I'm working up a 6-button doorbell for a shared office. The goal is to play a song snipped (WAV file) and animate a string of 77 LEDs for the duration of the song. Each playback/animation is triggered by a pushbutton. The following code works for shorter LED strips (10 are fine, but 20 aren't). With more LEDs, it latches during playback. The "latch" behavior is that it stops playing mid-file and emits a buzz via the audio out and the LED strip stops animating. I suspected an interrupt issue and switched from FastLED to the WS2812serial library which I read is non-blocking. However, the issue exists using either library. I suspect there is something problematic with my logic for testing buttons etc?
If anyone has suggestions, I'm happy to hear them! Thanks,
// Teensy 3.2 with Audio Shield implemented as 6-button doorbell
#include <Bounce.h>
#include <WS2812Serial.h>
// How many leds are in the strip?
//const int numled = 77;
const int numled = 10;
// Data pin that led data will be written out over
const int pin = 1;
byte drawingMemory[numled*3]; // 3 bytes per LED
DMAMEM byte displayMemory[numled*12]; // 12 bytes per LED
WS2812Serial leds(numled, displayMemory, drawingMemory, pin, WS2812_GRB);
#define RED 0xFF0000
#define GREEN 0x00FF00
#define BLUE 0x0000FF
#define YELLOW 0xFFFF00
#define PINK 0xFF1088
#define ORANGE 0xE05800
#define WHITE 0xFFFFFF
#define BLACK 0x000000
long randNumber;
const int buttonPin1 = 2;
Bounce pushbutton1 = Bounce(buttonPin1, 20);
const int buttonPin2 = 3;
Bounce pushbutton2 = Bounce(buttonPin2, 20);
const int buttonPin3 = 4;
Bounce pushbutton3 = Bounce(buttonPin3, 20);
const int buttonPin4 = 5;
Bounce pushbutton4 = Bounce(buttonPin4, 20);
const int buttonPin5 = 16;
Bounce pushbutton5 = Bounce(buttonPin5, 20);
const int buttonPin6 = 17;
Bounce pushbutton6 = Bounce(buttonPin6, 20);
AudioPlaySdWav playSdWav1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s1, 1);
delay(2000);
leds.begin();
// initialize the pushbutton pin as an input:
pinMode(buttonPin1, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
pinMode(buttonPin3, INPUT_PULLUP);
pinMode(buttonPin4, INPUT_PULLUP);
pinMode(buttonPin5, INPUT_PULLUP);
pinMode(buttonPin6, INPUT_PULLUP);
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(7);
SPI.setSCK(14);
if (!(SD.begin(10))) {
while (1) {
leds.setPixel(1, RED);
leds.setPixel(2, RED); // indicates SD card error
leds.show();
int microsec = 1500000 / leds.numPixels();
pushbutton1.update();
if (pushbutton1.fallingEdge()) {
playSdWav1.play("925.wav");
colorWipe(WHITE, microsec);
pushbutton2.update();
if (pushbutton2.fallingEdge()) {
playSdWav1.play("gtw.wav");
colorWipe(BLUE, microsec);
pushbutton3.update();
if (pushbutton3.fallingEdge()) {
playSdWav1.play("ilikeit.wav");
colorWipe(RED, microsec);
pushbutton4.update();
if (pushbutton4.fallingEdge()) {
playSdWav1.play("oops.wav");
colorWipe(YELLOW, microsec);
pushbutton5.update();
if (pushbutton5.fallingEdge()) {
playSdWav1.play("queens.wav");
colorWipe(PINK, microsec);
pushbutton6.update();
if (pushbutton6.fallingEdge()) {
playSdWav1.play("tiktok.wav");
colorWipe(GREEN, microsec);
if ( playSdWav1.isPlaying() == 0 ) {
delay(200);
if (playSdWav1.isPlaying() == 0 ) {
colorWipe(BLACK, 20);
void colorWipe(int color, int wait) {
for (int i=0; i < leds.numPixels(); i++) {
leds.setPixel(i, color);
leds.show();
delay(200);
delayMicroseconds(wait);
