Results 1 to 7 of 7
Thread: How do you install FlexCAN_t4 library?
    Oct 2019
    5
    How do you actually install the FlexCAN_t4 as a library for teensy 4.0? Thanks...
    10,322
    Download the ZIP
    Go to your sketchbook folder
    look for or make a dir:: libraries
    Put the extracted folder there in the folder with the right name on it matching the main .h file - i.e. remove '-master' or anything else added to the folder.
    Starting with IDE closed - or close and re-open will have it scan that libraries directory and show it in the files/examples list.
    Oct 2019
    5
    Thanks...
    I'm puzzled I see the "source" file has the .tpp extension. This doesn't need to be changed to .cpp or anything?
    10,322
    Quote Originally Posted by emicros View Post
    Thanks...
    That is fancy cpp feature for a Template file AFAIK ...
    Oct 2019
    5
    Is FlexCAN_t4 only used for CAN_FD or is it for normal CAN 2.0 also?
    10,322
    It can be used for CAN 2.0 and CAN FD - there is a whole thread on that library that will give details or examples.
    10,322
    Forum search often not effective with none or too many answers perhaps - but in this case a simple search for FlaexCAN_t4 quickly pointed out :: forum.pjrc.com/threads/56035-FlexCAN_T4-FlexCAN-for-Teensy-4
    In cases it doesn't work Bing and Google do typically provide good results to forum.PJRC topics
