Results 1 to 3 of 3
Thread: How to use the general purpose timer (GPT) output conpare interrupt
    Oct 2019
    2
    I am trying to create multiple interrupts that use the gpt.
    The project should look something like this:
    // compare values that will trigger the interrupts
    uint32_t ocvalue1 = 1000;
    uint32_t ocvalue2 = 1500;
      // Whatever has to be done to get this working
    // Stuff that should happen on the first interrupt (triggered by ocvalue1)
    void interrupt1(void) {
      // My code
    // Stuff that should happen on the second interrupt (triggered by ocvalue2)
    void interrupt2(void) {
      // My code
      // Other code that runs in the meantime
    What do I have to do in the setup() to have this program do what I described?
    2,231
    There are some T4 example sketches in https://github.com/manitou48/teensy4
    gpt_pwm.ino sets up GPT compare registers. There are other GPT examples (capture, external clock, ...)
    Oct 2019
    2
    Thanks manitou for the inspiration. I've been working on the project for some time now and was able to get it working the way I wanted it to (I'd still like the structure to be a bit better, but interrupts demand quick response times). I wrote two libraries (one for general use of projects like this and one customizable for each unique project) and one sketch to show it off. Here is the stuff (warning: the comments are in German):
    The sketch:
     * Dieses Programm stellt eine Umgebung zum Testen der Timerbasierten Interrupts mithilfe der Bibliothek L.h bereit.
     * Geschrieben von Lukas Freudenberg, 30. Oktober 2019
     * Dieses Programm ist gemeinfrei (public domain).
    #include <L.h>
    #include <Interrupt.h>
    uint32_t ocvalue2 = 500;
    int outPinArr[] = {3, 6, 13};
      L::sBg(4000000);
      L::pinSetup(outPinArr, sizeof(outPinArr)/sizeof(int));
      L::interSetup(0, ocvalue1);
      L::interSetup(1, ocvalue2);
      L::sync();
      digitalWriteFast(outPinArr[2], HIGH);
      delay(200);
      digitalWriteFast(outPinArr[2], LOW);
      delay(200);
    The L.h file:
     * L.h - Bibliothek, die einem das Leben erleichtert. Speziell für die Programmierung des Teensy 4.0
     * Diese Bibliothek ist gemeinfrei (public domain).
    #ifndef L_h
    #define L_h
    #include "Arduino.h"
    class L {
      public:
        static void pinSetup(int outPins[], int size);  // Setzt die Outputpins
        static void interSetup(int timer, int compare); // Initialisiert einen Timer-Counter mit Interruptfunktion
        static void sync();				    // Synchronisiert GPT1 und GPT2
      private:
        static void interrupt1();	// Was beim Interrupt 1 geschieht
        static void interrupt2();	// Was beim Interrupt 2 geschieht
        static int* pins;		// speichhert die Outputpins
    The L.cpp file:
    #include "L.h"
    #include "Interrupt.h"
    int* L::pins;
    void L::pinSetup(int outPins[], int size) {
      pins = outPins;
      for(int i = 0; i < size; i++) {
        pinMode(outPins[i], OUTPUT);
      CCM_CSCMR1 = 0x00000000;  // Clock wird durch 1 dividiert (maximale Geschwindigkeit = 150 MHz)
    void L::sync() {
      GPT2_CR &= 0xFFFFFFFE;    	// Counter GPT2 deaktivieren (wird beim nächsten Interrupt von GPT1 wieder aktiviert)
    void L::interrupt1() {
      GPT1_SR = 0x00000001;         // Interrupt im Statusregister zurücksetzen
      while (GPT1_SR == 0x0000001); // Auf Zurücksetzen des Registers warten
      Interrupt::in1(pins[0]);      // Interruptfunktion ausführen
      if (!(GPT2_CR & GPT_CR_EN)){GPT2_CR |= 0x00000001;} // Counter GPT2 aktivieren (aufgrund einer möglichen Synchronisation)
    void L::interrupt2() {
      GPT2_SR = 0x00000001;         // Interrupt im Statusregister zurücksetzen
      while (GPT2_SR == 0x0000001); // Auf Zurücksetzen des Registers warten
      Interrupt::in2(pins[1]);      // Interruptfunktion ausführen
    void L::interSetup(int timer, int compare) {
      switch(timer) {
        case 0: CCM_CCGR1 |= 0x03000000;  // Clock für GPT1 Modul aktivieren
                // GPT1 konfigurieren
                GPT1_CR = 0;              // Kontrollregister zurücksetzen
                GPT1_PR = 0;              // Vorskalierung = 1:1
                GPT1_CR |= 0x00000040;    // Periphere Clock auswählen für maximale Geschwindigkeit (150 MHz)
                GPT1_OCR1 = compare - 1;  // Wert des Counters für das Auslösen des Interrupts setzen
                GPT1_IR = 0x00000001;     // Output Compare 1 aktivieren
                GPT1_CR |= 0x00000001;    // Counter GPT1 aktivieren
                attachInterruptVector(IRQ_GPT1, interrupt1);  // Interruptfunktion festlegen
                NVIC_ENABLE_IRQ(IRQ_GPT1);			  // Interrupt in der Interruptcontroller Tabelle aktivieren
        case 1: CCM_CCGR0 |= 0x03000000;  // Clock für GPT2 Modul aktivieren
                // GPT2 konfigurieren
                GPT2_CR = 0;              // Kontrollregister zurücksetzen
                GPT2_PR = 0;              // Vorskalierung = 1:1
                GPT2_CR |= 0x00000040;    // Periphere Clock auswählen für maximale Geschwindigkeit (150 MHz)
                GPT2_OCR1 = compare - 1;  // Wert des Counters für das Auslösen des Interrupts setzen
                GPT2_IR = 0x00000001;     // Output Compare 1 aktivieren
                GPT2_CR |= 0x00000001;    // Counter GPT2 aktivieren
                attachInterruptVector(IRQ_GPT2, interrupt2);  // Interrupt festlegen
                NVIC_ENABLE_IRQ(IRQ_GPT2);			  // Interrupt in der Interruptcontroller Tabelle aktivieren
    The Interrupt.h file:
     * Interrupt.h - Bibliothek, die benutzerdefinierte Interrupts mithilfe der Bibliothek L.h auf dem Teensy 4.0 bereitstellt
    #ifndef Interrupt_h
    #define Interrupt_h
    class Interrupt {
      public:
        static void in1(int data);
        static void in2(int data);
    And finally the Interrupt.cpp file (this is the one that you would put into the folder of your sketch and edit the functions in it to whatever you want to happen at an interrupt):
    void Interrupt::in1(int data){
      digitalWriteFast(data, !digitalReadFast(data));
    void Interrupt::in2(int data){
      digitalWriteFast(data, HIGH);
      digitalWriteFast(data, LOW);
    Just as a side note: When a program with interrupts is already running on the Teensy, one might occur during the upload. This will cause it to fail, but don't worry: If you push the on board button to upload the sketch, you're fine.
    Any thoughts on how to further improve this?
    In any case, I release this code to the public domain.
Tags for this Thread
