Results 1 to 2 of 2
Thread: Teensy 4.0 Locks up sending udp
    Teensy 4.0 with w5500 ethernet freezes when you call sendPacket using UDP:
    #include <Ethernet.h>
    #include <EthernetUdp.h>
    byte g_mac[] = {
      0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 42
    IPAddress g_ip(10, 1, 10, 42);
    IPAddress g_clientIP(10, 1, 10, 10);
    unsigned int g_clientPort = 1337;
    EthernetUDP g_UDP;
    typedef struct
      char startChar = 'd';
      byte packetNumber = 0;
      uint16_t frameNumber = 0;
      uint16_t dataSize;
      uint16_t dataOffset;
    } dataPacket;
    dataPacket g_header;
    byte data[1024] = {127};
      while (!Serial)
      Ethernet.begin(g_mac, g_ip);
      //Ethernet.setRetransmissionCount(0);
      //Ethernet.setRetransmissionTimeout(10);
      Serial.println(Ethernet.linkStatus());
      Serial.println(Ethernet.hardwareStatus());
      int next = millis() + 1000;
      int success = 0;
      do
        success = g_UDP.beginPacket(g_clientIP, g_clientPort);
         Serial.print(".");
        //beginPacket fails if remote ethaddr is unknown. In this case an
        //arp-request is send out first and beginPacket succeeds as soon
        //the arp-response is received.
      while (!success && ((signed long)(millis() - next)) < 0);
      success = g_UDP.write((byte*)&g_header, sizeof(dataPacket));
      Serial.print("bytes written: ");
      Serial.println(success);
      success = g_UDP.write((byte*)data, 1024);
      success = g_UDP.endPacket(); //<< never returns
      if (success)Serial.print("sent!");
    2,496
    at the end of setup add g_UDP.begin(8888);
    see https://www.arduino.cc/en/Reference/EthernetUDPBegin
    try/study one of the UDP examples in the Ethernet library
