Results 1 to 5 of 5
Thread: Adding AudioInputAnalog breask the project
    Nov 2019
    3
    Adding AudioInputAnalog breaks the project
    Hello!
    I'm a beginner with Teensy, so I've spent the night setting up a simple mic and analog input that I want to do FFT. I've tried all samples I can find that uses AudioInputAnalog, but it just won't compile if I select Teensy 4.0 as a board. If I select any other Teensy board it will, but then it won't upload to the Teensy (which, of course, is understandable).
    Is it me or something else?
    Here's what I'm trying to do:
    #include <SerialFlash.h>
    AudioInputAnalog         adc1;           //xy=122,68
    AudioAmplifier           amp1;           //xy=279,126
    AudioAnalyzeFFT1024      fft1024;      //xy=433,180
    AudioConnection          patchCord1(adc1, amp1);
    AudioConnection          patchCord2(amp1, fft1024);
    //AudioInputAnalog adc1(A0);
    float level[16];
      AudioMemory(12);
      if (fft1024.available()) {
        // read the 512 FFT frequencies into 16 levels
        // music is heard in octaves, but the FFT data
        // is linear, so for the higher octaves, read
        // many FFT bins together.
        level[0] =  fft1024.read(0);
        level[1] =  fft1024.read(1);
        level[2] =  fft1024.read(2, 3);
        level[3] =  fft1024.read(4, 6);
        level[4] =  fft1024.read(7, 10);
        level[5] =  fft1024.read(11, 15);
        level[6] =  fft1024.read(16, 22);
        level[7] =  fft1024.read(23, 32);
        level[8] =  fft1024.read(33, 46);
        level[9] =  fft1024.read(47, 66);
        level[10] = fft1024.read(67, 93);
        level[11] = fft1024.read(94, 131);
        level[12] = fft1024.read(132, 184);
        level[13] = fft1024.read(185, 257);
        level[14] = fft1024.read(258, 359);
        level[15] = fft1024.read(360, 511);
        // See this conversation to change this to more or less than 16 log-scaled bands?
        // https://forum.pjrc.com/threads/32677-Is-there-a-logarithmic-function-for-FFT-bin-selection-for-any-given-of-bands
        for (int i = 0; i < 16; i++) {
          Serial.print(level[i]);
          //Serial.print(shown[i]);
          Serial.print(" ");
        Serial.print(" cpu:");
        Serial.println(AudioProcessorUsageMax());
    Same here.
    Nov 2019
    3
    ... anyone?
    21,069
    AudioInputAnalog is not yet supported on Teensy 4.0.
    It will be at some point in the future, but with the missing USB types at a higher priority, it may be several weeks until this gets serious engineering time. I know that timeframe isn't great news, but hopefully an honest answer is better than not knowing?
    Nov 2019
    3
    I really appreciate your honesty, even if it wasn't the answer I was hoping for.
    It cost me another $20+ as I bought a Teensy 3.6 so I can continue codingwhile you hopefully fix the 4.0 compatibility issues... But I guess that's good new for you.
    It's not a problem, I'll live with it. And the good news is that I will be able to use the Teensy 4.0 sometime in the future.
