Results 1 to 7 of 7
Thread: variable update::: general advice needed
    Nov 2019
    4
    I was hoping someone could tell me a way to retain information in a variable temporarily until it could be evaluated.
    something like this :::
    serial available
    read byte
    byte = previous byte
    if byte != previous byte
    How can you keep track of a change?
    Dec 2016
    Montreal, Canada
    3,135
    A class static/auto or global variable is needed where you can copy the last byte to and check later on
    Simply can put it before the void setup() line:
    uint8_t lastByte = 0;
    Nov 2019
    4
    I read about that but I don't get it.
    Lets say you say Byte = lastByte, how do you every make lastByte stop updating and look at the previous Byte?
    Nov 2019
    4
    okay sorry what about this::::
    analogread = x
    x=preeviousx
    print previousx
    how do you look at previousx?
    TY
    Dec 2016
    Montreal, Canada
    3,135
    After you compare it:
    myByte == lastByte, or however you wish to compare, then set it to the new value:
    lastByte = myByte;
    Then your code repeats it
    Nov 2019
    4
    lastByte = myByte;
    I haven't tried that but I did figure out something that works:::
    read = a
    read = b
    read = c
    read = d
    read = e
    if a != b || c || d || e
    something to that effect you can see when it changes and compare.
    I'll try what you mentioned.. thanks
    Dec 2016
    Montreal, Canada
    3,135
    if ( Serial.available() ) {
      uint8_t receivedByte = Serial.read();
      if ( receivedByte != lastByte ) {
        //Do Something...
      lastByte = receivedByte; // store the last byte as previous byte
