Results 1 to 3 of 3
Thread: Bounce Library
    Nov 2018
    16
    Bounce Library
    Hello does anyone know which Bounce example is best to use to make a pushbutton act like a toggle switch? I am using a teensy 2.0++ for XPlane 11.
    21,092
    You need more than just the Bounce library. You will also need to add some code to remember the emulated toggle switch's position.
    Something like this...
      button1.update();
      if (button1.fallingEdge()) {
        if (toggleState == true) {
          toggleState = false;
          Serial.println("Toggle switch is off");
          toggleState = true;
          Serial.println("Toggle switch is on");
    Nov 2018
    16
    Thanks I'll try that.
