Results 1 to 3 of 3
Thread: Teensy 4 FreqCount compile error
    Aug 2019
    southwest USA
    50
    this report concerns Teensy4 and FreqCount library
    win7x64,Arduino 1.8.5, Teensyduino 1.48 release
    compiles well if choose TeensyLC 48 mhz smallest.
    i do not know how to get the compile listing if
    there are no errors.
    compile error if choose Teensy 4 600 mhz faster.
    i did note that both use same Freqmeas and
    FreqCount libraries.
    here is the code:
    // tlc complete fsk rcvr 4ary
    // use with ft-25 vol = point center
    // rf sq 1
    // FT-25 NO 1 HAS 0.14 UV SENS
    // pin 13 audio in (int led cut)
    // pin 16 tied to 13 for fmeas
    // pin 5 thru tone gen to 3.3v
    // data in is 32 bits
    // tbit may be 20,40,80,140,200 ms
    // solid tone 5 sec good msg
    // 5 tones    5 sec  bad msg
    // 1 short tone bad synch wt  800
    // 2 short tone bad synch wt !800
    // 80 ms 500/800/1272/2008
    // 800 hz header
    // to sync uses fmeas to wait
    // for 800 then wait for not 800
    // 796 +- 33hz +- 4%
    // then drops into old fctr rtn
    // data in 32 bits
    // does 8 bit dummy then
    // 12 bit data word then
    // 12 bit data word
    // small 16% pgm  28% ram ok
    #include <FreqCount.h>
    #include <FreqMeasure.h>
    elapsedMillis etime;
      unsigned short int tbit,sdelay;
      unsigned short int lim1,lim2,lim3;
      unsigned short int lim4,lim5;
    volatile unsigned short int rcount;
    volatile unsigned short int ary[45];
    volatile unsigned short int lc;
    volatile unsigned short int pdta;
    volatile unsigned short int rp1,rp2;
    volatile unsigned short int wrd0r,wrd1r,wrd2r;
    volatile unsigned short int shft;
    volatile unsigned short int wc;
    volatile unsigned short int adr;
    volatile unsigned short int fc;
    volatile unsigned short int flag;
    volatile unsigned short int mc;
    volatile unsigned short int vc;
    volatile unsigned int fm;
    volatile unsigned int pe2;
    volatile unsigned short int nm;
    volatile unsigned short int c8;
    //volatile unsigned int arb[21];
    //volatile unsigned short int lb;
    int main() {
    // tbit may be 20 or 40 or 80 or 140 or 200
       tbit=80;
       if(tbit== 20) sdelay=20;
       if(tbit== 40) sdelay=20;
       if(tbit== 80) sdelay=80;
       if(tbit==140) sdelay=140;
       if(tbit==200) sdelay=200;
       if(tbit== 20) lim1=7;
       if(tbit== 40) lim1=15;
       if(tbit== 80) lim1=29;
       if(tbit==140) lim1=51;
       if(tbit==200) lim1=73;
       if(tbit== 20) lim2=13;
       if(tbit== 40) lim2=25;
       if(tbit== 80) lim2=51;
       if(tbit==140) lim2=89;
       if(tbit==200) lim2=127;
       if(tbit== 20) lim3=20;
       if(tbit== 40) lim3=40;
       if(tbit== 80) lim3=81;
       if(tbit==140) lim3=141;
       if(tbit==200) lim3=201;
       if(tbit== 20) lim4=32;
       if(tbit== 40) lim4=64;
       if(tbit== 80) lim4=128;
       if(tbit==140) lim4=224;
       if(tbit==200) lim4=320;
       if(tbit== 20) lim5=48;
       if(tbit== 40) lim5=97;
       if(tbit== 80) lim5=193;
       if(tbit==140) lim5=338;
       if(tbit==200) lim5=483;
      vc=1;
      adr=1;
      pinMode(13, INPUT);
      pinMode( 5, OUTPUT);
      digitalWrite(5, LOW);
      digitalWrite(5,HIGH);
    mloop:
      mc=0;
    lmc:
      ary[mc]=0;
      ++mc;
      if(mc<44)goto lmc;
      Serial.println("begin");
    // wait for pin 13 to change
      wc=0;
    wtchg:
      rp1=digitalReadFast(13);
      delayMicroseconds(2);
      rp2=digitalReadFast(13);
      if (rp1==rp2) goto wtchg;
      ++wc;
      if (wc<vc) goto wtchg;
      nm=0;
      fm=0;
      if (tbit== 20) delay(20);
      if (tbit== 40) delay(20);
      if (tbit== 80) delay(20);
      if (tbit==140) fm=fm;
      if (tbit==200) fm=fm;
      FreqMeasure.begin();
      etime=0;
    fmeas:
      nm = FreqMeasure.available();
    // abort if too long
       pe2=etime;
      if(pe2<20) goto sk1;
      goto mloop;
    sk1:
      if (!nm) goto fmeas;
      fm = FreqMeasure.read();
    //  Serial.println("*");
    // was 59500 61300
    // was 57500 62300
      if((fm<57900)||(fm>62910)) goto fmeas;
    //  Serial.println("**");
    // have seen 800
      etime=0;
    fmeas2:
      pe2=etime;
      if(pe2<430) goto sk2;
      goto mloop;
    sk2:
      if (!nm) goto fmeas2;
    //  Serial.println("***");
    //  Serial.println(fm);
    // was 59500 61300
    // was 57500 62300
      ++c8;
      if((fm>57900)&&(fm<62910)) goto fmeas2;
    //  Serial.println("****");
    // have seen not 800
      FreqMeasure.end();
      delay(sdelay);
    //  Serial.println("fmeas");
    //  Serial.println(nm);
      FreqCount.begin(sdelay);
      lc=0;
      Serial.println("trig");
    // meas cts per 80/140ms 16 times
    // and store msmnts in ary[]
    loop:
        if (!FreqCount.available()) goto loop;
        volatile unsigned short int count = FreqCount.read();
        ++lc;
        ary[lc]=count;
    //    ++lc;
      if (lc < 16) goto loop;
      FreqCount.end();
      lc=0;
    //ploop:
    //  Serial.println(ary[lc+adr]);
    //  ++lc;
    //  if (lc < 17) goto ploop;
    // done mesuring fsk in
    // now decode
    // get header 8 bits
      lc=0;
      wrd0r=0;
      shft=1;
    loop0:
      pdta=ary[lc+adr];
      if (pdta>= lim1 && pdta< lim2)
         wrd0r=wrd0r+shft*0;
      if (pdta>= lim2 && pdta< lim3)
         wrd0r=wrd0r+shft*1;
      if (pdta>=lim3 && pdta<lim4)
         wrd0r=wrd0r+shft*2;
      if (pdta>=lim4 && pdta<lim5)
         wrd0r=wrd0r+shft*3;
      shft=shft<<2;
      ++lc;
     if (lc < 4) goto loop0;
    // skew array read for 12 bit words if
    // 8 bit header value too small
    // if((wrd0r>120)&&(wrd0r<220)) goto ladr;
    // adr=adr-1;
    ladr:
    // get first 12 bit data word
      wrd1r=0;
      shft=1;
    loop1:
      pdta=ary[lc+adr];
         wrd1r=wrd1r+shft*0;
         wrd1r=wrd1r+shft*1;
         wrd1r=wrd1r+shft*2;
         wrd1r=wrd1r+shft*3;
     shft=shft<<2;
      ++lc;
     if (lc < 10) goto loop1;
    // get 2nd 12 bit data word
      wrd2r=0;
      shft=1;
    loop2:
      pdta=ary[lc+adr];
         wrd2r=wrd2r+shft*0;
         wrd2r=wrd2r+shft*1;
         wrd2r=wrd2r+shft*2;
         wrd2r=wrd2r+shft*3;
     shft=shft<<2;
      ++lc;
     if (lc < 16) goto loop2;
      Serial.println(vc);
      Serial.println(adr);
      Serial.println(c8);
      Serial.println(wrd0r);
      Serial.println(wrd1r);
      Serial.println(wrd2r);
      Serial.println(" ");
    //  vc=vc+1;
    // reset adr
    //  adr=1;
      flag=0;
      if ((wrd1r > 2889)&&(wrd1r<2893)) ++flag;
      if ((wrd2r > 2889)&&(wrd2r<2893)) ++flag;
      if (flag!=2) goto lbad;
      delay(5000);
    goto mloop;
    lbad:
    goto mloop;
    here is the verbose error listing:
    Arduino: 1.8.5 (Windows 7), TD: 1.48, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_368125 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_315675 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_368125 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_315675 -verbose C:\Users\Dell\Documents\Arduino\libraries\arf1\arf1.ino
    Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Detecting libraries used...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure\FreqMeasure.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/precompile_helper" "C:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125" "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr/cores/teensy4" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch/Arduino.h" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch/Arduino.h.gch"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp.o"
    arf1: In function 'int main()':
    arf1:232: warning: label 'ladr' defined but not used
     ladr:
    Compiling libraries...
    Compiling library "FreqCount"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount\FreqCount.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\libraries\FreqCount\FreqCount.cpp.o"
    Compiling library "FreqMeasure"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure\FreqMeasure.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\libraries\FreqMeasure\FreqMeasure.cpp.o"
    Compiling core...
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memcpy-armv7m.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\memcpy-armv7m.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\memset.S" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\memset.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\analog.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\analog.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\bootdata.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\bootdata.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\clockspeed.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\clockspeed.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\debugprintf.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\debugprintf.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\delay.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\delay.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\digital.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\digital.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\eeprom.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\eeprom.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\interrupt.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\interrupt.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\keylayouts.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\keylayouts.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\nonstd.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\nonstd.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\pwm.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\pwm.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\rtc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\rtc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\startup.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\startup.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\tempmon.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\tempmon.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_desc.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_desc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_rawhid.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_rawhid.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_seremu.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_seremu.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_serial.c" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_serial.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\AudioStream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\AudioStream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\DMAChannel.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\DMAChannel.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\EventResponder.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\EventResponder.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial1.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial1.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial2.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial2.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial3.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial3.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial4.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial4.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial5.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial5.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial6.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial6.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial7.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial7.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\HardwareSerial8.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial8.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IPAddress.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\IPAddress.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\IntervalTimer.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\IntervalTimer.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Print.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Print.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Stream.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Stream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\Tone.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Tone.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WMath.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\WMath.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\WString.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\WString.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\main.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\main.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\new.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\new.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\usb_inst.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_inst.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=148 -DARDUINO=10805 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Users\Dell\AppData\Local\Temp\arduino_build_368125/pch" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4" "C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\yield.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\yield.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\memcpy-armv7m.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\memset.S.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\analog.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\bootdata.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\clockspeed.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\debugprintf.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\delay.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\digital.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\eeprom.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\interrupt.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\keylayouts.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\nonstd.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\pwm.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\rtc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\startup.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\tempmon.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_desc.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_rawhid.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_seremu.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_serial.c.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\AudioStream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\DMAChannel.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\EventResponder.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial1.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial2.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial3.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial4.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial5.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial6.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial7.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\HardwareSerial8.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\IPAddress.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\IntervalTimer.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Print.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Stream.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\Tone.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\WMath.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\WString.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\main.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\new.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\usb_inst.cpp.o"
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc-ar" rcs "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\core.a" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\core\yield.cpp.o"
    Archiving built core (caching) in: C:\Users\Dell\AppData\Local\Temp\arduino_cache_315675\core\core_teensy_avr_teensy40_usb_serial,speed_600,opt_o2std,keys_en-us_4939f5412a75a8560acb0f9e98268f02.a
    "C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt1062.ld"  -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125/arf1.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\libraries\FreqCount\FreqCount.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\libraries\FreqMeasure\FreqMeasure.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_368125/core\core.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_368125" -larm_cortexM7lfsp_math -lm -lstdc++
    C:\Users\Dell\AppData\Local\Temp\arduino_build_368125\sketch\arf1.ino.cpp.o: In function `main':
    C:\Users\Dell\Documents\Arduino\libraries\arf1/arf1.ino:198: undefined reference to `FreqCountClass::end()'
    Using library FreqCount at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqCount
    Using library FreqMeasure at version 1.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FreqMeasure
    9,967
    There is a test note linked here in Post #4 for Freq Count in the T_4 Beta thread : not indicated that FreqCount Library resolved for Teensy 4 use at this time:
    pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test
    4,221
    @analog&RFmodels
    Just checked - you are right for the 1062 the end function is missing. I just added with the following PR: https://github.com/PaulStoffregen/FreqCount/pull/16.
    Just remember if you shut down the timer will have to do a Freqcount.begin again.
