Results 1 to 4 of 4
Thread: WS2812Serial Question
    Feb 2017
    313
    Hi All:
    Is seen in the example code for the WS2812Serial libary the following line:
    //   Teensy 3.2:  1, 5, 8, 10, 31   (overclock to 120 MHz for pin 8)
    Just curious why the need for 120 MHz to use Pin 8.
    Any insight appreciated.
    Thanks.
    20,674
    Quote Originally Posted by gfvalvo View Post
    Serial3 on Teensy 3.2 runs from the slower F_BUS clock, which is too slow for WS2812Serial unless you run at 120 MHz.
    Serial1 and Serial2 run from the faster F_CPU clock.
    Feb 2017
    313
    Thanks Paul. I was just about to post that I found that info after digging through the datasheet for a while.
    Feb 2017
    313
    So, if I'm reading the datasheet and source code correctly, it looks like the Baud is actually set to 3.75 MHz on a T3.2 (overclocked) when Pin 8 / UART2 is selected. Right?
