Results 1 to 3 of 3
Thread: Port Pin Edge Detection
    Feb 2017
    321
    Hi All.
    I’m wondering if it’s possible to use the edge detect capability of T3.2 Port Pins without actually causing an interrupt. I don’t want to miss the signal edge, but I don’t need the fast response of an interrupt -- polling would be fine. Looking through the device datasheet as well as source code for pinMode() and attachInterrupt(), I don’t see it. But, I could easily be missing something.
    Thanks.
    20,813
    Yes, this can be done.
    The trick is to configure the pin change for DMA rather than an interrupt, but then don't set up a DMA transfer. When the pin changes, it will set the PORT_PCR_ISF bit in that pin's config register. Normally the DMA controller would automatically clear this bit when the DMA transfer starts, but you can manually clear it by writing a 1 to it.
    Here's a program to demonstrate how this works.
    // connect pins 2 & 3 together
      while (!Serial && millis() < 4000) ; // wait for Arduino serial monitor
      Serial.println("pin change polling test");
      analogWriteFrequency(3, 51.6); // create test waveform on pin 3
      analogWrite(3, 128);
      pinMode(2, INPUT);
      CORE_PIN2_CONFIG &= ~PORT_PCR_IRQC_MASK;
      CORE_PIN2_CONFIG |= PORT_PCR_IRQC(1); // 1=rising edge detect
      Serial.println("begin");
    elapsedMicros usec;
      if (CORE_PIN2_CONFIG & PORT_PCR_ISF) { // check if pin changed
        CORE_PIN2_CONFIG |= PORT_PCR_ISF; // clear pin change status
        Serial.print("pin change after ");
        Serial.print(usec);
        Serial.println(" us");
        usec = 0;
    The details are in section 11.14.1 of the MK20DX256 reference manual, on page 227.
    https://www.pjrc.com/teensy/datasheets.html
    Feb 2017
    321
    Nice. Thanks Paul.
