Results 1 to 3 of 3
Thread: Teensy 3.6 with WaveShare CAN not working
    Oct 2019
    8
    I am trying to capture vehicle speed through CAN, however Can0 object is unavailable.
    Hardware:
    1. Teensy 3.6
    2. WaveShare CAN
    3. Teensy Audio Shield
    4. DB9 Connector
    Software & OS:
    1. Windows 10
    2. Arduino 1.8.7
    Pictures:
    From web(OBDII to DB9):
Name:	OBDII to DB9.jpg
    #include <FlexCAN.h>
    //#include <SD.h>
    AudioControlSGTL5000     sgtl5000_1;
    float maxVol = 0.4;
    float wheel_speed[] = {0.0, 0.0, 0.0, 0.0};  //LF, RF, LR, RR
    class ExampleClass : public CANListener
      public:
        void printFrame(CAN_message_t &frame, int mailbox);
        void gotFrame(CAN_message_t &frame, int mailbox); //overrides the parent version so we can actually do something
        void updateSnd(CAN_message_t &frame, int mailbox);
    void ExampleClass::printFrame(CAN_message_t &frame, int mailbox)
        Serial.print("ID: ");
        Serial.print(frame.id, HEX);
        Serial.print(frame.id);
        Serial.print(" Data: ");
        for (int c = 0; c < frame.len; c++)
          Serial.print(frame.buf[c], BIN);
          Serial.write(' ');
        Serial.write('\r');
        Serial.write('\n');
    void ExampleClass::gotFrame(CAN_message_t &frame, int mailbox)
      printFrame(frame, mailbox);
      updateSnd(frame, mailbox);
    void ExampleClass::updateSnd(CAN_message_t &frame, int mailbox)
      if (frame.id == 840) //wheel speeds 1
        //parse wheel speed here//
        wheel_speed[0] = ((frame.buf[1]) + (frame.buf[0] * 256)) * 0.03125;
        wheel_speed[1] = ((frame.buf[3]) + (frame.buf[2] * 256)) * 0.03125;
        //End Parse Wheel Speed//
      if (frame.id == 842) //wheel speeds 2
        wheel_speed[2] = ((frame.buf[1]) + (frame.buf[0] * 256)) * 0.03125;
        wheel_speed[3] = ((frame.buf[3]) + (frame.buf[2] * 256)) * 0.03125;
    ExampleClass exampleClass;
      sgtl5000_1.enable();
      sgtl5000_1.volume(maxVol);
      Serial.begin(115200); //115200 bits/second
      Can0.begin(500000); // Start CAN bus
      //if using enable pins on a transceiver they need to be set on
      pinMode(2, OUTPUT);
      digitalWrite(2, HIGH);
      Can0.attachObj(&exampleClass); //CAN bus handler
      exampleClass.attachGeneralHandler();
      if (Can0.available())
        Serial.print("Successful connection to CAN");
        Serial.println("CAN connection unsuccessful");
    //  Serial.print("Wheel Speed 0: ");
    //  Serial.println(wheel_speed[0]);
    //  Serial.print("Wheel Speed 1: ");
    //  Serial.println(wheel_speed[1]);
    //  Serial.print("Wheel Speed 2: ");
    //  Serial.println(wheel_speed[2]);
    //  Serial.print("Wheel Speed 3: ");
    //  Serial.println(wheel_speed[3]);
    Supply voltage to WaveShare CAN is 3.3V. Voltage between Can High and ground is also 3.3V. Same with CAN Low and ground. I have checked the voltages at pin3 and pin4 with respect to ground as well. They also read 3.3 V.
    Not really sure what I am missing here. Any help is appreciated!!
    --Mayo
    Oct 2019
    8
    Any suggestions guys?
    From other forum threads, I confirmed that there is 120 ohm resistance between CAN H and CAN L.
    I think I am not understanding FlexCAN correctly. Can someone please tell me where I am going wrong?
    Dec 2016
    Montreal, Canada
    3,134
    Try out IFCT, it has very easy examples to get up and running
