Page 34 of 38 FirstFirst ... 24 32 33 34 35 36 ... LastLast
Results 826 to 850 of 940
Thread: LittleFS port to Teensy/SPIFlash
  1. #826
    14,492
    Yes - two copies - one in prior LFS and one added to the NAND code.
    Not all media uses it : FRAM, RAM, PROGRAM. RAM is a NOP - not sure about FRAM to just write may take less time to just write blank on request, without wasting time to read first. As for Program - that is controlled down level in the called code to ignore erase when not needed - and seems hyper efficient/fast.
    Would be good to have knowledge of all the format requests (not called by formatUnused but LFS itself) for invalidating a cached LFS Used Traverse list since building that list can be time costly. But that gets to be invasive - and some media 'format' isn't in same class to share a common class variable on the low level using the 'static_erase' I found months back. Working through that would be invasive and still not sure if that is a welcome set of changes to get the job done? Perhaps the formatUnused could just have a way to be void on 'those' media and let them fend for themselves? It almost isn't worth it on NAND with FAST format and large media capacity that takes longer to scan numerous files/dirs they can hold. Though they are better served by the early exit blockIsBlank() { exits are single config->read_size verify in each erase block } that doesn't have to read 256MB to see the media is formatted { they check only 2048 for each 131072 erase block - a 64X speedup }
    Question: Is there any other reasonable use case that should be added to test in LFSIntegrity?
    > like writes on an interrupt to a file - that could likely re-enter and probably bad form as the time taken is 'unknown/long'. Better to cache data and write in loop()?
    > and other common interfaces beyond open, write, close, delete, dir, disk space?
    ->> Doesn't do any RANDOM seek writes?
  2. #827
    14,492
    @mjs513 ... TD 1.54 b7 came out with OLD LittleFS in place.
    Is the current github.com/Defragster/LFSintegrity up to date for a complete pull to PJRC github.com/PaulStoffregen/LittleFS
    I need to put it back here - the older LFSIntegrity wasn't ideal before ... fixed that and added more.
  3. #828
    14,492
    @mjs513 ...
    Made a github.com/PaulStoffregen/LittleFS/pull/8 to update from this fork: github.com/Defragster/LittleFS
  4. #829
    7,225
    Ok cool was just looking at this now - so now don't have to. Do have to so some testing with the changes though in MTP and standalone
  5. #830
    14,492
    Awesome. Let me know if anything changes - the git.LFSIntegrity should match? We can manage any updates but that helps formatUnused look useful and improves/updates LFSIntegrity.ino.
  6. #831
    14,492
    PR prepped to update with latest and LFSIntegrity got pulled into PJRC tree. Copied those files to git.defragster\lfsintegrity so they match now for changes going forward.
  7. #832
    14,492
    WOW - 5 weeks since last post ...
    @Paul and @mjs513: QSPI 256MB / 2Mb NAND Flash seems to work!
    >> Paul this is freshly soldered from last package with the DIY T_4.1 bootloader chip (Argh - PCB already pinned soldering a WSON - it works no burns)
    >> Also soldered new 8MB PSRAM to same and it works
    Some LFSIntergrity commands to disk - "B":create big file half the size of Media, "b":Verify and Delete big file
    :: /X_file.txt  QSPI_NAND +++ Add [sz 0 add 6300] @KB/sec 546.78 {94.18}  ++ X   Verify /X_file.txt 6300B  @KB/sec 527.46
    :: /Y_file.txt  QSPI_NAND +++ Add [sz 0 add 6400] @KB/sec 557.05 {89.71}  ++ Y   Verify /Y_file.txt 6400B  @KB/sec 518.60
     myfs.formatUnused( 0 ) ...
    	 formatUnused :: Done Formatting Low Level in 266725 us.
    Start Big write of 130920448 Bytes..... // deleted a lot of dots ....
    Big write /0_bigfile.txt took 47.47 Sec for 130918400 Bytes : file3.size()=130918400
    	Big write KBytes per second 2757.89
    Bytes Used: 134348800, Bytes Total:265289728
    Delete with read verify all #bigfile's
    	Verify /0_bigfile.txt bytes 130918400 : ..................................................	GOOD! >>  bytes 130918400
    	Big read&compare KBytes per second 2475.46
    	 formatUnused :: Done Formatting Low Level in 3234789 us.
    And the PSRAM for speed compare:
    Start Big write of 4141056 Bytes..................................................
    Big write /0_bigfile.txt took  0.96 Sec for 4139008 Bytes : file3.size()=4139008
    	Big write KBytes per second 4296.76
    Bytes Used: 4220928, Bytes Total:8388608
    	Verify /0_bigfile.txt bytes 4139008 : ..................................................	GOOD! >>  bytes 4139008
    	Big read&compare KBytes per second 2315.14
  8. #833
    7,225
    @defragster
    Glad that it worked out of the box. QSPI for that chip was a best guess based on the SPI version and the other QSPI chips.
  9. #834
    14,492
    @defragster
    Me too - you did good , didn't see it had been tested with that (pre-release?) 2Mb variant Paul got so just hooked it up. It has been on my mind to see it run so requested one.
  10. #835
    14,492
    Minor edit to LFSIntegrity to HALT on failed myfs.begin() :: github.com/PaulStoffregen/LittleFS/pull/11
    - just got two T_4.1's mixed up and failed to catch the passing NAND and NOR fail notice on QSPI
  11. #836
    14,492
    Just edited @mjs513 post #4
    Added github link to github/littlefs
    Copied out the //known chips for reference used on T_4.1
  12. #837
    14,492
    Anyone looking for File System support on Teensy FLASH chips note that LittleFS is included in pjrc.com/threads/67252-Teensyduino-1-54-Beta-9
    Using that version has the needed libraries to have it work.
    It seems two other users have found it to work on this thread : pjrc.com/threads/61979-Teensy-4-1-external-flash-memory-question
    Any issues or notes posted here will be with the 34 pages of work on LittleFS.
  13. #838
    May 2015
    USA
    1,005
    Lots of minor warnings from "cppcheck --enable=all --inconclusive", but these might be an issue:
    [lfs.c:1975]: (error, inconclusive) Address of local auto-variable assigned to a function parameter.
    [lfs.c:3199]: (error, inconclusive) Address of local auto-variable assigned to a function parameter.
    [lfs.c:3320]: (error, inconclusive) Address of local auto-variable assigned to a function parameter.
  14. #839
    14,492
    Indeed it is:
    int lfs_mkdir(lfs_t *lfs, const char *path) {
        LFS_TRACE("lfs_mkdir(%p, \"%s\")", (void*)lfs, path);
        // deorphan if we haven't yet, needed at most once after poweron
        int err = lfs_fs_forceconsistency(lfs);
        if (err) {
            LFS_TRACE("lfs_mkdir -> %d", err);
            return err;
        struct lfs_mlist cwd;
            lfs->mlist = &cwd;
    int lfs_remove(lfs_t *lfs, const char *path) {
        struct lfs_mlist dir;
            lfs->mlist = &dir;
    int lfs_rename(lfs_t *lfs, const char *oldpath, const char *newpath) {
        struct lfs_mlist prevdir;
            lfs->mlist = &prevdir;
  15. #840
    Is QSPIFlash in LittleFS on a T4.1 dependent on any of the standard GPIO pins?
    I got the 64mb external flash chip (W25Q512JV) working like a boss, using the 1.54 beta #9 and the included example files. I exercised a test sketch hundreds of times to write, read, delete, read directories, and lots more. Then I soldered my T4.1 into a custom PCB that is using a dozen GPIO pins, analog inputs, and I2C and the stand-alone flash sketch now fails to start spidisk. I suspect it is because QSPI is using or dependent on some of the GPIO pins I am using for other I/O, but I can't find a reference (although I was getting close with a reference to pins 35, 36, and 37). I don't have any reason to believe that the chip was damaged or altered when I transferred the T4.1 to the PCB, but that is also a possibility (low likelihood). I suspect I have a GPIO conflict.
    Thanks for any direction or advice.
    -Mike
  16. #841
    14,492
    Quote Originally Posted by TeensyDigital View Post
    No, the QSPI pins are unique and routed only to those pads from MCU specific hardware that does the QSPI control. They are valid pins for other use { when not using them as QSPI, except the 'other' CS pin if only one pad set is used }, but they are not common to anything else.
    The updated T_4.1 card shown here pjrc.com/store/teensy41.html#pins gives the pin reference for those pads.
    > Any software change to function or use of pins #48 to #54 could interfere with QSPI.
    -Mike
    Not sure if this is a typo or the problem as it should be QSPI not SPI :: " start spidisk "
    If it worked before: only damage, flux uncleaned from pads, added solder or something else directly interfering with the chip would be expected to cause any failure.
    It has been tested in some variety of connections with other bus and device use.
    Suggest going back to the minimal working sketch/state and confirm function as possible.
    Then add minimally to seeing a point of failure and examine or post code so the hardware and software can be considered.
  17. #842
    Thanks @defragster for the quick reply.
    That is a typo. A left over error statement from the original example code. My sketch is using "LittleFS_QSPIFlash myfs". In the library it fails almost immediately in the "LittleFS_QSPIFlash::begin()" function. The flash ID returns FF FF FF and so the chip info returns false.
    The sketch I am using is my very stripped down flash test sketch that worked over a hundred times without any other code modifications or library mods, when the Teensy was stand-alone. My SMD soldering skills are usually solid, using 20X magnification, but that 64mb chip (with pins already on the Teensy), doesn't have a lot of room to maneuver, so it is possible something shifted when mounting to the PCB. Unfortunately, after soldering the Teensy down to the PCB, there aren't a lot of options for rework of the flash chip. All the voltages check-out and I have a dozen other components on the board working well when testing with different sketches on the Teensy (I2C, Serial, etc.). I'll keep troubleshooting. As a last resort I might try (very carefully) getting under the Teensy with rework heat on the flash chip.
  18. #843
    A quick update... I gave my whole board a CRC electronics cleaner bath, including an underbody car wash for the Teensy, followed by compressed air, and the worlds tiniest toothbrush scrub around the flash chip. I reconnected to power and my flash sketch works flawlessly. So, my issue was definitely hardware (solder, flux, poor pcb hygiene) and not related to GPIOs or code. I am now proceeding to rock on.
  19. #844
    14,492
    That is Awesome news - I 90% alcohol toothbrush mine before trusting them - then a quick hairdryer blow dry as much as my hand can stand a few rotations.
    Not the first to report error from "flux uncleaned from pads" and then needing better cleaning to work - might have been a loose solder bit ...
    The last one I soldered was pre-Pinned and and managed a PSRAM with legs and a WSON FLASH without. And at least another dozen chips on some half dozen boards in various combos that all managed to work. I found a solder paste that I can work with - didn't use that once and on inspection had lots of solder stalagmites until redone with paste to pretty shiny spots.
  20. #845
    Yep. If anyone else is planning on using the 64mb flash chip (W25Q512JV), I'd highly suggest attaching it on a Teensy board without header pins and add your header pins once you've cleaned and tested it. It is a very tight fit. The chip could be set with rework heat, but there is too much going on the reverse side of the Teensy board for me to chance using heat -- hand soldering seems the way to go. Also, this chip requires a small square of capstan tape on the bottom pad, otherwise it will short the chip pins. Use caution when cleaning (air or alcohol), so you don't dislodge the insulating tape. Besides those caveats, this little 64mb flash chip on the T4.1 is perfect.
  21. #846
    14,492
    PR made for LittleFS to reMount RAM disks that survive a Warm Restart
    From thread : pjrc.com/threads/67500-Another-PSRAM-option-Lyontek
    This :: github.com/PaulStoffregen/LittleFS/pull/12
    >> Note PR was merged as this post was saved - so look for this in TD 1.54 Beta 10 and after.
    Came about when warm restart testing showed that RAM media was always WIPED with memset on .begin().
    When LittleFS_RAM using RAM2MAMEM or PSRAM and power is maintained across a Warm Restart those memory areas ( except in unseen worst case interruption perhaps ) will hold their contents on setup() reentry.
    Code was changed to attempt mount ( like of the FLASH (MRAM) media ) and if that succeeds then no format is performed.
    Some notes from above ref thread - this is before RAM1 was excluded from dcache_flush as it done in the Pull Request linked above.
    Thanks, Might have been browser spasm here - was typing a reply and 'focus' was not in the post area ... may have tabbed back and had focus on that check box ... opps.
    Tested against RAM2 :: DMAMEM char buf[490000];
    Again generally works - except without 'file *' flush the lfs core hasn't updated the DIR entry it seems and file size on 'B'igfile write is not correct and LFSIntegrity catches an error.
    LFSIntegrity was not doing ANY FLUSH( file ) - perhaps it should have been - though it is clear when data is not flushed errors are detected.
    Using the obvious seeming FLUSH() was a fail ...
    >> FIXED ?????
    Making a change like this seems to be working with no added code on user part as this is called by the lfs core code as needed, even across a 'Hardware' driven reset with TyComm/Reset:
    class LittleFS_RAM : public LittleFS
    private:
    	static int static_sync(const struct lfs_config *c) {
    		Serial.printf("    arm_dcache_flush_delete: ptr=0x%x, size=%d\n", c->context, c->block_count * c->block_size);
    		arm_dcache_flush_delete(c->context, c->block_count * c->block_size );
    		return 0;
    Here is above code showing the PRINT on creating a BigFile - tested an DMAMEM and here on PSRAM:
     RAM_DISK +++ Add [sz 0 add 5120] @KB/sec 800.38 {524.81}  ++ I   Verify /I_file.txt 5120B  @KB/sec 2348.62
    :: /J_file.txt     arm_dcache_flush_delete: ptr=0x70000000, size=8388608
     RAM_DISK +++ Add [sz 0 add 5632] @KB/sec 920.86 {595.41}  ++ J   Verify /J_file.txt 5632B  @KB/sec 2321.52
    :: /A_file.txt     arm_dcache_flush_delete: ptr=0x70000000, size=8388608
     RAM_DISK +++ Add [sz 0 add 6144] @KB/sec 954.48 {624.77}  ++ A   Verify /A_file.txt 6144B  @KB/sec 2308.04
    [  0.10 M](0.01127 M elap) Awaiting input 0123456789RdwcghkFqvplmusSBbyYxfan+-? loops left 0 >
    Start Big write of 4147200 Bytes    arm_dcache_flush_delete: ptr=0x70000000, size=8388608
    ..................................................    arm_dcache_flush_delete: ptr=0x70000000, size=8388608
    Big write /0_bigfile.txt took  0.97 Sec for 4145152 Bytes : file3.size()=4145152
    	Big write KBytes per second 4267.55
    Bytes Used: 4214784, Bytes Total:8388608
    NOTE: In the event a sketch NEVER wants to mount and use prior LittleFS_RAM image in setup() after myfs.begin() do a format:
    myfs.quickFormat();
    or
    myfs.lowLevelFormat();
  22. #847
    24,497
    Looks like LittleFS_Program is only working on Teensy 4.1 but crashes on Teensy 4.0.
  23. #848
    14,492
    Won't work here either with RAM that fits or DMAMEM???
    Not sure when a T_4.0 may have been tested last?
    With 1.9MB free on FLASH it won't run with a 1MB LittleFS_Program either?
  24. #849
    7,225
    Yep it sure is crashing on T4.0. Even if I revert the changes that @defragster just made it crashes.. Testing with DMAMEM for a quick and dirty test.
  25. #850
    7,225
    @PaulStoffregen - @defragster
    Ran it on a T3.5 with
    DMAMEM char buf[49000];;  // USE DMAMEM for more memory than ITCM allows - or remove
    and my last posted test program and it seems to be working - no hangs!
    LittleFS Test
    TotalSize (Bytes): 48896
    started
    printDirectory
     0 dirs with 0 files of Size 0 Bytes
    MAKE files
    printDirectory
    DIR	structureData1 /
     1 dirs with 0 files of Size 0 Bytes
    printDirectory
    	FILE	temp_test.txt		19
     0 dirs with 1 files of Size 19 Bytes
    FILE	temp_test1.txt		19
    FILE	temp_test2.txt		19
    FILE	temp_test3.txt		1024
     1 dirs with 3 files of Size 1062 Bytes
    Disk Usuage:
    Bytes Used: 2816, Bytes Total:48896
    Test for SOME DATA TO TEST
Tags for this Thread
