I want to directly access timer-registers on the teensy36. If I remove the two lines showHex(...) the program runs (prints every 0.5 seconds a ever increasing number).
If I want to access then _SC registers the call: showHex("TPM1_SC",TPM1_SC) ; works (prints a result). But if I use showHex("TPM2_SC",TPM2_SC) ; the program gets stuck (does not reach the line Serial.println("here 1"); ).
What do I make wrong. How can I access the timer registers ? Wich timer is used by FrequencyTimer2 ?
int led = 13;
#include <FrequencyTimer2.h>
void showHex(char *name,int val){
char helpString[32] ;
sprintf(helpString,"%s = %08XH =%8dd \n",name,val,val) ;
Serial.print(helpString) ;
pinMode(led, OUTPUT);
Serial.println("start...");
FrequencyTimer2::setOnOverflow(InterruptCode);
FrequencyTimer2::setPeriod(500000);
int intCount = 0;
int outCount=0 ;
void InterruptCode(void) {
intCount++;
digitalWrite( led, digitalRead( led ) ^ 1 );
Serial.print(" ");
Serial.print(intCount);
outCount++ ;
if(outCount>20){ outCount=0 ; Serial.println("//") ; }
