Results 1 to 7 of 7
Thread: Tutorial help - 'waveform1' was not declared in this scope
    Oct 2019
    5
    I am trying to go through the video tutorial but I have become stuck.
    Part_2_08_Oscillators
    I get the following message,
    "'waveform1' was not declared in this scope"
    I am using a teensy 3.2 and audio shield rev B.
    I tried to follow each step of the tutorial, rewinding etc to ensure I hadn't missed anything, but I just don't know what to do next.
    Anyone able to suggest how I can get past this?
Name:	Screenshot 2019-10-30 at 17.18.25.png
    1,244
    Copy the text of your code into a new message (preferably between code tags - generated with the # menu icon).
    If waveform1 is undeclared, you can't have put it into the audio design tool.
    Pete
    Nov 2017
    Belgium
    215
    Please post your complete code, otherwise it rather hard to help without guessing.
    guess: you might have declared your oscillator with a different name than "waveform1".
    21,473
    We can't see what you drew in the Design Tool, and in this screenshot we can only see the first few lines of text you copied from the Design Tools into Arduino.
    You can find a correct copy of the Design Tool output for every part of the tutorial by clicking File > Examples > Audio > Tutorial > Reference. Compare what you have in the Design Tool to this image. Pay close attention to the upper left corner...
    (click for full size)
    Or if you want us to help, show us a screenshot of what you actually created in the Design Tool, or the full code you have in Arduino after copying the Design Tool output.
    Oct 2019
    5
    // Advanced Microcontroller-based Audio Workshop
    // http://www.pjrc.com/store/audio_tutorial_kit.html
    // https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
    // Part 2-8: Oscillators
    #include <Bounce.h>
    Bounce button0 = Bounce(0, 15);
    Bounce button1 = Bounce(1, 15);  // 15 = 15 ms debounce time
    Bounce button2 = Bounce(2, 15);
    // copy the Design Tool code here
    #include <SerialFlash.h>
    AudioSynthWavetable      wavetable1;     //xy=120,52
    AudioSynthWaveformSineModulated sine_fm1;       //xy=120,129
    AudioSynthNoisePink      pink1;          //xy=128,257
    AudioSynthWaveformSine   sine1;          //xy=129,192
    AudioMixer4              mixer1;         //xy=330,62
    AudioEffectEnvelope      envelope1;      //xy=475,221
    AudioMixer4              mixer2;         //xy=488,86
    AudioOutputI2S           i2s1;           //xy=652,158
    AudioConnection          patchCord1(wavetable1, 0, mixer1, 0);
    AudioConnection          patchCord2(wavetable1, sine_fm1);
    AudioConnection          patchCord3(sine_fm1, 0, mixer1, 1);
    AudioConnection          patchCord4(pink1, 0, mixer1, 3);
    AudioConnection          patchCord5(sine1, 0, mixer1, 2);
    AudioConnection          patchCord6(mixer1, 0, mixer2, 0);
    AudioConnection          patchCord7(mixer1, envelope1);
    AudioConnection          patchCord8(envelope1, 0, mixer2, 1);
    AudioConnection          patchCord9(mixer2, 0, i2s1, 0);
    AudioConnection          patchCord10(mixer2, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=643,218
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.32);
      pinMode(0, INPUT_PULLUP);
      pinMode(1, INPUT_PULLUP);
      pinMode(2, INPUT_PULLUP);
      mixer1.gain(0, 0.75);
      mixer1.gain(1, 0.0);
      mixer1.gain(2, 0.0);
      mixer1.gain(3, 0.0);
      mixer2.gain(0, 0.15);
      mixer2.gain(1, 0.0);
      mixer2.gain(2, 0.0);
      mixer2.gain(3, 0.0);
      waveform1.begin(WAVEFORM_SAWTOOTH);
      waveform1.amplitude(0.75);
      waveform1.frequency(50);
      waveform1.pulseWidth(0.15);
      sine_fm1.frequency(440);
      sine_fm1.amplitude(0.75);
      sine1.frequency(200);
      sine1.amplitude(0.75);
      pink1.amplitude(0.75);
      envelope1.attack(10);
      envelope1.hold(10);
      envelope1.decay(25);
      envelope1.sustain(0.4);
      envelope1.release(70);
    int waveform_type = WAVEFORM_SAWTOOTH;
    int mixer1_setting = 0;
    int mixer2_setting = 0;
    elapsedMillis timeout = 0;
    bool mixer2_envelope = false;
      button0.update();
      button1.update();
      button2.update();
      // Left changes the type of control waveform
      if (button0.fallingEdge()) {
        Serial.print("Control waveform: ");
        if (waveform_type == WAVEFORM_SAWTOOTH) {
          waveform_type = WAVEFORM_SINE;
          Serial.println("Sine");
        } else if (waveform_type == WAVEFORM_SINE) {
          waveform_type = WAVEFORM_SQUARE;
          Serial.println("Square");
        } else if (waveform_type == WAVEFORM_SQUARE) {
          waveform_type = WAVEFORM_TRIANGLE;
          Serial.println("Triangle");
        } else if (waveform_type == WAVEFORM_TRIANGLE) {
          waveform_type = WAVEFORM_PULSE;
          Serial.println("Pulse");
        } else if (waveform_type == WAVEFORM_PULSE) {
          Serial.println("Sawtooth");
        waveform1.begin(waveform_type);
      // middle button switch which source we hear from mixer1
      if (button1.fallingEdge()) {
        if (mixer1_setting == 0) {
          Serial.println("Mixer1: Control oscillator");
          mixer1_setting = 1;
        } else if (mixer1_setting == 1) {
          mixer1.gain(0, 0.0);
          mixer1.gain(1, 0.75);
          Serial.println("Mixer1: Frequency Modulated Oscillator");
          mixer1_setting = 2;
        } else if (mixer1_setting == 2) {
          mixer1.gain(2, 0.75);
          Serial.println("Mixer1: Regular Sine Wave Oscillator");
          mixer1_setting = 3;
        } else if (mixer1_setting == 3) {
          mixer1.gain(3, 0.75);
          Serial.println("Mixer1: Pink Noise");
          mixer1_setting = 0;
      // Right button activates the envelope
      if (button2.fallingEdge()) {
        mixer2.gain(0, 0.0);
        mixer2.gain(1, 1.0);
        mixer2_envelope = true;
        timeout = 0;
        envelope1.noteOn();
      if (button2.risingEdge()) {
        envelope1.noteOff();
        timeout = 0;
      // after 4 seconds of inactivity, go back to
      // steady listening intead of the envelope
      if (mixer2_envelope == true && timeout > 4000) {
      // use the knobs to adjust parameters
      //float knob1 = (float)analogRead(A1) / 1023.0;
      float knob2 = (float)analogRead(A2) / 1023.0;
      float knob3 = (float)analogRead(A3) / 1023.0;
      waveform1.frequency(360 * knob2 + 0.25);
      sine_fm1.frequency(knob3 * 1500 + 50);
      sine1.frequency(knob3 * 1500 + 50);
    Thanks for the speedy replies.
    Does this information help with trouble shooting?
    All support appreciated, a lot.
Name:	audio system design tool oscillators  2019-10-31 at 15.18.27.jpg
    2,566
    where in the top did you declare waveform1? you only declare wavetable1
    Nov 2017
    Belgium
    215
    @acbc
    According to the tutorial you picked the wrong object in the Design Tool.
    wavetable instead of waveform.
