Results 1 to 4 of 4
Thread: T3.5 Serial Halting Problem
    I've used the T3.2 for years, and this is a strange problem that should be beneath me, but I can't figure it out.
    Teensy 3.5.
    Arduino IDE 1.8.9
    Teensy Loader 1.46
      Serial.begin(57600);
      pinMode(LED_BUILTIN, OUTPUT);
      Serial.print("Hello  ");
      Serial.println(millis());
      digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
    I am unable to get reliable serial data. The LED is flashing, and I must power cycle multiple times until the USB serial connection is reliable. kernel messages seem normal for the USB negotiation. The first cat of the port gives me a buffer full, then the next cat hangs waiting for more data. Miniterm gives the same result.
    root@michalk-desktop:~# cat /dev/ttyACM0
    Hello  1300
    Hello  2300
    Hello  3300
    Hello  4300
    Hello  5300
    Hello  6300
    Hello  7300
    Hello  8300
    Hello  9300
    Hello  10300
    ^C
    ^C
    Update:
    If I use the Arduino serial monitor, it's initially grey, then when the Teensy boots, it shows the serial data. I can close the Arduino serial monitor, and open miniterm, or cat the device, and it functions as expected.
    If I replug the Teensy without the serial monitor running, Miniterm, or cat do not work. It seems there's some handshake that's happening when the program first starts, and the serial monitor is allowing it to work properly. How can I get this to work without the serial monitor?
    It looks like the udev rules fixed this problem. I'm not sure when they changed, and a system update probably caused this problem. The udev rules from the install web page fixed this problem.
    21,119
    Ubuntu recently changed the default ModemManager filter policy. Maybe other distros did too? In theory, it's the sort of settings change that's supposed to improve security or something.
    ModemManager has a documented behavior to ignore certain things in that mode. Whether you see that as a feature or bug is a matter of opinion. The ModemManager developers have made improvements so explicit udev rules will no longer be ignored in that mode (the stuff it's supposed to ignore has been renamed), but it will take years for those improvements to be updated to mainstream Linux distros.
    We updated the udev rules shortly after this problem began, to also tell ModemManager to not interfere in a 2nd way (ports vs devices). ModemManager still sees Teensy, but fortunately it does seem to prevent ModemManager from causing trouble. That's why updating the udev rule fixes this problem. It's all ModemManager misbehaving.
    Long ago, it seemed like every year another ModemManager bug or "feature" would haunt us. It's been a few years of quiet, but sadly ModemManager came back yet again this year to disrupt Teensy and Arduino and so many others. I really don't like ModemManager...
    For all my Linux development I have removed ModemManager.
    sudo apt-get purge modemmanager
