Page 3 of 38 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 51 to 75 of 941
Thread: LittleFS port to Teensy/SPIFlash
  1. #51
    New York
    7,673
    Added this test for removing directories and files. But did notice that all files have to be removed in the directory for the directory can be removed.
      //next test
      //lets make a few files and directories.
      file1 = myfs.open("file1", FILE_WRITE);
      file2 = myfs.open("file2", FILE_WRITE);
      file3 = myfs.open("file3", FILE_WRITE);
      file1.println("this is a test");
      file2.println("this is a test");
      file3.println("this is a test");
      file1.close();
      file2.close();
      file3.close();
      myfs.mkdir("test1");
      myfs.mkdir("test2");
      myfs.mkdir("test3");
      printDirectory();
      file1 = myfs.open("/test1/file1", FILE_WRITE);
      file2 = myfs.open("/test2/file2", FILE_WRITE);
      file3 = myfs.open("/test3/file3", FILE_WRITE);
      file1.close();
      file2.close();
      file3.close();
      printDirectory();
      //now lets remove them
      if(myfs.remove("/test3/file3") == true)
              Serial.println("file /test3/file3 removed!");
      if(myfs.rmdir("test3") == true)
              Serial.println("directory /test3 removed!");
      myfs.remove("/test2/file2");
      myfs.rmdir("test2");
      printDirectory();
    printDirectory
    FILE	PRINTOUTPUT1.txt		628
    FILE	PRINTOUTPUT2.txt		630
    FILE	file1		16
    FILE	file2		16
    FILE	file3		16
    DIR	structuredData /
    	FILE	logger.txt		480
    DIR	test1 /
    	FILE	file1		16
    DIR	test2 /
    	FILE	file2		16
    DIR	test3 /
    	FILE	file3		16
    printDirectory
    FILE	file1		16
    FILE	file2		16
    FILE	file3		16
    	FILE	logger.txt		480
    DIR	test1 /
    	FILE	file1		16
  2. #52
    New York
    7,673
    Sounds like you are making good progress.
    Wondering about other stressy things. I was wondering about access to multiple files at same time, which looks like you have.
    Like wondering if it is at all sort of thread safe?
    What about reading and writing to multiple files using IntervalTimers? And main sketch. Or TimerTool with different types of interrupts maybe at different priorities?
    Guess that's some more test cases. If you want to join the fray First was trying to verify the new functions.
    Then only thing haven't tested yet is seek, peek, position is in there and seems to work. Never played with those functions before so if you have a good example.
    Not sure about it being thread safe. Might wind up with some race conditions if trying to write files at the same time? But not an expert on that - usually figure it out by testing it.
  3. #53
    25,221
    I added support for SPI flash chips.
    https://github.com/PaulStoffregen/Li...2fba33f21b96db
    Or chip (singular), as only Winbond W25Q64JVSSIQ is configured so far in the list of known chips.
    You create an instance of LittleFS_SPIFlash, then call begin(csPin) or begin(csPin, port), where "port" is SPI, SPI1 or SPI2. So far SPI1 and SPI2 are untested, but theoretically they ought to work.
    Here's a test program.
    #include <LittleFS.h>
    LittleFS_RAM myfs;
    char buf[200000];
    LittleFS_SPIFlash myflash;
      pinMode(13, OUTPUT);
      digitalWrite(13, HIGH);
      while (!Serial) ; // wait
      Serial.println("LittleFS Test"); delay(5);
      if (!myfs.begin(buf, sizeof(buf))) {
        Serial.println("Error starting ramdisk");
        while (1) ;
      Serial.println("started");
      File f = myfs.open("test.txt", FILE_WRITE);
      Serial.println("opened test.txt");
      f.println("This is a test....");
      Serial.println("wrote to file");
      //f.whoami();
      f.close();
      File in = myfs.open("test.txt");
      if (in) Serial.println("opened file for read");
      char buf[256];
      int n = in.read(buf, 256);
      Serial.printf("read %d bytes\n", n);
      if (n > 255) n = 255;
      buf[n] = 0;
      Serial.println(buf);
      Serial.println("done printing, now close the file");
      in.close();
      Serial.println("try writing more");
      if (f) Serial.println("opened test.txt again for writing");
      f.println("another test");
      Serial.println("after write");
      //f.whoami();
      f.close();
      char buf2[256];
      n = in.read(buf2, 256);
      buf2[n] = 0;
      Serial.println(buf2);
      in.close();
      delay(10);
      printDirectory();
      Serial.println("create folder");
      if (myfs.mkdir("myfolder")) {
        Serial.println("  success");
        Serial.println("  failed");
      printDirectory();
      Serial.println("write to file in folder");
      f = myfs.open("/myfolder/morestuff.txt", FILE_WRITE);
      if (f) Serial.println("opened myfolder/morestuff.txt for write");
      f.println("some more text to write into 2nd file");
      f.close();
      printDirectory();
      Serial.println("**************************************\n");
      Serial.println("SPI Flash");
      if (!myflash.begin(4)) {
        Serial.println("error initializing");
        while (1) ; // stop here
      Serial.println("started ok\n");
      Serial.println("try to read a file already stored on the flash");
      in = myflash.open("test.txt");
      if (in) {
        buf[n] = 0;
        in.close();
        Serial.printf("couldn't open file - normal for virgin flash");
      printDirectoryFlash();
      Serial.println("write some more data to the file");
      f = myflash.open("test.txt", FILE_WRITE);
      if (f) {
        Serial.println("adding to file");
        f.println("adding more to the file");
        f.close();
        Serial.println("couldn't open file for writing");
      Serial.println("read the file again from the flash");
      if (in) {
        buf[n] = 0;
        in.close();
        Serial.printf("couldn't open file - not good");
    void printDirectoryFlash() {
      Serial.println("printDirectory\n--------------");
      printDirectory(myflash.open("/"), 0);
    void printDirectory() {
      printDirectory(myfs.open("/"), 0);
    void printDirectory(File dir, int numTabs) {
      //dir.whoami();
      while (true) {
        static int count = 0;
        if (++count > 20) while (1) ;
        File entry =  dir.openNextFile();
        if (! entry) {
          // no more files
          //Serial.println("**nomorefiles**");
        for (uint8_t i = 0; i < numTabs; i++) {
          Serial.print('\t');
        Serial.print(entry.name());
        if (entry.isDirectory()) {
          Serial.println(" / ");
          printDirectory(entry, numTabs + 1);
          // files have sizes, directories do not
          Serial.print("\t\t");
          Serial.println(entry.size(), DEC);
        entry.close();
    Next I'm going to work on QSPI / FlexSPI support for the memory expansion on Teensy 4.1...
  4. #54
    New York
    7,673
    WOW Paul - you are on a roll - I'm still playing with RAM disk
  5. #55
    New York
    7,673
    @KurtE - your timer test using callbacks from TimerTool example:
    #include "TeensyTimerTool.h"
    using namespace TeensyTimerTool;
    Timer t1(TCK);  // Tick-Timer does not use any hardware timer (20 32bit channels)
    Timer t2(TMR1); // First channel on TMR1 aka QUAD timer module. (TMR1 - TMR4, four 16bit channels each)
    Timer t3(GPT1); // GPT1 module (one 32bit channel per module)
    Timer t4(TMR1); // Second channel on TMR1
    LittleFS_RAM myfs;
    char buf[200000];
    File pulse200, pulse400;
    elapsedMicros my_us;
    elapsedMillis my_ms;
    elapsedMillis timer;
    // Callbacks ===================================================================================
    void callback_200()  // this callback has context, i.e. parameter
        pulse200.println(my_ms);
    void callback_400()  // this callback has context, i.e. parameter
        pulse400.println(my_us);
    void LED_ON()
        digitalWriteFast(LED_BUILTIN, HIGH); // LED On
        t4.trigger(10'000);                  // trigger t4 to switch of after 10ms
    void LED_OFF()
        digitalWriteFast(LED_BUILTIN, LOW);
      Serial.println("LittleFS Timer Test"); delay(5);
        while (1) ;
      Serial.println("create pulse200 and pulse400 files");
      pulse200 = myfs.open("pulse200.txt", FILE_WRITE);
      pulse400 = myfs.open("pulse400.txt", FILE_WRITE);
        for(unsigned pin = 0; pin <=13; pin++) pinMode(pin,OUTPUT);
        t1.beginPeriodic([] { callback_200(); }, 50'000); // 200ns pulse every 500 ms
        t2.beginPeriodic([] { callback_400(); },      100); // 400ns pulse every 100 Ás
        t3.beginPeriodic(LED_ON,    1'000'000); // Switch LED on every second
        t4.beginOneShot(LED_OFF);               // One shot timer to switch LED Off
      //dir.whoami();
      while (true) {
        static int count=0;
        if (++count > 100) while (1) ;
        if (! entry) {
          // no more files
          Serial.print('\t');
        if(entry.isDirectory()) {
          Serial.print("DIR\t");
          Serial.print("FILE\t");
        entry.close();
      if(timer > 2000) {
        pulse200.close();
        pulse400.close();
        printDirectory();
      Serial.println("PULSE200.txt dump of time");
      pulse200 = myfs.open("pulse200.txt");
      for(uint8_t i = 0; i <100; i++){
          char buf[256];
          int n = pulse200.read(buf, 256);
          buf[n] = 0;
          if(pulse200.available() == 0) break;
      pulse200.close();
      Serial.println("PULSE400.txt dump of time");
      pulse400 = myfs.open("pulse400.txt");
          char buf[256];
          int n = pulse400.read(buf, 256);
          buf[n] = 0;
          if(pulse400.available() == 0) break;
      pulse400.close();
        Serial.println("FINISHED");
        Serial.flush();
        while(1){};
    Output:
    D:\Users\Merli\Documents\Arduino\litteFS_MoreTimers_test\litteFS_MoreTimers_test.ino Nov  6 2020 09:26:00
    LittleFS Timer Test
    printDirectory
    FILE	pulse200.txt		60
    FILE	pulse400.txt		48474
    1513
    1563
    1613
    1663
    1713
    1763
    1813
    1863
    1913
    1963
    1462881
    1462980
    1463080
    1463180
    1463280
    1463380
    1463480
    1463579
    1463679
    1463779
    1463879
    1463979
    1464079
    1464179
    1464278
    1464378
    1464478
    1464578
    1464678
    1464778
    1464877
    1464977
    1465077
    1465177
    1465277
    1465377
    1465476
    1465576
    146
    676
    1465776
    1465876
    1465976
    1466075
    1466175
    1466275
    1466375
    1466475
    1466575
    1466675
    1466774
    1466874
    1466974
    1467074
    1467174
    1467274
    1467373
    1467473
    1467573
    1467673
    1467773
    1467873
    1467972
    1468072
    1468172
    1468272
    1468372
    1468472
    1468571
    1468671
    1468771
    1468871
    1468971
    1469071
    1469171
    1469270
    1469370
    1469470
    1469570
    1469670
    1469770
    1469869
    1469969
    1470069
    1470169
    1470269
    1470369
    1470468
    1470568
    1470668
    1470768
    1470868
    1470968
    1471067
    1471167
    1471267
    14
    1367
    1471467
    1471567
    1471667
    1471766
    1471866
    1471966
    1472066
    1472166
    1472266
    1472365
    1472465
    1472565
    1472665
    1472765
    1472865
    1472964
    1473064
    1473164
    1473264
    1473364
    1473464
    1473563
    1473663
    1473763
    1473863
    1473963
    1474063
    147416
    1474262
    1474362
    1474462
    1474562
    1474662
    1474762
    1474861
    1474961
    1475061
    1475161
    1475261
    1475361
    1475460
    1475560
    1475660
    1475760
    1475860
    1475960
    1476059
    1476159
    1476259
    1476359
    1476459
    1476559
    1476659
    1476758
    1476858
    1476958
    1
    77058
    1477158
    1477258
    1477357
    1477457
    1477557
    1477657
    1477757
    1477857
    1477956
    1478056
    1478156
    1478256
    1478356
    1478456
    1478555
    1478655
    1478755
    1478855
    1478955
    1479055
    1479155
    1479254
    1479354
    1479454
    1479554
    1479654
    1479754
    14798
    FINISHED
    Only prints first 100 records of each file
    on the 100ns writes it does loose data - probably too fast a fast.
  6. #56
    25,221
    I added more of the common Winbond flash chips.
  7. #57
    New York
    7,673
    Just tried it with a W25Q128JVSIM and does seem to initializing or returning any chip ID.
    SPI Flash
    flash begin
    Flash ID: 00 00 00
    error initializing
  8. #58
    15,271
    Prior '\n' hang with loop() code went to WORKING with updated LittleFS! Still RAMDISK - but using the multi Flash update code from 6AM.
    @mjs513 it should work for you now - as it was ... and below with exception.
    Did a minor Mod to write to not delete file EVERY set of 10 files so it cycles adding bytes to the files 3 times, that looked okay until printDirectory was added.
    Pulled updated @mjs513 FOX code not printing NULL, and updated loop() code is here.
    It does not (always) HANG requiring button press now - but stalls printing unless the lines #222 and #244 are commented out.
    It RUNS up to and including the first printDirectory() - then fails to continue?
    LittleFS_RAM myfs;
    char buf[200000];
    File file1, file2, file3;
    char fname[32] = "my_file1";
    int szLen = strlen( buf );
    //define a struct of various data types
    struct MYDATA_t {
    	bool data_0;
    	float data_1;
    	long data_2;
    	int data_3;
    	char data_4[32];
    //define a struct joining MYDATA_t to an array of bytes to be stored
    union MYDATA4RAM_t {
    	MYDATA_t datastruct;
    	char Packet[sizeof(MYDATA_t)];
    MYDATA4RAM_t mydata; //data to be written in memory
    MYDATA4RAM_t readdata; //data read from memory
    		while (1) ;
    	printDirectory();
    	//test of print
    	Serial.println("Using println and printf to printoutput file");
    	file1 = myfs.open("PRINTOUTPUT1.txt", FILE_WRITE);
    	Serial.println("opened PRINTOUTPUT1.txt");
    	file2 = myfs.open("PRINTOUTPUT2.txt", FILE_WRITE);
    	Serial.println("opened PRINTOUTPUT2.txt");
    	for (uint8_t i = 0; i < 10; i++) {
    		file1.println("abcdefghijklmnopqrstuvwxyz");
    		file1.printf("Rec: %d, Float: %f, Int: %d\n", i, i + 26.4, i + 98);
    		file2.println("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
    		//eRAM.println("THIS IS A TEST");
    		file2.printf("Rec: %d, Float: %f, Int: %d\n", i, i + 56.4, i + 198);
    	file1.close();
    	file2.close();
    	printDirectory();
    	Serial.println("-------------------------------");
    	Serial.println("File1 contents:");
    	file1 = myfs.open("PRINTOUTPUT1.txt");
    	Serial.printf("File1 size: %d\n", file1.size());
    	int filesize = file1.size();
    	for (uint8_t i = 0; i < 30; i++) {
    		char buf[256];
    		int n = file1.read(buf, 256);
    		//Serial.printf("read %d bytes\n", n);
    		buf[n] = 0;
    		//Used this in place of a file1.eof() function
    		//if((file1.position()+1) > filesize) break;
    		if (file1.available() == 0) break;
    	file1.close();
    	structuredWrite();
    void structuredWrite() {
    	Serial.println("File3 byte conversion test:");
    	uint32_t arraySize = sizeof(MYDATA_t);
    	//---------init data - load array
    	mydata.datastruct.data_0 = true;
    	Serial.print("Data_0: ");
    	if (mydata.datastruct.data_0) Serial.println("true");
    	if (!mydata.datastruct.data_0) Serial.println("false");
    	mydata.datastruct.data_1 = 1.3575;
    	Serial.print("Data_1: ");
    	Serial.println(mydata.datastruct.data_1, DEC);
    	mydata.datastruct.data_2 = 314159L;
    	Serial.print("Data_2: ");
    	Serial.println(mydata.datastruct.data_2, DEC);
    	mydata.datastruct.data_3 = 142;
    	Serial.print("Data_3: ");
    	Serial.println(mydata.datastruct.data_3, DEC);
    	//string test
    	String string_test = "The Quick Brown Fox";
    	int stringLen = string_test.length();
    	Serial.println(stringLen);
    	string_test.toCharArray(mydata.datastruct.data_4, stringLen + 1);
    	Serial.println(string_test);
    	Serial.println("Init Done - array loaded");
    	Serial.println("...... ...... ......");
    	if (myfs.mkdir("structuredData")) {
    	//lets try something more interesting and complicated
    	file3 = myfs.open("/structuredData/logger.txt", FILE_WRITE);
    	for (int32_t i = 0; i < 10; i++) {
    		file3.write(mydata.Packet, arraySize);
    	file3.close();
    	Serial.println("2nd Directory contents:");
    	printDirectory();
    	file3 = myfs.open("/structuredData/logger.txt");
    		//if(eRAM.f_eof(file3)) //break loop on EOF
    		//    break;
    		int n = file3.read(readdata.Packet, arraySize);
    		//---------Send data to serial
    		if (readdata.datastruct.data_0) Serial.print("true");
    		if (!readdata.datastruct.data_0) Serial.print("false");
    		Serial.print(", ");
    		Serial.print(readdata.datastruct.data_1, DEC);
    		Serial.print(", ");
    		Serial.print(readdata.datastruct.data_2, DEC);
    		Serial.print(", ");
    		Serial.print(readdata.datastruct.data_3, DEC);
    		Serial.print(", ");
    		for (uint8_t j = 0; j < stringLen; j++) {
    			Serial.print(readdata.datastruct.data_4[j]);
    		if ((file3.position() + 1) > file3.size()) break;
    		//if(file3.available() == 0) break;
    	file3.close();
    	//dir.whoami();
    	while (true) {
    		if (! entry) {
    			// no more files
    			Serial.print('\t');
    		entry.close();
    uint32_t lCnt = 0;
    uint32_t cCnt = 0;
    char szLoop[] = "#_file.txt";
    	lCnt++;
    	int ii;
    	byte nNum = lCnt % 10;
    	szLoop[0] = '0' + nNum;
    	if ( cCnt >= 3 && myfs.exists(szLoop) ) {
    		if ( nNum == 1 ) {
    			Serial.print('\n');
    		file3 = myfs.open(szLoop);
    		ii = 0;
    		char mm;
    		while ( file3.available() ) {
    			file3.read( &mm , 1 );
    			ii++;
    			if ( '@' != mm ) Serial.print( "Bad Byte!\n");
    		Serial.printf( " file %s had %u bytes\n", szLoop, ii );
    		file3.close();
    		myfs.remove(szLoop);
    	else {
    //		file3 = myfs.open(szLoop, FILE_WRITE);
    		if ( nNum == 0 ) {
    			nNum = 10;
    			cCnt++;
    			if ( cCnt >= 5 ) {
    				cCnt = 0;
    				Serial.print('\n');
    				delay(2000);
    		char mm = '@';
    		file3 = myfs.open(szLoop, FILE_WRITE); // Moving this after printDir doesn't matter
    		for ( ii = 0; ii < nNum * 100; ii++ ) {
    			file3.write( &mm , 1 );
    		file3.close();
    		Serial.print('.');
  9. #59
    9,737
    Right now I am not finding any of my flash chips, I know I have a few around here somewhere. I do have a couple on the T4.1s...
    So will do some more searching, and then may have to order some.
  10. #60
    15,271
    These are the SPI flash chips like on an Audio card correct? Any of those populated Audio boards handy Kurt?
    That reminds me I have a T_4.0 Beta Breakout with Audio w/Flash.
  11. #61
    15,271
    Though - getting FAIL using T_4.0 breakout using supplied Rev B Audio board socket with Winbond 2SQ128FVSG
    That indicates MEMCS on #6 and MOSI on pin #7
    Seeing failure with above Paul FLASH sketch:
    SPI Flash
    flash begin
    Flash ID: FF FF FF
    error initializing
  12. #62
    9,737
    I don't think so, I don't think I ever populated any of them. I did find one of the 1G flash chips I populated a T4.1 (W25NO1GVZEIG) or thereabout that was from a different thread. Not sure I want to populate with this one...
    I think there were a few others around as well.. But so far have not found them
    Thought about doing an order to PJRC... But I don't see any on the site...
    Will keep looking.
  13. #63
    15,271
    SUCCESS !!!!!
    I have Two REV D boards with that Flash - one bottom female header on a T_4.0 Top Pin:
    SPI Flash
    flash begin
    Flash ID: EF 40 18
    Flash size is 16.00 Mbyte
    attemping to mount existing media
    couldn't mount media, attemping to format
      waited 82307 us
      waited 165 us
      waited 82468 us
      waited 164 us
    attemping to mount freshly formatted media
    success
    started ok
    printDirectory
      waited 146 us
    adding to file
      waited 155 us
    printDirectory
    test.txt		25
    read 25 bytes
  14. #64
    25,221
    FWIW, I just found the 1Gbit NAND chips I bought earlier this year.
    I was reading the datasheet again this morning. While these chips do have amazing capacity, the page & sector sizes are much larger. They'll probably be much more useful for large files.
    Earlier I had planned to memory map these. Now I'm reconsidering whether that is really a good idea. Apparently 2Gbit and 4Gbit parts are on the horizon (8Gbit might be too - info isn't as clear), and we just don't have enough FlexSPI address space to support them that way. But we might be able to use the full capacity of those future chips if I write the code to use the other interface which isn't memory mapped. Difficult decisions....
  15. #65
    15,271
    Modified setup to end with :: for ( int ii=0; ii<60; ii++ ) loopTest();
    Where loopTest() is prior RAMDISK loop() code just called 60 times and modified to use "myflash."
    It worked ONCE until it did print :: printDirectoryFlash();
    BEING STATIC ( not seeing FORMAT ) ... Now it is dying running the initial PAUL code:
    printDirectory
    0_file.txt		3000
    1_file.txt		300
    2_file.txt		600
    3_file.txt		900
    4_file.txt		1200
    5_file.txt		1500
    6_file.txt		1800
    7_file.txt		2100
    8_file.txt		2400
    here is the edited code - I removed printDirectoryFlash() in loopTest() after it failed - but now it doesn't get that far:
    LittleFS_RAM myfs;
    char buf[200000];
        while (1) ;
      //f.whoami();
      f.close();
      char buf[256];
      buf[n] = 0;
      in.close();
      //f.whoami();
      f.close();
      char buf2[256];
      buf2[n] = 0;
      in.close();
      delay(10);
      printDirectory();
      printDirectory();
      f.close();
      printDirectory();
      if (!myflash.begin(6)) {
      if (in) {
        buf[n] = 0;
        in.close();
      if (f) {
        f.close();
      if (in) {
        buf[n] = 0;
        in.close();
      for ( int ii = 0; ii < 20; ii++ ) loopTest();  // EDITED THIS CODE TO REPRO FLASH dir print fail // 20 not 21 for valid counts
      Serial.printf("loopTest() COMPLETED !!!!");
      //dir.whoami();
      while (true) {
        if (! entry) {
          // no more files
          Serial.print('\t');
        entry.close();
    uint32_t lCnt = 0;
    uint32_t cCnt = 0;
    File file3;
    void loopTest() {
    	lCnt++;
    	int ii;
    	if ( cCnt >= 3 && myflash.exists(szLoop) ) {
    		if ( nNum == 1 ) {
    			Serial.print('\n');
    //  printDirectoryFlash();
    		file3 = myflash.open(szLoop);
    		ii = 0;
    		char mm;
    			ii++;
    		file3.close();
    		myflash.remove(szLoop);
    	else {
    //		file3 = myflash.open(szLoop, FILE_WRITE);
    		if ( nNum == 0 ) {
    			nNum = 10;
    			cCnt++;
    			if ( cCnt >= 5 ) {
    				cCnt = 0;
    				Serial.print('\n');
    				delay(2000);
    		char mm = '@';
    		file3 = myflash.open(szLoop, FILE_WRITE); // Moving this after printDir doesn't matter
    		file3.close();
    		Serial.print('.');
    Last edited by defragster; 11-06-2020 at 08:23 PM. Reason: EDITED CODE for 20 loopTest()'s
  16. #66
    9,737
    Actually I may have found some with Propshield. Just pulled out a new Propshield LC.. Probably need to solder some pins on it. First a quick search for ones already with pins...
  17. #67
    25,221
    I anyone wants to buy some of those 1Gbit chips, Digikey as plenty in stock for about $2 each. Part number is W25N01GVZEIGCT-ND.
    https://www.digikey.com/en/products/...EIG-TR/5803931
    These are a tight fit but can be soldered to the bottom side of Teensy 4.1. Good surface mount soldering skill is needed.
  18. #68
    9,737
    Question is this supposed to be T4.x only?
    Since I found a propshield with a T3.2, I thought I would try to compile for it... and the build fails:
    C:\Users\kurte\Documents\Arduino\libraries\LittleFS\src\LittleFS.cpp: In member function 'int LittleFS_SPIFlash::prog(lfs_block_t, lfs_off_t, const void*, lfs_size_t)':
    C:\Users\kurte\Documents\Arduino\libraries\LittleFS\src\LittleFS.cpp:158:22: error: 'delayNanoseconds' was not declared in this scope
      delayNanoseconds(250);
    C:\Users\kurte\Documents\Arduino\libraries\LittleFS\src\LittleFS.cpp: In member function 'int LittleFS_SPIFlash::erase(lfs_block_t)':
    C:\Users\kurte\Documents\Arduino\libraries\LittleFS\src\LittleFS.cpp:179:22: error: 'delayNanoseconds' was not declared in this scope
    Using library LittleFS at version 1.0.0 in folder: C:\Users\kurte\Documents\Arduino\libraries\LittleFS
    Using library SPI at version 1.0 in folder: C:\arduino-1.8.13\hardware\teensy\avr\libraries\SPI
    Error compiling for board Teensy 3.2 / 3.1.
    Will probably plug in T4. instead. But wonder
  19. #69
    15,271
    Looks like I already got 4 of those - and soldered two I just touched!
    Went back to the Audio and did a FORMAT everything - then Ran sketch post #65
    Only change {end of setup()} was this to show it finished - which it did:
      for ( int ii = 0; ii < 60; ii++ ) loopTest();
    I can now run it repeatedly without failure - BUT the early PAUL call to printDirectoryFlash(); does not show my files now???
    Flash Memory has 16777216 bytes.
    Erasing ALL Flash Memory:
      estimated wait: 40 seconds.
      Yes, full chip erase is SLOW!
    Erase completed
      actual wait: 44 seconds.
    T:\tCode\littleFS\lfsFLASHspi\lfsFLASHspi.ino Nov  6 2020 11:51:08
    LittleFS Test
    started
    opened test.txt
    wrote to file
    read 20 bytes
    This is a test....
    try writing more
    after write
    read 34 bytes
    This is a test....
    another test
    printDirectory
    test.txt		34
    create folder
      success
    printDirectory
    myfolder /
    test.txt		34
    printDirectory
    myfolder /
    	morestuff.txt		39
    test.txt		34
    SPI Flash
    flash begin
    Flash ID: EF 40 18
      waited 85736 us
      waited 165 us
      waited 81405 us
      waited 166 us
    success
    started ok
    printDirectory
      waited 146 us
    adding to file
      waited 154 us
    printDirectory
    test.txt		25
    read 25 bytes
      waited 148 us
      waited 227 us
    .  waited 148 us
      waited 325 us
    .  waited 148 us
      waited 82631 us
      waited 367 us
      waited 161 us
      waited 138 us
    .  waited 148 us
      waited 82614 us
      waited 367 us
      waited 259 us
      waited 138 us
    .  waited 147 us
      waited 82677 us
      waited 367 us
      waited 356 us
      waited 138 us
    .  waited 146 us
      waited 86135 us
      waited 367 us
      waited 367 us
      waited 204 us
      waited 138 us
    .  waited 148 us
      waited 89524 us
      waited 367 us
      waited 367 us
      waited 301 us
      waited 83168 us
      waited 364 us
      waited 367 us
      waited 165 us
    .  waited 148 us
      waited 86167 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 150 us
      waited 138 us
    .  waited 148 us
      waited 82771 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 248 us
      waited 138 us
    .  waited 147 us
      waited 82715 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 344 us
      waited 138 us
    .  waited 325 us
    .  waited 82760 us
      waited 367 us
      waited 259 us
      waited 138 us
    .  waited 82707 us
      waited 367 us
      waited 368 us
      waited 204 us
      waited 138 us
    .  waited 86188 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 151 us
      waited 138 us
    .  waited 82712 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 344 us
      waited 138 us
    .  waited 82768 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 368 us
      waited 290 us
      waited 137 us
    .  waited 82783 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 236 us
      waited 138 us
    .  waited 82754 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 181 us
      waited 81428 us
      waited 364 us
      waited 367 us
      waited 151 us
    .  waited 82776 us
      waited 367 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 127 us
      waited 137 us
    .  waited 82653 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 321 us
      waited 137 us
    .  waited 82703 us
      waited 367 us
      waited 162 us
      waited 138 us
    .  waited 82568 us
      waited 368 us
      waited 367 us
      waited 204 us
      waited 138 us
    .  waited 82657 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 247 us
      waited 138 us
    .  waited 82480 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 290 us
      waited 138 us
    .  waited 82448 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 333 us
      waited 138 us
    .  waited 86280 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 126 us
      waited 137 us
    .  waited 82714 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 170 us
      waited 138 us
    .  waited 82560 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 211 us
      waited 137 us
    .  waited 82545 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 254 us
      waited 138 us
    .  waited 82382 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 367 us
      waited 297 us
      waited 138 us
     file 1_file.txt had 300 bytes
      waited 129 us
     file 2_file.txt had 600 bytes
      waited 83127 us
      waited 364 us
      waited 163 us
     file 3_file.txt had 900 bytes
      waited 129 us
     file 4_file.txt had 1200 bytes
      waited 129 us
     file 5_file.txt had 1500 bytes
      waited 129 us
     file 6_file.txt had 1800 bytes
      waited 129 us
     file 7_file.txt had 2100 bytes
      waited 129 us
     file 8_file.txt had 2400 bytes
      waited 129 us
     file 9_file.txt had 2700 bytes
      waited 129 us
     file 0_file.txt had 3000 bytes
      waited 128 us
      waited 148 us
      waited 228 us
    .  waited 147 us
      waited 325 us
    .  waited 147 us
      waited 82296 us
      waited 367 us
      waited 161 us
      waited 138 us
    .  waited 83419 us
      waited 364 us
      waited 329 us
      waited 82071 us
      waited 367 us
      waited 259 us
      waited 85415 us
      waited 364 us
      waited 337 us
    .  waited 148 us
      waited 81996 us
      waited 367 us
      waited 356 us
      waited 138 us
    .  waited 147 us
      waited 86940 us
      waited 367 us
      waited 368 us
      waited 204 us
      waited 138 us
    .  waited 148 us
      waited 84007 us
      waited 367 us
      waited 368 us
      waited 301 us
      waited 138 us
    .  waited 148 us
      waited 83221 us
      waited 368 us
      waited 367 us
      waited 368 us
      waited 150 us
      waited 137 us
    .  waited 147 us
      waited 85406 us
      waited 368 us
      waited 367 us
      waited 368 us
      waited 247 us
      waited 137 us
    .  waited 147 us
      waited 81837 us
      waited 367 us
      waited 368 us
      waited 367 us
      waited 343 us
      waited 137 us
     file 1_file.txt had 100 bytes
      waited 129 us
     file 2_file.txt had 200 bytes
      waited 129 us
     file 3_file.txt had 300 bytes
      waited 83325 us
      waited 363 us
      waited 137 us
     file 4_file.txt had 400 bytes
      waited 128 us
     file 5_file.txt had 500 bytes
      waited 129 us
     file 6_file.txt had 600 bytes
      waited 128 us
     file 7_file.txt had 700 bytes
      waited 128 us
     file 8_file.txt had 800 bytes
      waited 129 us
     file 9_file.txt had 900 bytes
      waited 128 us
     file 0_file.txt had 1000 bytes
      waited 129 us
  20. #70
    15,271
    re post #69 - to assure loopTest had not removed the files I changed the 60 to 61 {should have made it 71 as it groups in 10} - still not present.
    So I changed end of setup() to #20 - and these sizes agree with two write iterations:
    The files are now present for sure on RESET as again the initial PAUL code hangs printing the directory as before:
    printDirectory
    0_file.txt		2000
    1_file.txt		400
    2_file.txt		400
    3_file.txt		600
    4_file.txt		800
    5_file.txt		1000
    6_file.txt		1200
    7_file.txt		1400
    8_file.txt		1600
  21. #71
    25,221
    Opps. Will fix that soon.
    I've been testing mostly on Teensy 4.1 and just focusing on getting things working rather than testing on all the boards.
  22. #72
    15,271
    I edited post #65 LittleFS-port-to-Teensy-SPIFlash
    To match the failure repro I am seeing in post #70
    I am using T_4.0 with Audio Card with 16MB winbond on myflash.begin(6)
  23. #73
    15,271
    @Paul - is there a way to manually trigger lfs_format() without doing Flash EraseEverything?
    Note - edited above to 20's for accurate file write iterations where it hangs:
    printDirectory
    0_file.txt		2000
    1_file.txt		200
    2_file.txt		400
    3_file.txt		600
    4_file.txt		800
    5_file.txt		1000
    6_file.txt		1200
    7_file.txt		1400
    8_file.txt		1600
  24. #74
    New York
    7,673
    Way back when we did get the 1GB chip working on a T4.1 with some success. You might want to check this thread out: https://forum.pjrc.com/threads/61566...highlight=nand
    The example code and lib is posted on github if you decided you want to play with it: https://github.com/PaulStoffregen/teensy41_extram (https://github.com/PaulStoffregen/te...t41/w25n01g_t4). Don't think you are going to be able to memory map this chip the way you want to anyway - chip kind of works differently.
    Now to read the other posts and see what I missed.
    Probably will solder up another breakout with a Flash chip - not sure the one I have is working anymore - checked it with SErialFlash and it does show the JEDEC but then the tests failed.
    Raw SerialFlash Hardware Test
    Read Chip Identification:
      JEDEC ID:     EF 70 18
      Part Nummber: (unknown chip)
      Memory Size:  16777216 bytes
      Block Size:   65536 bytes
    Reading Chip...
      Previous data found at address 16384
      You must fully erase the chip before this test
      found this: 00 00 00 00 15 F5 95 4B
         correct: 00 00 40 00 D5 5A F7 CA
    Tests Failed  :{
  25. #75
    9,737
    Quick FYI - The flash worked for the Prop shield:
    LittleFS Test
    flash begin
    Flash ID: EF 40 17
    Flash size is 8.00 Mbyte
      waited 44089 us
      waited 185 us
      waited 50385 us
      waited 185 us
    success
    started
      waited 164 us
    opened test.txt
    wrote to file
      waited 168 us
    read 20 bytes
    This is a test....
    try writing more
    after write
      File    this=2006fdbc, f=202036f8
      LittleFSFile this=202036f8, refcount=1
      waited 183 us
    read 34 bytes
    This is a test....
    another test
    printDirectory
    test.txt		34
    create folder
      waited 46844 us
      waited 145 us
      waited 184 us
      success
    printDirectory
    myfolder /
    test.txt		34
      waited 169 us
      waited 188 us
    printDirectory
    myfolder /
    	morestuff.txt		39
    test.txt		34
    Not sure if I edited out all of he extra lines or not But worked...
    Wondering can we read those flash chips soldered to bottom of T4.1 using SPI?
    Something like: if (!myfs.begin(51, SPI2)) ?
Tags for this Thread
