Results 1 to 7 of 7
Thread: qc of boards with teensy bootloader - bring RTC clock to a digital output
    Oct 2019
    4
    I have a client using your teensy bootloader ICs on their hardware.
    Im writing QC procedures, and want their pcb stuffer to QC boards.
    I need to verify the correct operation of the 16MHz and 32K RTC clock the scopes that the suppliers will overload the Clks, so I wish to bring these clocks straight through onto a pair of spare pins and run a very basic QC sketch program for hardware verification.
    I just used the PWM function(analog write) to confirm correct frequency of the 16Mhz, divided by 32k of course to 488.25hz.
    Is there a convenient code example of how to bring the 32K RTC clock out, even if divide, preferably by an integer, so it can be probed?
    It should be known im a hardware guy thru & thru, minimal SW/FW ability...
    B.
    20,688
    I believe I sent you an email reply with:
    Look at CLKOUTSEL in the SIM_SOPT2 register, and the ALT5 mux setting for PORTC_PCR3, pin PTC3 (or Arduino pin 9).
    To expand on that just a bit more, if you write to SIM_SOPT2 to select the 32 kHz clock, and put PTC3's mux into ALT5 mode, you should get a 32 kHz square wave on pin 9 (PTC3) directly from the on-chip oscillator.
    Oct 2019
    4
    thanks Paul,
    ill give it a go now,
    B.
    Oct 2019
    4
    hi all,
    this sounds like writing in assembly many years ago for pic's..
    but how do i do this in the arduino enviroment? can anyone give me an example of code where control bits of configuration registers are setup?
    i had a dig, but i couldn't find any examples in the arduino IDE..
    B: confused:.
    2,367
    As you asked for special feature, you may have to write it yourself
    I assume you wanted code for T3.x and not T4
    So, I checked kinetis.h, the k66 manual and some other core samples and
     SIM_SOPT2 |=  SIM_SOPT2_CLKOUTSEL(5);
     CORE_PIN9_CONFIG  = PORT_PCR_MUX(5);
    20,688
    Yes, that's pretty much it. But that 3 bit field needs to be cleared to zeros before the logical or.
    I ran this on a Teensy 3.5 and saw a 32.768 kHz square wave on pin 9.
      SIM_SOPT2 &= ~SIM_SOPT2_CLKOUTSEL(7);
    Oct 2019
    4
    from the K64 Sub-Family Reference Manual, Rev. 3, July 2017, and considering im using the 144 pin LQFP device, not the 144 pin BGA:
    RTC_CLKOUT is available on PIN 1 (PTE0) in ALT 7 mode, and PIN 47 (PTE26) in ALT mode 6.
    a bit of bodging, since ard' pins are defined for a 144pin BGA, this worked spitting out 32K to LQFP pin 47.... note my amazing C skills to set RTC clock to not 1hz, but the orignal 32k..
    // since a
    //SIM_SOPT2 |= SIM_SOPT2_CLKOUTSEL(5);
    SIM_SOPT2 = 0x00b0;
    CORE_PIN24_CONFIG = PORT_PCR_MUX(6); // comes out on LQFP pin 47... see pinlist...
    thanks all for your help!
