Results 1 to 8 of 8
Thread: Flexcan - what does this line do?
    Sep 2019
    UK
    22
    I'm trying to learn some of the Flexcan features and would like to understand what this line in the global section actually does in laymans terms.
    static CAN_message_t msg;
    It is sometimes as above and sometimes ends msg, rxmsg;. What does the extra rxmsg do?
    Dec 2016
    Montreal, Canada
    3,267
    Receive message, its just a struct with the id, data, etc
    Sep 2019
    UK
    22
    Thanks, but it's still a little over my head. Can you explain 'struct' to me?
    Dec 2016
    Montreal, Canada
    3,267
    Its basically like a container that has multiple variables.
    As an example above, these work:
    msg.id;
    msg.buf[0];
    msg.flags.extended,
    Sep 2019
    UK
    22
    Ok thanks, so presumably if you had inMsg in you struct you'd use inMsg.id; etc.
    Why might you need two containers such as msg, rxmsg then
    Jan 2015
    UK
    106
    Quote Originally Posted by keith-i View Post
    msg use in transmit function.
    rxmsg use in receive function.
    Sep 2019
    UK
    22
    So does it matter what name you use or is it just rxmsg to help recognise it as a receive function. Could you say use txmsg instead of msg?
    Dec 2016
    Montreal, Canada
    3,267
    Name can be anything you want it to be, like a variable, yeah
    Txmsg is an example to let you know its a transmit message
