LittleFS port to Teensy/SPIFlash
Oh, yeah, there's probably bugs in openNextFile() with subdirectories. I had to do some kludgy stuff with pathnames. Some not-so-safe string manipulation is also done in there which really needs to be hardened against buffer overflows. Will dig into it later today...
Just reverted my changes to the ScanDir function to use the version with file_.openNextFile to see what would happen (more as another data point). For RAM and SPI seems to working with a problem to display sub-directories and files in the root directory. However when you use it for QSPI then you run into the issue what we posted.
Good luck
Let me know if you need some more testing. If so which versions of libraries to use, like the main one or the WIP branch...
Morning Kurt
If you want to give it a try I would use the WIP branch. Its now set up so you can have multiple SPIFlash chips and multiple RAMDISKs if you want. Use the mtp_test_combine.ino sketch. The change was to get in line @WMXZ's changes to use multiple SD Cards :)
The one thing I was hoping to do was set it up so you could use all 3 storage devices but ran into a problem that I just can't break the code on. Evident when you run the mpt_test_combined1 sketch.
Thanks for giving it a try.
re p#248 p#247 P#246 - not getting good result on Root either - and goes down hill from there adding subdirs
@Paul - In posted sketch just edited to create and cycle over only 4 files on root not 26 @line 32::
>> #define MAXNUM 4 //26 // ALPHA A-Z is 26, less for fewer files
dir 'f'ormat for fresh disk.
did '1' iterations a few times : repro got to #28. "C" just worked to update and "D" failed
> This indicates that "D" was 31 bytes and another 31 bytes were written, file closed, then VERIFY to read back the 62 bytes that should have been in "D" when "D" failed to open.
 QSPI_DISK +++ Add ++++ [was 21 wrote 21] ++ C 	Verify /C_file.txt bytes read 42 and size 42
	FILE	A_file.txt		101
	FILE	B_file.txt		22
	FILE	C_file.txt		42
	FILE	D_file.txt		31
 0 dirs with 4 files of Size 196 Bytes
[  0.91 M] Awaiting input 0123456789rdchkfvpl? loops left 0 >1
:: /D_file.txt   waited 28390 us
  waited 157 us
 [B][COLOR="#FF0000"]QSPI_DISK +++ Add ++++ [was 31 wrote 31] ++ D 	V	 Fail File open /D_file.txt[/COLOR][/B]
> HIT ENTER and 'BOOM" { these notes from 3rd repro of process }
I got these SUPER FAST SPEW errors:
Error: FLEXSPI2_IPRXFSTS=E0C40001
Error: FLEXSPI2_IPRXFSTS=E0C50001
Error: FLEXSPI2_IPRXFSTS=E0C60001
Error: FLEXSPI2_IPRXFSTS=E0C70001
Error: FLEXSPI2_IPRXFSTS=E0C80001
Error: FLEXSPI2_IPRXFSTS=E0C90001
Error: FLEXSPI2_IPRXFSTS=E0CA0001
Error: FLEXSPI2_IPRXFSTS=E0CB0001
Error: FLEXSPI2_IPRXFSTS=E0CC0001
Error: FLEXSPI2_IPRXFSTS=E0CD0001
Error: FLEXSPI2_IPRXFSTS=E0CE0001
Error: FLEXSPI2_IPRXFSTS=E0CF0001
Error: FLEXSPI2_IPRXFSTS=E0D00001
Error: FLEXSPI2_IPRXFSTS=E0D10001
Error: FLEXSPI2_IPRXFSTS=E0D20001
Error: FLEXSPI2_IPRXFSTS=E0D30001
Error: FLEXSPI2_IPRXFSTS=E0D40001
Error: FLEXSPI2_IPRXFSTS=E0D50001
Error: FLEXSPI2_IPRXFSTS=E0D60001
Error: FLEXSPI2_IPRXFSTS=E0D70001
Error: FLEXSPI2_IPRXFSTS=E0D80001
Error: FLEXSPI2_IPRXFSTS=E0D90001
Error: FLEXSPI2_IPRXFSTS=E0DA0001
Error: FLEXSPI2_IPRXFSTS=E0DB0001
Error: FLEXSPI2_IPRXFSTS=E0DC0001
Error: FLEXSPI2_IPRXFSTS=E0DD0001
Error: FLEXSPI2_IPRXFSTS=E0DE0001
Error: FLEXSPI2_IPRXFSTS=E0DF0001
Error: FLEXSPI2_IPRXFSTS=E0E00001
Error: FLEXSPI2_IPRXFSTS=E0E10001
Error: FLEXSPI2_IPRXFSTS=E0E20001
Error: FLEXSPI2_IPRXFSTS=E0E30001
Error: FLEXSPI2_IPRXFSTS=E0E40001
Error: FLEXSPI2_IPRXFSTS=E0E50001
Error: FLEXSPI2_IPRXFSTS=E0E60001
Error: FLEXSPI2_IPRXFSTS=E0E70001
Error: FLEXSPI2_IPRXFSTS=E0E80001
Error: FLEXSPI2_IPRXFSTS=E0E90001
Error: FLEXSPI2_IPRXFSTS=E0EA0001
Error: FLEXSPI2_IPRXFSTS=E0EB0001
Error: FLEXSPI2_IPRXFSTS=E0EC0001
Error: FLEXSPI2_IPRXFSTS=E0ED0001
Error: FLEXSPI2_IPRXFSTS=E0EE0001
Error: FLEXSPI2_IPRXFSTS=E0EF0001
Error: FLEXSPI2_IPRXFSTS=E0F00001
And similar steps:
Error: FLEXSPI2_IPRXFSTS=A7240001
Error: FLEXSPI2_IPRXFSTS=A7250001
Error: FLEXSPI2_IPRXFSTS=A7260001
Error: FLEXSPI2_IPRXFSTS=A7270001
Error: FLEXSPI2_IPRXFSTS=A7280001
Error: FLEXSPI2_IPRXFSTS=A7290001
Error: FLEXSPI2_IPRXFSTS=A72A0001
Error: FLEXSPI2_IPRXFSTS=A72B0001
Error: FLEXSPI2_IPRXFSTS=A72C0001
Error: FLEXSPI2_IPRXFSTS=A72D0001
Error: FLEXSPI2_IPRXFSTS=A72E0001
Error: FLEXSPI2_IPRXFSTS=A72F0001
Error: FLEXSPI2_IPRXFSTS=A7300001
Error: FLEXSPI2_IPRXFSTS=A7310001
Error: FLEXSPI2_IPRXFSTS=A7320001
Error: FLEXSPI2_IPRXFSTS=A7330001
Error: FLEXSPI2_IPRXFSTS=A7340001
Error: FLEXSPI2_IPRXFSTS=A7350001
Error: FLEXSPI2_IPRXFSTS=A7360001
Error: FLEXSPI2_IPRXFSTS=A7370001
Error: FLEXSPI2_IPRXFSTS=A7380001
Error: FLEXSPI2_IPRXFSTS=A7390001
Error: FLEXSPI2_IPRXFSTS=A73A0001
Error: FLEXSPI2_IPRXFSTS=A73B0001
Error: FLEXSPI2_IPRXFSTS=A73C0001
Error: FLEXSPI2_IPRXFSTS=A73D0001
Error: FLEXSPI2_IPRXFSTS=A73E0001
Error: FLEXSPI2_IPRXFSTS=A73F0001
Error: FLEXSPI2_IPRXFSTS=A7400001
And from the THIRD repro - so fast the buffer scrolls off:
Error: FLEXSPI2_IPRXFSTS=971D0001
Error: FLEXSPI2_IPRXFSTS=971E0001
Error: FLEXSPI2_IPRXFSTS=971F0001
Error: FLEXSPI2_IPRXFSTS=97200001
Error: FLEXSPI2_IPRXFSTS=97210001
Error: FLEXSPI2_IPRXFSTS=97220001
Error: FLEXSPI2_IPRXFSTS=97230001
Error: FLEXSPI2_IPRXFSTS=97240001
Error: FLEXSPI2_IPRXFSTS=97250001
Error: FLEXSPI2_IPRXFSTS=97260001
Error: FLEXSPI2_IPRXFSTS=97270001
Error: FLEXSPI2_IPRXFSTS=97280001
Error: FLEXSPI2_IPRXFSTS=97290001
Error: FLEXSPI2_IPRXFSTS=972A0001
Error: FLEXSPI2_IPRXFSTS=972B0001
Error: FLEXSPI2_IPRXFSTS=972C0001
Error: FLEXSPI2_IPRXFSTS=972D0001
Error: FLEXSPI2_IPRXFSTS=972E0001
Error: FLEXSPI2_IPRXFSTS=972F0001
Error: FLEXSPI2_IPRXFSTS=97300001
Error: FLEXSPI2_IPRXFSTS=97310001
Error: FLEXSPI2_IPRXFSTS=97320001
Error: FLEXSPI2_IPRXFSTS=97330001
Error: FLEXSPI2_IPRXFSTS=97340001
Error: FLEXSPI2_IPRXFSTS=97350001
Repro above on second T_4.1 QSPI:
'f'ormat
'1' iteration 24 times
:: /A_file.txt 	Verify /A_file.txt bytes read 404 and size 404  waited 81 us
 QSPI_DISK ----DEL------ - -- A
 0 dirs with 0 files of Size 0 Bytes
:: /B_file.txt   waited 105 us
  waited 96 us
 QSPI_DISK +++ Add ++++ [was 0 wrote 11] ++ B 	V	 Fail File open /B_file.txt
[  0.63 M] Awaiting input 0123456789rdchkfvpl? loops left 1 >
>> REPRO not identical - it does get to a 'Fail File open'
- Prior 'loops left 0' means it was complete the pass - just above it shows 'loops left 1' - meaning if not '0' Zeroed it will continue.
- this one does not go BOOM
I've committed a fix for race conditions while reading the FlexSPI IP RX FIFO. Hopefully this will cure the QSPI bugs.
https://github.com/PaulStoffregen/LittleFS/commit/8b67af45a53b26a51ea5ff1ce05f89189dcd3792
To add another little test program, I noticed the failures would sometimes cause printDirectory to omit printing 1 or more files. So I created this little test which just repeatedly prints the directory, but pauses for 5 seconds (easily visible) if the wrong number of files are found.
// Repeatedly print a list of all files, but pause if wrong number of files
// set this to the number of files previously written to QSPI
#define NUMFILES  4
#include <LittleFS.h>
LittleFS_QSPIFlash myfs;
  while (!Serial) ;
  Serial.printf("IPRXFCR = %x\n", FLEXSPI2_IPRXFCR);
  if (!myfs.begin()) {
    Serial.println("error startup");
    while (1) ;
unsigned int count = 0;
unsigned int errcount = 0;
unsigned int filecount = 0;
  Serial.print("run ");
  Serial.print(++count);
  Serial.print(", errors ");
  Serial.println(errcount);
  filecount = 0;
  printDirectory(myfs);
  if (filecount != NUMFILES) {
    errcount++;
    delay(5000);
  delay(1); // run fast, but don't overwhelm serial monitor
void printDirectory(FS &fs) {
  Serial.println("printDirectory\n--------------");
  printDirectory(fs.open("/"), 0);
void printDirectory(File dir, int numTabs) {
  while (true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
    for (uint8_t i = 0; i < numTabs; i++) {
      Serial.print('\t');
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println(" / ");
      printDirectory(entry, numTabs + 1);
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.println(entry.size(), DEC);
      filecount++;
    entry.close();
Went back to 26 Root files and 5 minutes with '1' single and a 3 'h'undred iterations the Directory Integrity on QSPI seems right.
  5.09 M] Awaiting input 0123456789rdchkfvpl? loops left 0 >l
	 Loop Count: 438 (#fileCycle=4918), Bytes read 1445136, written 455864
Commenting // ROOTONLY
Fails right away:
DISREGARD - After FORMAT the ROOT DIRS are NOT CREATED until RESTARTED ...
Well not good - let it run 10 times and had 9 errors, here's the dump (using the original T4.1 beta):
IPRXFCR = 0
QSPI flash begin
Flash ID: EF 40 18
Flash size is 16.00 Mbyte
attempting to mount existing media
success
run 1, errors 0
printDirectory
PRINTOUTPUT1.txt		628
PRINTOUTPUT2.txt		630
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 2, errors 1
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 3, errors 2
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 4, errors 3
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 5, errors 4
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 6, errors 5
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 7, errors 6
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 8, errors 7
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 9, errors 8
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
run 10, errors 9
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
Unfortunately don't have another board with flash. Have to solder another up just in case.
EDIT: not sure, but the directly listings all look correct and are the same. Must be missing something.
@Paul
I think its working at least for me it seems. I ran my MTPResponder for QSPI and turned power on and off 5 times to see what the directory structure look liked. All 5 times they were the same even the subdirectory files. which matches the printDirectory from your test sketch and what I see on SPIFlash using the test sketch I have to create files and directories.:
Check that you edited NUMFILES to 12 (since your flash chip appears to have 12 files stored).
Recounted the files - there are 13. After the change it works without error with matches what i am seeing in MTP as well
run 12319, errors 0
printDirectory
file1.txt		32
file10.txt		16
file2.txt		32
file20.txt		16
file3.txt		32
file30.txt		16
mtpindex.dat		0
structuredData /
	logger.txt		480
test1 /
	file1.txt		16
test2 /
	file2.txt		16
test3 /
	file3.txt		16
After writing the following ran the p#256 sketch on resulting disk - fails: >> EDIT >> SEE POST #267 ... after reading code ...
run 9, errors 8
printDirectory
<< BOGUS REMOVED >>
@mjs513 - I suspect your disk FORMAT is bad? That is - already has underlying disk damage?
Install posts LFSIntegrity:
> 'f'ormat
> '1' and '1'
> 'd'ir
> Upload Paul's test code
I'm running on my #2 and it is streaming by just fine:
run 371547, errors 0
printDirectory
A_file.txt		101
B_file.txt		22
C_file.txt		42
D_file.txt		31
On the #1 here :: Using new github update I have move to !ROOTONLY and it is showing GREAT ...
> Iterating over 10 directories and the Root with 26 files Add, extend, delete
> When that is done in another minute I'll post result notes and then start Paul's post #256 sketch there:
This shows it ran 26 minutes ROOT and 10 DIRS with 26 files coming and going - read 5MB and wrote 1.62MB
>> NO PROBLEMS - like RAM or SPI it is not running on QSPI
... // other 10 dirs prior
 0 dirs with 26 files of Size 4624 Bytes
FILE	A_file.txt		101
FILE	B_file.txt		22
FILE	C_file.txt		42
FILE	D_file.txt		31
FILE	E_file.txt		41
FILE	F_file.txt		102
FILE	G_file.txt		122
FILE	H_file.txt		71
FILE	I_file.txt		81
FILE	J_file.txt		182
FILE	K_file.txt		202
FILE	L_file.txt		222
FILE	M_file.txt		242
FILE	N_file.txt		262
FILE	O_file.txt		282
FILE	P_file.txt		302
FILE	Q_file.txt		322
FILE	R_file.txt		342
FILE	S_file.txt		362
FILE	T_file.txt		382
FILE	U_file.txt		402
FILE	V_file.txt		422
FILE	W_file.txt		442
FILE	X_file.txt		462
FILE	Y_file.txt		482
FILE	Z_file.txt		251
 10 dirs with 26 files of Size 6176 Bytes
 Total 286 files of Size 55248 Bytes
Bytes Used: 606208, Bytes Total:16777216
[ 23.22 M] Awaiting input 0123456789rdchkfvpl? loops left 0 >
[ 23.22 M] Awaiting input 0123456789rdchkfvpl? loops left 0 >l
	 Loop Count: 130 (#fileCycle=17484), Bytes read 5003936, written 1621272
[ 23.26 M] Awaiting input 0123456789rdchkfvpl? loops left 0 >
I'm a little concerned about the error "spew" Defragster posted in msg #255 (just minutes before I committed this race condition fix).
Those could be related to the RX FIFO race condition, or it could be a completely different bug. Very difficult to know...
JUST READING p#256 CODE - it has hardcoded :: #define NUMFILES 4
Anything but that is a FAIL - I just happen to have 4 files on the disk when I ran it on #2 - not the case with #1 with unknown number of files.
Suggest this changed code:
[B]uint32_t NUMFILES  = 4;[/B]
[B]unsigned int filecount = 0;[/B]
  while (!Serial) ;
    while (1) ;
[B]  printDirectory(myfs);
  NUMFILES = filecount;
[/B]}
  filecount = 0;
    errcount++;
    delay(5000);
  while (true) {
    if (! entry) {
      // no more files
      Serial.print('\t');
      filecount++;
    entry.close();
Indeed - that was UGLY and shocking to see ...
It only occurred in the one set of repro's and doesn't repeat as tried with latest LittleFS ....
Any chance that was a side effect of a corrupted disk directory entry with a bad entry telling it to do something out of bounds on the QSPI?
Running that LFSIntegrity on root and 10 subdirs with 26 files without verbose DIR printing so it runs a bit faster:
5 mins did a 100 iteration with no error on #2 T_4.1 w/QSPI:
[  4.42 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >l
	 Loop Count: 111 (#fileCycle=15838), Bytes read 4516416, written 1468664
Then ran about 30 '1' single iterations no problem where about 286 files are involved across root and 10 dirs.
Then turned it on 'c'ontinuous for a bit after that and with 13 minutes running no errors:
 10 dirs with 26 files of Size 5704 Bytes
[B] Total 286 files of Size 61312 Bytes
Bytes Used: 704512, Bytes Total:16777216
[/B]
[ 13.83 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >
[ 13.83 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >l
	 Loop Count: 276 (#fileCycle=35182), [B]Bytes read 10257464, written 3264696[/B]
And some time later ... another 15 minutes running:
 10 dirs with 24 files of Size 10980 Bytes
 Total 279 files of Size 131181 Bytes
Bytes Used: 1114112, Bytes Total:16777216
[ 40.01 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >
[ 40.01 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >l
	 Loop Count: 860 (#fileCycle=124027), [B]Bytes read 36534907, written 11505408[/B]
I really like the CMD UI I put in that sketch! Extended it to ad 'l' and 'm' today where 'm' makes the needed root dirs after a Format.
Oh and Teensy #1 running updated p#267 of Paul's Dir count code is doing well on 200+ files now:
Z_file.txt		251
[B]run 4241, errors 0
printDirectory[/B]
0_dir /
	A_file.txt		101
@Paul - what is with the 20 to 30 ms waits on QSPI?
Is that the processor flushing the cache or some such long operation as it waits for the needed data to save/read?
 QSPI_DISK +++ Add ++++ [was 0 wrote 111] ++ L 	Verify /L_file.txt bytes read 111 and size 111
:: /M_file.txt   waited 29376 us
  waited 369 us
  waited 372 us
  waited 372 us
  waited 372 us
  waited 229 us
  waited 27960 us
  waited 369 us
  waited 372 us
  waited 372 us
  waited 372 us
  waited 372 us
  waited 73 us
 QSPI_DISK +++ Add ++++ [was 0 wrote 121] ++ M 	Verify /M_file.txt bytes read 121 and size 121
@Paul latest change looking good from here for QSPI:
One Teensy:
Z_file.txt		251
[B]run 18787, errors 0[/B]
printDirectory
0_dir /
	A_file.txt		101
The Other with Bigger file changes in LFSIntegrity - running some part of 45 minutes and Bytes read 115,031,770, written 36,276,080:
 0 dirs with 26 files of Size 29350 Bytes
FILE	B_file.txt		1010
FILE	C_file.txt		1020
FILE	F_file.txt		1050
FILE	G_file.txt		1060
FILE	J_file.txt		1090
FILE	K_file.txt		1100
FILE	N_file.txt		1130
FILE	O_file.txt		1140
FILE	R_file.txt		1170
FILE	S_file.txt		1180
FILE	V_file.txt		1210
FILE	W_file.txt		1220
 10 dirs with 12 files of Size 13380 Bytes
 Total 100 files of Size 112980 Bytes
Bytes Used: 507904, Bytes Total:16777216
[ 47.59 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >
[ 47.59 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >l
	 Loop Count: 568 (#fileCycle=45242), Bytes read 115031770, written 36276080
That is with "BIGADD 1000" now doing "BIGADD 10000"
All well after some first loops - files are growing:
 0 dirs with 20 files of Size 257820 Bytes
FILE	A_file.txt		11200
FILE	B_file.txt		11020
FILE	C_file.txt		11040
FILE	D_file.txt		11060
FILE	E_file.txt		11080
FILE	F_file.txt		21150
FILE	G_file.txt		11120
FILE	H_file.txt		1070
FILE	I_file.txt		11160
FILE	J_file.txt		20180
FILE	K_file.txt		10100
FILE	L_file.txt		1110
FILE	O_file.txt		10140
FILE	P_file.txt		1150
FILE	U_file.txt		11400
FILE	V_file.txt		20420
FILE	W_file.txt		20440
FILE	X_file.txt		11460
FILE	Y_file.txt		11480
FILE	Z_file.txt		11500
 10 dirs with 20 files of Size 229280 Bytes
 Total 217 files of Size 3071940 Bytes
Bytes Used: 3518464, Bytes Total:16777216
[  2.67 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >
[  2.67 M] Awaiting input 0123456789rdchkfvplm? loops left 0 >l
	 Loop Count: 25 (#fileCycle=955), Bytes read 14086630, written 6958080
And 50 more cycles - files growing okay:
 10 dirs with 24 files of Size 263230 Bytes
 Total 256 files of Size 2856350 Bytes
Bytes Used: 3473408, Bytes Total:16777216
I probably need to setup another T4.1 to try out some of this stuff.
My latest order from Digikey had:
5 of the https://www.digikey.com/en/products/detail/winbond-electronics/W25N01GVZEIG-TR/7393545 (FLASH - NAND Memory IC 1Gb (128M x 8) SPI 104MHz 8-WSON (8x6))
and
5 of the
https://www.digikey.com/en/products/detail/winbond-electronics/W25Q128JVSIQ-TR/7087212 (FLASH - NOR Memory IC 128Mb (16M x 8) SPI - Quad I/O, QPI, DTR 133MHz 8-SOIC)
I am guessing for this round the later one is the better choice to wire up another T4.1... Still need to order some more PSRAM, I think I still have one... Need to use for Cameras ;)
Those are the time the flash chip takes to write a 256 byte page or erase a 4K sector. You should see very similar times for the same type of flash chip on the SPI port (if that code inside LittleFS.cpp is uncommented).
Here are the specs from Winbond's datasheet. As you can see, these chips are pretty slow for anything but reading.
As the chip ages from heavy use, you may see the wait times gradually increase. Of course, these worst case specs in the datasheet also take extreme temperature and manufacturing tolerance into account, so you're unlikely to see anything take quite that long for ordinary use at room temperature.
and
5 of the
@KurtE
Yep the later 128MB NOR flash is the one to go with. The NAND is setup for direct memory read and writes. Think Paul mentioned that it is a bit more complicated to implement: https://forum.pjrc.com/threads/58033-LittleFS-port-to-Teensy-SPIFlash?p=258762&viewfull=1#post258762 and he won't be getting to it for awhile.
