Results 1 to 5 of 5
Thread: MMAP an external SPI device on the T4.0
    I am currently experimenting with PSRAM on the Teensy 4.0.
    I finally got an IPS6404 (8MB RAM) working on the SPI2 bus of the Teensy4.0.
    Speed can still be improved but I am not using DMA transfer nor QUAD SPI yet.
    Anyhow...
    This kind of device is only useful for me if I can MMAP the device to a part of the memory map. I currently have a read() and a write() function that handle the paging/caching into real memory but I would like to be able to use pointers to that memory that I can use from C directly without having to call my read/write function.
    Is there an example on how to do this.
    Is there a memory space that can be used to address 8MB?
    Oct 2016
    18
    Sorry, cant help with the question, but would like to try out the PSRAM chips. Did you get them from Electrodragon ? if so were there package ok for MSL3 ? I am in the uk and imagine they will take some time to arrive. Also would you mind share the code you have so far ?
    Thanks and Regards
    I bought them at Electrodragon.
    https://www.electrodragon.com/produc...s6404-iot-ram/
    The SMD package 3.3v version.
    I am from Belgium. It took 2-3 weeks.
    I ordered 8 and I got something like twice as much.
    I started to use it for my emulator project (https://github.com/Jean-MarcHarvengt/MCUME) but I cannot make it work as fast as it should. I made a driver that can cache few pages. It runs roughly half what it should on the T4
    I am not using Quad SPI yet.
    I will publish the 1st emulator using it with pictures later this W-E.
    Oct 2016
    18
    Many thanks for the info. Just wondering did you have any trouble with Moisture Sensitivity Level ? Did you have to bake them or just careful hand soldering ?
    Great work by the way on your emulators!
    I am not an expert of SMD soldering but I managed to solder it without any problem. I use flux. It helps a lot for me as I don't have specific equipment for SMD. No issue with MSL also.
    The PC engine emulator has been added by the way.
    See code and video at https://github.com/Jean-MarcHarvengt/MCUME
