Results 1 to 2 of 2
Thread: Micro SD Card Adaptor HELP
    Hi all,
    I'm a student and am in a class in which I have to create a circuit board. For my project, I need to use the micro sd adaptor https://www.pjrc.com/store/sd_adaptor.html .
    I've been using the program Altium to create the board, but in Alitum you need to search for parts you want to put on your board with a manufacturing number (listed as Digi-Key Part Number here) https://www.digikey.com/product-deta...ource=octopart
    I also need to have a pin configuration to see what all the pins do pg 5 as an example of what I mean http://www.ti.com/lit/ds/symlink/ads1299-6.pdf .
    I can't seem to find any of that information on the pjrc website and i can't find the part on any other websites that I know of (DigiKey and Mouser).
    ANY information will be more than helpful. I apologize if I'm not using the correct terminology or if I am missing something very obvious, I've never done anything with electronics before and honestly I have no idea how any of these things work, my group just told me to figure it out and that's what I'm trying to do.
    THANK YOU
    3,375
    Other than designing a board to connect this board to the Teensy (and of course ultimately soldering stuff and a micro SD card), you don't need any additional components. The board has all of the appropriate circuits (*). There are simpler micro SD cards, where you would need to add resistors, capacitors, diodes, etc.
    Generally, you would want to do things on a breadboard first, and make sure you understand the wiring, etc. Then it should be fairly simple to move it over to the board.
    * in some cases, where you are sharing the SPI bus with other devices, particularly high speed displays that are optimized for Teensy, it might be advisable to add a 2.2K pull-up resistor on the SS pin (sometimes called CS instead of SS).
    I will leave it as an exercise which pins on the Teensy to use.
