TeensyStep - changing target while running
WildFire
New member
i am trying to change the target using setTargetAbs and then tell the controller to change controller.moveAsync(motor).
when i do this the motor stops and starts again with acceleration.
i would like it to keep running and go to the new target.
if the target is the other way i want the motor to slowdown then change direction and accelerate again.
is there someting i did not find. or is it not teensystep?
Thanks in advance
This is the current test I've written keeping track of the position myself using RotateControl instead of StepperControl. It works, but I'm not really happy with it.
#include "Arduino.h"
#include "TeensyStep.h"
constexpr unsigned motorStpPerRev = 200 * 16;            // e.g. fullstep/rev * microstepping
constexpr unsigned motorAcceleration = 15000;
float targetMotorSpeed, oldMotorSpeed;
int motorTargetPosition = 0;
int motorTargetDirection = 2; // 0 == up 1 == down 2 == none
int prevMotorPosition = 0;
constexpr unsigned maxSpeed = 1000;
RotateControl controller;
Stepper motor(4, 5);
  while(!Serial) {
  motor.setMaxSpeed(1);   // -> parameter of overrideSpeed equals real speed
  motor.setAcceleration(motorAcceleration);
  // startup controller
  controller.rotateAsync(motor);
  controller.overrideSpeed(0.0f);
//  setMotorTarget(-4000);
void setMotorTarget(int t) {
  motorTargetPosition = t;
  if(t > motor.getPosition()) {
    motorTargetDirection = 0;
  } else if(t < motor.getPosition()){
    motorTargetDirection = 1;
    motorTargetDirection = 2; //none
  int p = motor.getPosition();
  int pp = prevMotorPosition;
  int t = motorTargetPosition;
  if(motorTargetDirection == 0) {
    // we go up
    setMotorSpeed(maxSpeed);//up
    if(p > t) motorTargetDirection = 2;
  } else if(motorTargetDirection == 1){
    // we go down
    setMotorSpeed(-maxSpeed);//down
    if(p < t) motorTargetDirection = 2;
    // nowhere
    setMotorSpeed(0);
  prevMotorPosition = p;
  updateSpeeds();
  int sinT = sin(millis()*0.0001)*9000; // send it a changing target (sine wave for testing)
  setMotorTarget(sinT);
void setMotorSpeed(float rpm)
    targetMotorSpeed = rpm / 60.0f * motorStpPerRev;
void updateSpeeds()
    if(targetMotorSpeed != oldMotorSpeed)  // if target speed changed -> update all
        oldMotorSpeed = targetMotorSpeed;
        controller.overrideSpeed(targetMotorSpeed);
inline int getCurMotorSpeed() { return controller.isRunning() ? controller.getCurrentSpeed() : 0; }
