Results 1 to 12 of 12
Thread: Tensey 4.0 + Pi-4 Home Automation Perimeter Monitoring ....
    Oct 2019
    Arizona
    8
    Seems like a good solution. Quiet possibly 'way' overkill. ...
    Tensey 4.0 for control of FLIR and associated. Data to Pi-4
    Pi-4 for post processing engine and reporting via hardwired Ethernet or Wifi.
    Thoughts?
    Oct 2019
    Arizona
    8
    1st Q, 5V drive strength from Pi-4 to power Teesny 4.0. Assumption typical 500mA from USB, ... :/ ... Then how much required from Teensy4.0?
    Correction. ... https://cdn.sparkfun.com/assets/e/b/..._Datasheet.pdf
    Oct 2019
    Arizona
    8
    Current requirements of Tensey 4.0? .. And where is the 50mA fuse located on the PCB?.... hmmm what are the 5V current draw requirements?
    Oct 2019
    Arizona
    8
    Okay mistyped, 500mA. So connecting to the PI-4 USB did work. Saw your blinking Amber LED. Need to follow the remaining instructions
    10,937
    PJRC Teensy 4 page specs the current at approx. 100 mA at startup.
    Oct 2019
    Arizona
    8
    Awesome, 100mA, much appreciated ...
    Okay now i need help. Have Arduino on both Win10 and PI-4 Linux distro. Both at the most recent version of Arduino. Have not used Arduino. Am a old command line or Eclipse dev user for C lvl development. ... So therefore am an Arduino neo-fit. ... Seems like all the stuff may be there with the udev rules for linux, not sure yet.
    Any hints?
    Also, 4.0 is ARM based not AVR based, so different tool chain ... etc. Correct?
    10,937
    Yes, All Teensy 3.x, LC and 4.0 are ARM core processors - not AVR. Installing TeensyDuino gives the toolchain needed and updates the Arduino IDE to connect and build. There is an rPi build too.
    Oct 2019
    Arizona
    8
    Okay had to ... File->Sketchbook->Digital->Blink menu ==>> File->Examples->0.1 Basics->Blink ... is this the correct code for the T-4.0? What should it be mod'd to to test?
    rPi build? ... nm ... smacks head Ras Pi ..
    Oct 2019
    Arizona
    8
    Any thoughts of adding FreeRTOS or NuttX?
    10,937
    Quote Originally Posted by EM1SSNuke View Post
    All the general examples - except perhaps for hardware not yet ported - run as written - or in some cases as noted or adjusted within the example.
    Blink will just run - selecte Teensy 4 as the board and Upload and modify as desired.
    No specific PJRC plans to port any RTOS - there is a TeensyThreads that allows task switching - and other posters may have ports underway
    Oct 2019
    Arizona
    8
    Looking for a SPI example with interrupts. ... ? Does one exist in the Arduino package from T-4?
    Sep 2019
    Essex, UK
    8
    Take a look at https://github.com/sumotoy/gpio_expander - I have used that library with multiple MCP23S17 GPIO expanders on a T4 using interrupts to trigger reads from 112 end points. Originally wrote code in python running on a Pi to do this, but on a T4 it's 1000 times faster
