Results 1 to 5 of 5
Thread: Audio Lib inits in other than main.cpp
    I've used the audio library before and had trouble when pasting the init code in another .hpp file, other than main.cpp
    By init code I mean the code the audio library generates:
    #include <SerialFlash.h>
    AudioInputI2S            i2s2;           //xy=128,351
    AudioSynthWaveformSine   sine1;          //xy=221,562
    AudioMixer4              mixer1;         //xy=282,369
    AudioSynthWaveformSineModulated sine_fm1;       //xy=409,553
    AudioAnalyzePeak         peak1;          //xy=410,336
    AudioEffectDelay         delay1;         //xy=603,418
    AudioEffectFreeverb      freeverb1;      //xy=720,280
    AudioMixer4              mixer2;         //xy=918,300
    AudioOutputI2S           i2s1;           //xy=1102,294
    AudioOutputUSB           usb1;           //xy=1108,353
    AudioConnection          patchCord1(i2s2, 0, mixer1, 0);
    AudioConnection          patchCord2(i2s2, 1, mixer1, 1);
    AudioConnection          patchCord3(sine1, delay1);
    AudioConnection          patchCord4(mixer1, peak1);
    AudioConnection          patchCord5(sine_fm1, delay1);
    AudioConnection          patchCord6(delay1, 0, freeverb1, 0);
    AudioConnection          patchCord7(delay1, 0, mixer2, 1);
    AudioConnection          patchCord8(freeverb1, 0, mixer2, 0);
    AudioConnection          patchCord9(mixer2, 0, i2s1, 0);
    AudioConnection          patchCord10(mixer2, 0, i2s1, 1);
    AudioConnection          patchCord11(mixer2, 0, usb1, 0);
    AudioConnection          patchCord12(mixer2, 0, usb1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=136,157
    I'd rather put it in a separate audioController.hpp file and use it in audioController.cpp as to organise my project well.
    Last time I've fixed this by passing pointers of all audio instances into the constructor of the audioController.
    Now before starting to work on the audio part of this rather large project I wonder if anyone else has come across this and maybe has a solution for it.
    Thanks in advance
    222
    If audioController.h has the code that you posted, you should be able to include it just fine from main.h or main.cpp for example.
    You shouldn't need to make pointers to something just because it's been moved into a different header file.
    @wcalvert that's what I would expect but it doesn't seem to work.
    Here's my code;
    audioController.hpp
    #pragma once
    #include <Arduino.h>
    class AudioController {
        public:
            AudioController();
            void testSignal();
        private:
            AudioSynthWaveformSine   sine1;          //xy=264,299
            AudioMixer4              mixer1;         //xy=469,316
            AudioOutputI2S           i2s1;           //xy=643,316
    audioController.cpp
    #include "audioController.hpp"
    AudioController::AudioController() {
        AudioConnection          patchCord1(sine1, 0, mixer1, 0);
        AudioConnection          patchCord2(mixer1, 0, i2s1, 0);
        AudioConnection          patchCord3(mixer1, 0, i2s1, 1);
        AudioMemory(10);
        sgtl5000_1.enable();
        sgtl5000_1.volume(0.75);
        sine1.amplitude(1.0);
        sine1.frequency(500);
        mixer1.gain(0,1.0);
    in main.cpp this class is included as follows;
    AudioController audioController;
    This is just some audio code to test and not the final code. I've had it run when everything is in main.cpp, so it should just give a test-tone sine.
    FIXED;
    So I've just fixed it by just putting everything inside audioController.cpp as follows;
        AudioMemory(10);
        mixer1.gain(0,1.0);
    It seems like odd practice to me to init those objects in the .cpp file and outside any functions. So if anyone has something wise to say about that please explain
    222
    One minor suggestion.. when asking for help, please tell us if you're having a compile time problem (and if so, include the error message) or having a runtime problem (and be really specific about the problem).
    The way you posted it before, the patchCords are going out of scope since they are declared in the constructor. You need to move the patchCords to be private members so they stick around.
