@KurtE
Have to go do a couple of errands - didn't get a chance to test if the same thing happens on other pins as well. I assume you did though knowing you.![]()
@KurtE
@mjs513 - I hacked up another sketch that has to FlexSerial objects and just does output. Did not bother to echo (also posted this one to NXP).
Sample output:Code://============================================================================ // Simple output only test for Flex Serial pin defined on Pin 2 // Idea is to connect pin 0 (Serail1 RX pin) to Pin2 (Flex IO output) // // And the program will hopefully echo the stuff to The serial output //============================================================================ #include <FlexIO_t4.h> #include <FlexSerial.h> #define TX_PIN 3 #define TX_FLEX_IO_INDEX 0 #define TX_FLEX_IO_TIMER 0 #define TX_FLEX_IO_SHIFTER 0 #define TX_PIN2 4 #define TX_FLEX_IO_INDEX2 0 #define TX_FLEX_IO_TIMER2 1 #define TX_FLEX_IO_SHIFTER2 1 FlexSerial SerialFlex(-1, TX_PIN, -1, -1, -1, TX_FLEX_IO_INDEX, TX_FLEX_IO_TIMER, TX_FLEX_IO_SHIFTER); FlexSerial SerialFlex2(-1, TX_PIN2, -1, -1, -1, TX_FLEX_IO_INDEX2, TX_FLEX_IO_TIMER2, TX_FLEX_IO_SHIFTER2); void setup() { pinMode(13, OUTPUT); while (!Serial && millis() < 4000); Serial.begin(115200); Serial1.begin(115200); // lets start up Serial1, to see if we can receive anything from our FlexSerial delay(500); SerialFlex.begin(115200); SerialFlex2.begin(115200); } // Real simple for now void loop() { SerialFlex.print("Flex1"); SerialFlex2.print("Flex2 More"); delay(2); Serial.println("******** After first output ************"); Serial.printf("CCM_CDCDR: %x\n", CCM_CDCDR); Serial.printf("VERID:%x PARAM:%x CTRL:%x PIN: %x\n", IMXRT_FLEXIO1_S.VERID, IMXRT_FLEXIO1_S.PARAM, IMXRT_FLEXIO1_S.CTRL, IMXRT_FLEXIO1_S.PIN); Serial.printf("SHIFTSTAT:%x SHIFTERR=%x TIMSTAT=%x\n", IMXRT_FLEXIO1_S.SHIFTSTAT, IMXRT_FLEXIO1_S.SHIFTERR, IMXRT_FLEXIO1_S.TIMSTAT); Serial.printf("SHIFTSIEN:%x SHIFTEIEN=%x TIMIEN=%x\n", IMXRT_FLEXIO1_S.SHIFTSIEN, IMXRT_FLEXIO1_S.SHIFTEIEN, IMXRT_FLEXIO1_S.TIMIEN); Serial.printf("SHIFTSDEN:%x SHIFTSTATE=%x\n", IMXRT_FLEXIO1_S.SHIFTSDEN, IMXRT_FLEXIO1_S.SHIFTSTATE); Serial.printf("SHIFTCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCTL[0], IMXRT_FLEXIO1_S.SHIFTCTL[1], IMXRT_FLEXIO1_S.SHIFTCTL[2], IMXRT_FLEXIO1_S.SHIFTCTL[3]); Serial.printf("SHIFTCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCFG[0], IMXRT_FLEXIO1_S.SHIFTCFG[1], IMXRT_FLEXIO1_S.SHIFTCFG[2], IMXRT_FLEXIO1_S.SHIFTCFG[3]); Serial.printf("TIMCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCTL[0], IMXRT_FLEXIO1_S.TIMCTL[1], IMXRT_FLEXIO1_S.TIMCTL[2], IMXRT_FLEXIO1_S.TIMCTL[3]); Serial.printf("TIMCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCFG[0], IMXRT_FLEXIO1_S.TIMCFG[1], IMXRT_FLEXIO1_S.TIMCFG[2], IMXRT_FLEXIO1_S.TIMCFG[3]); Serial.printf("TIMCMP:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCMP[0], IMXRT_FLEXIO1_S.TIMCMP[1], IMXRT_FLEXIO1_S.TIMCMP[2], IMXRT_FLEXIO1_S.TIMCMP[3]); SerialFlex.print(" second Flex output"); SerialFlex2.print(" Flex 2 output again"); delay(10); Serial.println("******** After Second output ************"); Serial.printf("CCM_CDCDR: %x\n", CCM_CDCDR); Serial.printf("VERID:%x PARAM:%x CTRL:%x PIN: %x\n", IMXRT_FLEXIO1_S.VERID, IMXRT_FLEXIO1_S.PARAM, IMXRT_FLEXIO1_S.CTRL, IMXRT_FLEXIO1_S.PIN); Serial.printf("SHIFTSTAT:%x SHIFTERR=%x TIMSTAT=%x\n", IMXRT_FLEXIO1_S.SHIFTSTAT, IMXRT_FLEXIO1_S.SHIFTERR, IMXRT_FLEXIO1_S.TIMSTAT); Serial.printf("SHIFTSIEN:%x SHIFTEIEN=%x TIMIEN=%x\n", IMXRT_FLEXIO1_S.SHIFTSIEN, IMXRT_FLEXIO1_S.SHIFTEIEN, IMXRT_FLEXIO1_S.TIMIEN); Serial.printf("SHIFTSDEN:%x SHIFTSTATE=%x\n", IMXRT_FLEXIO1_S.SHIFTSDEN, IMXRT_FLEXIO1_S.SHIFTSTATE); Serial.printf("SHIFTCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCTL[0], IMXRT_FLEXIO1_S.SHIFTCTL[1], IMXRT_FLEXIO1_S.SHIFTCTL[2], IMXRT_FLEXIO1_S.SHIFTCTL[3]); Serial.printf("SHIFTCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCFG[0], IMXRT_FLEXIO1_S.SHIFTCFG[1], IMXRT_FLEXIO1_S.SHIFTCFG[2], IMXRT_FLEXIO1_S.SHIFTCFG[3]); Serial.printf("TIMCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCTL[0], IMXRT_FLEXIO1_S.TIMCTL[1], IMXRT_FLEXIO1_S.TIMCTL[2], IMXRT_FLEXIO1_S.TIMCTL[3]); Serial.printf("TIMCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCFG[0], IMXRT_FLEXIO1_S.TIMCFG[1], IMXRT_FLEXIO1_S.TIMCFG[2], IMXRT_FLEXIO1_S.TIMCFG[3]); Serial.printf("TIMCMP:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCMP[0], IMXRT_FLEXIO1_S.TIMCMP[1], IMXRT_FLEXIO1_S.TIMCMP[2], IMXRT_FLEXIO1_S.TIMCMP[3]); Serial.println("\n *** Enter anything to run again ***"); while (Serial.read() == -1) ; while (Serial.read() != -1); }
This one shows the issue that with 2 Shifters 0 and 1, when 0 finishes 1 does not output anymore...Code:pin 3 maps to: 20000bb8, port: 401ac000(FLEXIO1) pin 5 timer index: 0 shifter index: 0 mask: 1 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 0 SHIFTSTAT:0 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 0 0 0 SHIFTCFG:32 0 0 0 TIMCTL:1c00501 0 0 0 TIMCFG:2222 0 0 0 TIMCMP:f81 0 0 0 pin 4 maps to: 20000bb8, port: 401ac000(FLEXIO1) pin 6 timer index: 1 shifter index: 1 mask: 2 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 40 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3(F) 0 1 0 FI1: 2 3 0 4(F) 0 3 0 FI1: 1 3 0 3(l) 0 3 0 FI1: 2 3 0 4(l) 0 3 0 FI1: 1 3 0 3(e) 0 3 0 FI1: 2 3 0 4(e) 0 3 0 FI1: 1 3 0 3(x) 0 3 0 FI1: 2 3 0 4(x) 0 3 0 FI1: 1 3 0 3(1)* 0 2 0 FI1: 2 2 0 4(2) 0 2 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 3 0 3( ) 0 3 0 FI1: 3 3 0 3(s)4( ) 0 3 0 FI1: 3 3 0 3(e)4(M) 0 3 0 FI1: 3 3 0 3(c)4(o) 0 3 0 FI1: 3 3 0 3(o)4(r) 0 3 0 FI1: 3 3 0 3(n)4(e) 0 3 0 FI1: 3 3 0 3(d)4( ) 0 3 0 FI1: 3 3 0 3( )4(F) 0 3 0 FI1: 3 3 0 3(F)4(l) 0 3 0 FI1: 3 3 0 3(l)4(e) 0 3 0 FI1: 3 3 0 3(e)4(x) 0 3 0 FI1: 3 3 0 3(x)4( ) 0 3 0 FI1: 3 3 0 3( )4(2) 0 3 0 FI1: 3 3 0 3(o)4( ) 0 3 0 FI1: 3 3 0 3(u)4(o) 0 3 0 FI1: 3 3 0 3(t)4(u) 0 3 0 FI1: 3 3 0 3(p)4(t) 0 3 0 FI1: 3 3 0 3(u)4(p) 0 3 0 FI1: 3 3 0 3(t)*4(u) 0 2 0 FI1: 3 2 0 4(t) 1 2 0 ******** After Second output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 *** Enter anything to run again ***
Probably all for now. May do some other diversion
@KurtE
Know this is going to sound strange but could you put you LA on it again using these prints:
Code:SerialFlex.print ("Flex112345"); SerialFlex2.print("Flex2 More"); …... SerialFlex.print (" second Flex output1"); SerialFlex2.print(" Flex 2 output again");
Yep - But all of this is strange....
Here is debug output:
So you are going to say it looks like maybe it output the last stuff? BUT again the odd part...Code:pin 3 maps to: 20000bc0, port: 401ac000(FLEXIO1) pin 5 timer index: 0 shifter index: 0 mask: 1 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 0 SHIFTSTAT:0 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 0 0 0 SHIFTCFG:32 0 0 0 TIMCTL:1c00501 0 0 0 TIMCFG:2222 0 0 0 TIMCMP:f81 0 0 0 pin 4 maps to: 20000bc0, port: 401ac000(FLEXIO1) pin 6 timer index: 1 shifter index: 1 mask: 2 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 40 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3(F)* 0 0 0 FI1: 2 3 0 4(F) 0 3 0 FI1: 1 3 0 3(l) 0 3 0 FI1: 2 3 0 4(l) 0 3 0 FI1: 1 3 0 3(e) 0 3 0 FI1: 2 3 0 4(e) 0 3 0 FI1: 1 3 0 3(x) 0 3 0 FI1: 2 3 0 4(x) 0 3 0 FI1: 1 3 0 3(1) 0 3 0 FI1: 2 3 0 4(2) 0 3 0 FI1: 1 3 0 3(1) 0 3 0 FI1: 2 3 0 4( ) 0 3 0 FI1: 1 3 0 3(2) 0 3 0 FI1: 2 3 0 4(M) 0 3 0 FI1: 1 3 0 3(3) 0 3 0 FI1: 2 3 0 4(o) 0 3 0 FI1: 1 3 0 3(4) 0 3 0 FI1: 2 3 0 4(r) 0 3 0 FI1: 1 3 0 3(5)* 0 2 0 FI1: 2 2 0 4(e)* 0 0 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3( ) 0 1 0 FI1: 3 3 0 3(s)4( ) 0 3 0 FI1: 3 3 0 3(e)4(F) 0 3 0 FI1: 3 3 0 3(c)4(l) 0 3 0 FI1: 3 3 0 3(o)4(e) 0 3 0 FI1: 3 3 0 3(n)4(x) 0 3 0 FI1: 3 3 0 3(d)4( ) 0 3 0 FI1: 3 3 0 3( )4(2) 0 3 0 FI1: 3 3 0 3(F)4( ) 0 3 0 FI1: 3 3 0 3(l)4(o) 0 3 0 FI1: 3 3 0 3(e)4(u) 0 3 0 FI1: 3 3 0 3(x)4(t) 0 3 0 FI1: 3 3 0 3( )4(p) 0 3 0 FI1: 3 3 0 3(o)4(u) 0 3 0 FI1: 3 3 0 3(u)4(t) 0 3 0 FI1: 3 3 0 3(t)4( ) 0 3 0 FI1: 3 3 0 3(p)4(a) 0 3 0 FI1: 3 3 0 3(u)4(g) 0 3 0 FI1: 3 3 0 3(t)4(a) 0 3 0 FI1: 3 3 0 3(1)*4(i) 0 2 0 FI1: 3 2 0 4(n)* 1 0 0 ******** After Second output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 *** Enter anything to run again ***
In each case it looks like the last character is output (as shown in RED, but in both cases the character is not shifted out. In the first set of outputs, it does get shifted out when the first byte is output of the next sequence...
Yeah, that's kind of what I wanted to check. It is strange. Its almost like you have to flush the last character or send a 0xff or 0x00 just to complete the sequence - think I saw that someplace but I cant remember what it was referring too.So you are going to say it looks like maybe it output the last stuff? BUT again the odd part...
@KurtE
Started playing again this morning and I did add a couple more debug prints to your callback function. In the SDK it has this as a test:
so I changed it to print this which I think is the same or equivalent:Code:/* Send data register empty and the interrupt is enabled. */ if ((kFLEXIO_UART_TxDataRegEmptyFlag & status) && (base->flexioBase->SHIFTSIEN & (1U << base->shifterIndex[0])))
Now when I run the example in post #27.Code:Serial.printf(" (index %d, SDK flag %d)",_tx_shifter, (0x1 & p->SHIFTSTAT) && (p->SHIFTSIEN & (1U << _tx_shifter)));
that flag seems to be set only for index 0? And if I hit return:Code:pin 3 maps to: 20000be0, port: 401ac000(FLEXIO1) pin 5 timer index: 0 shifter index: 0 mask: 1 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 0 SHIFTSTAT:0 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 0 0 0 SHIFTCFG:32 0 0 0 TIMCTL:1c00501 0 0 0 TIMCFG:2222 0 0 0 TIMCMP:f81 0 0 0 pin 4 maps to: 20000be0, port: 401ac000(FLEXIO1) pin 6 timer index: 1 shifter index: 1 mask: 2 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 40 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3 (index 0, SDK flag 1)(h!t1: F)* 0 0 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: l) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: e) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: x) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: 1)* 0 2 0 FI1: 2 2 0 4 (index 1, SDK flag 0)(h!t1: 2) 0 2 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: s)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: M) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: c)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: r) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: n)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: d)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: F)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: p)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: p) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)*4 (index 1, SDK flag 0)(h!t1: u) 0 2 0 FI1: 3 2 0 4 (index 1, SDK flag 1)(h!t1: t) 1 2 0 ******** After Second output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0
Is it possible the index is getting messed some how?Code:*** Enter anything to run again *** FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: a) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: g) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: 1)*4 (index 1, SDK flag 0)(h!t1: a) 0 2 0 FI1: 3 2 0 4 (index 1, SDK flag 1)(h!t1: i) 1 2 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: s)4 (index 1, SDK flag 0)(h!t1: n) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: c)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: n)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: d)4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: F)4 (index 1, SDK flag 0)(h!t1: M) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: r) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: p)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)*4 (index 1, SDK flag 0)(h!t1: 2) 0 2 0 FI1: 3 2 0 4 (index 1, SDK flag 1)(h!t1: ) 1 2 0 ******** After Second output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:2 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 *** Enter anything to run again *** FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: F)* 0 2 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: 1)*4 (index 1, SDK flag 0)(h!t1: p) 0 2 0 FI1: 3 2 0 4 (index 1, SDK flag 1)(h!t1: u) 1 2 0
PS: yes I changed a couple of the other prints just because.....
Hi @mjs513....
Not sure about the line: Serial.printf(" (index %d, SDK flag %d)",_tx_shifter, (0x1 & p->SHIFTSTAT) && (p->SHIFTSIEN & (1U << _tx_shifter)));
In particular the part in RED. Looks like it will only be TRUE if Index is 1...?
I converted that piece from the SDK code frag I posted:. In the SDK its was specified asCode:kFLEXIO_UART_TxDataRegEmptyFlag & statusjust as an aside I extracted from here:Code:kFLEXIO_UART_TxDataRegEmptyFlag = 0x1U, /*!< Transmit buffer empty flag. */
As I said just took a guess that was the right conversion.\Code:/*! @brief Define FlexIO UART status mask. */ enum _flexio_uart_status_flags { kFLEXIO_UART_TxDataRegEmptyFlag = 0x1U, /*!< Transmit buffer empty flag. */ kFLEXIO_UART_RxDataRegFullFlag = 0x2U, /*!< Receive buffer full flag. */ kFLEXIO_UART_RxOverRunFlag = 0x4U, /*!< Receive buffer over run flag. */ };
EDIT: Looking back at the output it does show for index 0, the SDK flag 1 which is from that serial output. Think I am interpreting right. Still playing and figuring things out. Index is _tx_shifter.
Hi @mjs513 - Still does not make sense to me... Maybe I am just being dense.
For example:
If you look at the SHIFTSEIN register P3049, the bits are defined for Transmit:
And SSF is defined in SHIFTSTAT: (P3046) -Code:bits 3-0 SSIE Shifter Status Interrupt Enable Enables interrupt generation when corresponding SSF is set. 0b - Shifter Status Flag interrupt disabled. 1b - Shifter Status Flag interrupt enabled.
Note: These bits are W1C where as the SHIFTSEIN they are simply READ/WRITE...Code:3-0 SSF Shifter Status Flag The shifter status flag is updated when one of the following events occurs: For SMOD=Receive, the status flag is set when SHIFTBUF has been loaded with data from Shifter (SHIFTBUF is full), and the status flag is cleared when SHIFTBUF register is read. For SMOD=Transmit, the status flag is set when SHIFTBUF data has been transferred to the Shifter (SHIFTBUF is empty) or when initially configured for SMOD=Transmit, and the status flag is cleared when the SHIFTBUF register is written. For SMOD=Match Store, the status flag is set when a match has occured between SHIFTBUF and Shifter, and the status flag is cleared when the SHIFTBUF register is read. For SMOD=Match Continuous, returns the current match result between the SHIFTBUF and Shifter. For SMOD=State, the status flag for a shifter will set when it is selected by the current state pointer. For SMOD=Logic, returns the current value of the programmable logic block output. The status flag can also be cleared by writing a logic one to the flag for all modes except Match Continuous/State/Logic. 0b - Status flag is clear. 1b - Status flag is set.
Again![]()
@KurtE
Confused is the normal state for meGuess I will have to go back to the manual and bounce the two off each other. Either that or I can run the SDK interrupt example on the 1062EVKB and try to duplicate what is being done in the sketch to see what happens
Waiting for wife at Dr's now so may be awhile....
@KurtE
I loaded up the interrupt SDK example on the 1062EVKB and saw a couple of things. First, the way the sdk is set up is it transmits on one pin and recieives on another. So I hooked up the USB converter to the pc and opened the serial monitor. Sent it a input string of "12345678":
not sure it means anything for us or just a quirk with the SDK.Code:12345 (CR/NL) 1st send 12345678 678 (CR/NL) 2nd send 12345678 123 45678 (NL) 3rd send 12345678 1 Do a reset and select no line ending 12345678
But played some more with padding the shorter prints with spacers instead of number, i.e.,
and I think it worked this time>>>>> heres the output:Code:SerialFlex.printf("Flex1 "); SerialFlex2.printf("Flex2 More"); … SerialFlex.print(" second Flex output "); SerialFlex2.print(" Flex 2 output again");
on second output:Code:pin 3 maps to: 20000bf0, port: 401ac000(FLEXIO1) pin 5 timer index: 0 shifter index: 0 mask: 1 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 0 SHIFTSTAT:0 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 0 0 0 SHIFTCFG:32 0 0 0 TIMCTL:1c00501 0 0 0 TIMCFG:2222 0 0 0 TIMCMP:f81 0 0 0 pin 4 maps to: 20000bf0, port: 401ac000(FLEXIO1) pin 6 timer index: 1 shifter index: 1 mask: 2 Before configure flexio CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 40 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=0 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3 (index 0, SDK flag 1)(h!t1: F) 0 1 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: l) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: e) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: x) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: 1) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: M) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: ) 0 3 0 FI1: 2 3 0 4 (index 1, SDK flag 0)(h!t1: r) 0 3 0 FI1: 1 3 0 3 (index 0, SDK flag 1)(h!t1: )* 0 2 0 FI1: 2 2 0 4 (index 1, SDK flag 0)(h!t1: e)* 0 0 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3 (index 0, SDK flag 1)(h!t1: )* 0 0 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: s)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: c)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: n)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: d)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: F)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: p) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: p)4 (index 1, SDK flag 0)(h!t1: a) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: g) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: a) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: i) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: n)* 0 1 0 FI1: 3 1 0 3 (index 0, SDK flag 1)(h!t1: ) 2 1 0 FI1: 3 1 2 3 (index 0, SDK flag 1)(h!t1: )(err) 4$ 0 1 0 FI1: 3 1 0 3 (index 0, SDK flag 1)(h!t1: )* 2 0 0
Don't know just throwing things out there and seeing if something clicks..... Now to read the manual.Code:*** Enter anything to run again *** FI1: 3 1 2 3 (index 0, SDK flag 1)(h!t1: F)(err) 4$ 0 1 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: 1)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: M) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )*4 (index 1, SDK flag 0)(h!t1: r) 0 2 0 FI1: 3 2 0 4 (index 1, SDK flag 1)(h!t1: e)* 1 0 0 ******** After first output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:1 SHIFTERR=0 TIMSTAT=3 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0 FI1: 1 1 0 3 (index 0, SDK flag 1)(h!t1: )* 0 0 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: s)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: F) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: c)4 (index 1, SDK flag 0)(h!t1: l) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: e) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: n)4 (index 1, SDK flag 0)(h!t1: x) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: d)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: 2) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: F)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: l)4 (index 1, SDK flag 0)(h!t1: o) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: e)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: x)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: p) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: o)4 (index 1, SDK flag 0)(h!t1: u) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: t) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: ) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: p)4 (index 1, SDK flag 0)(h!t1: a) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: u)4 (index 1, SDK flag 0)(h!t1: g) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: t)4 (index 1, SDK flag 0)(h!t1: a) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: i) 0 3 0 FI1: 3 3 0 3 (index 0, SDK flag 1)(h!t1: )4 (index 1, SDK flag 0)(h!t1: n)* 0 1 0 FI1: 3 1 0 3 (index 0, SDK flag 1)(h!t1: ) 2 1 0 FI1: 3 1 2 3 (index 0, SDK flag 1)(h!t1: )(err) 4$ 0 1 0 FI1: 3 1 0 3 (index 0, SDK flag 1)(h!t1: )* 2 0 0 ******** After Second output ************ CCM_CDCDR: 33f71f92 VERID:1010001 PARAM:2100808 CTRL:1 PIN: 60 SHIFTSTAT:3 SHIFTERR=2 TIMSTAT=3 SHIFTSIEN:0 SHIFTEIEN=0 TIMIEN=0 SHIFTSDEN:0 SHIFTSTATE=0 SHIFTCTL:30502 1030602 0 0 SHIFTCFG:32 32 0 0 TIMCTL:1c00501 1c00601 0 0 TIMCFG:2222 2222 0 0 TIMCMP:f81 f81 0 0
@mjs513 (and others) - I may have fixed my multiple FlexSerial transmit issue...
I believe: The TIMCTL register did not have the right TRGSEL value (I think).
I think it needs to 4* Shifter number + 1 (was hard coded to 1) so was specific to shifter 0...
The documentation for this at times is a bit confusing.
At least I think my two FlexSerial on pins 3 and 4 appears to be working now. Will try the big one nextCode:Trigger Select The valid values for TRGSEL will depend on the FLEXIO_PARAM register. • When TRGSRC = 1, the valid values for N will depend on PIN, TIMER, SHIFTER fields in the FLEXIO_PARAM register. • When TRGSRC = 0, the valid values for N will depend on TRIGGER field in FLEXIO_PARAM register. Refer to the chip configuration section for external trigger selection. NOTE: For a pin, N=0 to 31. For a Shifter/Timer, N=0 to 3. The internal trigger selection is configured as follows: • 4*N - Pin 2*N input • 4*N+1 - Shifter N status flag • 4*N+2 - Pin 2*N+1 input • 4*N+3 - Timer N trigger output
The debug prints? If so, try enabling the lpuart clock, CANFD wont work without lpuart clock enabled....
Thanks @tonton81 - CANFD - needs LUPUART... Looks like they are pretty similar in the clock tree...
As for this one, I isolated down which set of Serial.printf(...) statements when disabled caused things to screw up.
At first I thought maybe it was because these prints, were outputting most of the FlexIO registers, so maybe one or more of them needed to be read... So I put code in to read all of them, and still failed. However if I add a delay(1) it works, which is how I left it. As this is done on the FlexSerial::begin() method, not worried about a 1ms delay...
So hopefully things are now working OK (fingers crossed)
@KurtE
Cool that you got FlexIO Serial working. I read that section a couple of times and still gets me confused.Nothing new
Yeah - FlexCAN seems to need LPUART enabled to work for some reason. If we don't enable it just hangs on initialization. Worked before in testing because it was enabled in startup.c because debug.prints were turned on.
I know what you mean, some of these descriptions are not very obvious. And their examples are like here is it working on Pin X timer0 shifter 0... No where to they explain how each of the fields in their example would change if they changed one of those parameters...
Next hurtle, is so far I have not done SerialFlex.flush()... I had a version for awhile that was hanging.
I can easily (in theory) get flush to go until the queue is empty, but not sure yet on how to get it to wait until the last byte transferred. I am going to try to hack in maybe setting a timer interrupt at this point and see what it does... But that is just a guess!
Just an FYI - I just pushed up an update, that I believe makes flush work reasonably well.
The simple version that simply waits for us to output the last byte in the queue into the shift buffer is not sufficient. It would end up returning from flush() with part of two characters left to be output.
So this version enables the Timer interrupt to happen when we sense that our queue is empty, and then we need to process two of these timer interrupts. On the second one we disable it and set the flag that says that we are no longer transmitting. If we do another write after we start up the trigger, we reset the timer status and again turn off the ISR...
I added a one second timeout into flush() in case it totally hangs.
Again depending on if anyone is going to use this, I could add in the Transmitter Enable pin code...
