Results 1 to 2 of 2
Thread: TFT ST7789 - convert SPI9 to DMA transfer (Teensy 3.6)
    I have an odd display which uses a modified ST7789 driver to support SPI9 but to update the display is quite slow. I am using an Teensy 3.6 and running the example DMASpi (https://github.com/crteensy/DmaSpi) and would like to convert the bit banging code to DMA transfer.
    The ST7789 SPI 9 librry for the driver is here:
    https://github.com/ananevilya/Arduino-ST7789-Library
    This is the part of the code which bit bangs the data into SPI, the rest of the code is driver code and commands
    inline void Arduino_ST7789::spiwrite(uint8_t c)
    		digitalWrite(_sclk, LOW);
    		if(_DCbit) digitalWrite(_sid, HIGH);
    		else        digitalWrite(_sid, LOW);
    		digitalWrite(_sclk, HIGH);
    		// Fast SPI bitbang swiped from LPD8806 library
    		for(uint8_t bit = 0x80; bit; bit >>= 1)
    		if(c & bit)
    I trying to work out if I can somehow replace the above code with DMA transfer, rather than the block data transfer into the bit transfer I want to add it into the DMA "src" buffer. I have tried the code but it does not work and just wondering if it will be possible.
      DMASPI0.begin();
      DMASPI0.start();
      Serial.println("Start DMA transfer");
      DmaSpi::Transfer trx(nullptr, 0, nullptr);
      trx = DmaSpi::Transfer(src, DMASIZE, dest);
      clrDest((uint8_t*)dest);
      DMASPI0.registerTransfer(trx);
      while(trx.busy())
      Serial.println("Finished DMA transfer");
    5,994
    You might simply try the st7735_t3 library which now includes the st7789. We also have frame buffer support plus option of DMA updates.
