kallaballa
New member
I'm trying to create a scripting environment running on the teensy 4.0 based on https://github.com/TonicAudio/Tonic, https://github.com/AnthonyDiGirolamo/lua-teensyduino and https://github.com/satoren/kaguya.
Basically it works but as i define more bindings i seem to hit some kind of limit that i don't understand and the Teensy 4.0 freezes without executing any code from my sketch. The code i'm talking about can be found here: https://github.com/kallaballa/Farts/tree/kaguya but it's rather messy and huge. The problem arises when i add another (no matter how small) binding definition in https://github.com/kallaballa/Farts/blob/kaguya/tonic_lua.cpp. The bindings seem to be correct, after checking them over and over again. when i compile them on my PC (x86_64) it works. I think i'm hitting some kind of limit that i don't understand.
Attached you'll find the map file and the output of arm-none-eabi-size command for a case where the teensy freezes and one case where it just runs fine.
Why is the teensy freezing right after upload?
