0.9765625,-0.9765625,-0.96875,-0.9609375,-0.9453125,-0.9375,-0.9296875,-0.9140625,
      -0.8984375,-0.890625,-0.875,-0.859375,-0.84375,-0.828125,-0.8046875,-0.7890625,-0.765625,-0.7421875,-0.7265625,-0.703125,
      -0.671875,-0.6484375,-0.625,-0.59375,-0.5625,-0.5390625,-0.5078125,-0.4765625,-0.4375,-0.40625,-0.3671875,-0.3359375,-0.296875,
      -0.2578125,-0.21875,-0.171875,-0.1328125,-0.0859375,-0.046875,0,0.046875,0.1015625,0.1484375,0.203125,0.2578125,0.3125,0.3671875,
      0.421875,0.4765625,0.5390625,0.6015625,0.6640625,0.7265625,0.7890625,0.859375,0.9296875,0.9996875
    const float wave_shape_chebyshev_6th [257] =
      0.490693441,0.270855938,0.072669375,-0.104991361,-0.263216483,-0.403061926,-0.525549963,-0.631669818,-0.722378276,
      -0.79860028,-0.861229534,-0.911129093,-0.949131951,-0.976041622,-0.992632719,-0.999651527,-0.997816569,-0.987819169,
      -0.970324009,-0.945969683,-0.915369243,-0.879110741,-0.837757768,-0.791849987,-0.741903658,-0.688412162,-0.631846518,
      -0.572655896,-0.511268125,-0.448090193,-0.383508747,-0.317890586,-0.251583144,-0.184914977,-0.118196241,-0.05171916,
      0.014241505,0.079427988,0.143599071,0.206529621,0.268010148,0.327846365,0.385858743,0.441882084,0.495765094,0.547369957,
      0.59657192,0.643258879,0.687330973,0.728700181,0.767289925,0.803034675,0.835879566,0.86578001,0.892701325,0.916618355,
      0.93751511,0.955384399,0.970227472,0.982053671,0.990880081,0.996731184,0.999638529,0.999640393,0.996781454,0.991112473,
      0.982689972,0.971575925,0.957837447,0.941546494,0.922779566,0.90161741,0.87814474,0.852449947,0.824624828,0.794764306,
      0.762966172,0.729330814,0.693960964,0.656961444,0.61843892,0.578501658,0.537259286,0.494822565,0.451303155,0.406813401,
      0.361466108,0.315374332,0.268651175,0.221409575,0.173762116,0.125820832,0.077697021,0.029501059,-0.018657772,-0.066671461,
      -0.114433432,-0.161838711,-0.208784079,-0.255168227,-0.300891902,-0.345858051,-0.389971958,-0.433141375,-0.475276652,
      -0.516290858,-0.556099899,-0.594622629,-0.63178096,-0.667499963,-0.701707965,-0.734336644,-0.765321112,-0.794600003,
      -0.822115545,-0.847813638,-0.871643916,-0.893559814,-0.913518623,-0.931481545,-0.947413734,-0.961284349,-0.973066581,
      -0.982737693,-0.990279043,-0.99567611,-0.998918508,-1,-0.998918508,-0.99567611,-0.990279043,-0.982737693,-0.973066581,
      -0.961284349,-0.947413734,-0.931481545,-0.913518623,-0.893559814,-0.871643916,-0.847813638,-0.822115545,-0.794600003,
      -0.765321112,-0.734336644,-0.701707965,-0.667499963,-0.63178096,-0.594622629,-0.556099899,-0.516290858,-0.475276652,
      -0.433141375,-0.389971958,-0.345858051,-0.300891902,-0.255168227,-0.208784079,-0.161838711,-0.114433432,-0.066671461,
      -0.018657772,0.029501059,0.077697021,0.125820832,0.173762116,0.221409575,0.268651175,0.315374332,0.361466108,0.406813401,
      0.451303155,0.494822565,0.537259286,0.578501658,0.61843892,0.656961444,0.693960964,0.729330814,0.762966172,0.794764306,
      0.824624828,0.852449947,0.87814474,0.90161741,0.922779566,0.941546494,0.957837447,0.971575925,0.982689972,0.991112473,
      0.996781454,0.999640393,0.999638529,0.996731184,0.990880081,0.982053671,0.970227472,0.955384399,0.93751511,0.916618355,
      0.892701325,0.86578001,0.835879566,0.803034675,0.767289925,0.728700181,0.687330973,0.643258879,0.59657192,0.547369957,
      0.495765094,0.441882084,0.385858743,0.327846365,0.268010148,0.206529621,0.143599071,0.079427988,0.014241505,-0.05171916,
      -0.118196241,-0.184914977,-0.251583144,-0.317890586,-0.383508747,-0.448090193,-0.511268125,-0.572655896,-0.631846518,
      -0.688412162,-0.741903658,-0.791849987,-0.837757768,-0.879110741,-0.915369243,-0.945969683,-0.970324009,-0.987819169,
      -0.997816569,-0.999651527,-0.992632719,-0.976041622,-0.949131951,-0.911129093,-0.861229534,-0.79860028,-0.722378276,
      -0.631669818,-0.525549963,-0.403061926,-0.263216483,-0.104991361,0.072669375,0.270855938,0.490693441,0.733342528,1
      AudioMemory(40);
      waveform.begin(1.0, 200.0, WAVEFORM_SINE);
      waveshape1.shape(wave_shape_flat, 2);
      delay (500);
      waveshape1.shape(wave_shape_chebyshev_3rd, 257);
      waveshape1.shape(wave_shape_chebyshev_6th, 257);
    1,635
    shape expects a (float *) as its first argument. Just cast it and the warning will go away.
      waveshape1.shape((float *)wave_shape_flat, 2);
    and similarly for the other two.
    Pete
    Aug 2015
    Scotland
    175
    D'oh! I should have tried that. Works perfectly - thanks
