Aref pin on Teensy 3.6.
I want to connect a voltage reference chip to the Teensy 3.6 to get accurate measurements from the ADC.
Can the Aref pin take more than 3.3V or is it also limited to 3.3V like all other pins?
For setting the Aref to internal reference, it is written in the ADC library to use ADC_REFERENCE::REF_3V3 or ADC_REFERENCE::REF_1V2. Does this apply to the Teens 3.6 as well?
So for setting to external reference, I just use ADC_REFERENCE::REF_EXT, right?
In the schematics, it is shown that Aref is already connected to 3.3V, so does that mean I have to remove the 470Ohm resistor if I want to use an external reference chip?
Thanks in advance.
I will have the same problem.
I tryed to use the internal tempSensor for regulating the temperatur on the chip, so i cold use the internal reference. But the use of the internal sensor doubles my isr, because the only working way reading the sensor is the blocking methode analogRead().
So i have to use a Ref43 with its own tempSensor an an analog regulater. And i have to connect it to Aref....
Senior Member+
Originally Posted by
Bert62
As noted on the card back and elsewhere :
Teensy 3.6 pins are
not 5 volt tolerant. Do not apply more than 3.3 volts.
Even if that did not somehow apply to AREF - no input over 3.3V could be applied.
- You may not post replies
- You may not edit your posts
Forum Rules
