Results 1 to 5 of 5
Thread: SD Card Test ->SD card is not connected or unusable :-(
    Oct 2019
    5
    I have teensy 4.0 with Audio Adaptor Board rev D, and the SanDisk Ultra SDHC UHS-I Card 16G with the 4 Wave exemples files in
    I run the sketch: Sd Card Test
    the code of this sketch follows
    And I only got the message :SD card is not connected or unusable :-(
    on the terminal
    Other Sktech work well Like :
    Part_2_03_Samples
    Part_2_08_Oscillators
    4 files on the micro Sd
    the card is formatted fat32
    Here is the code I Upload:
    // SD Card Test
    // Check if the SD card on the Audio Shield is working,
    // and perform some simple speed measurements to gauge
    // its ability to play 1, 2, 3 and 4 WAV files at a time.
    // Requires the audio shield:
    // http://www.pjrc.com/store/teensy3_audio.html
    // Data files to put on your SD card can be downloaded here:
    // http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
    // This example code is in the public domain.
    #define SDCARD_CS_PIN 10
    #define SDCARD_MOSI_PIN 7
    #define SDCARD_SCK_PIN 14
    // Use these with the Teensy 3.5 & 3.6 SD card
    //#define SDCARD_CS_PIN BUILTIN_SDCARD
    //#define SDCARD_MOSI_PIN 11 // not actually used
    //#define SDCARD_SCK_PIN 13 // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN 4
    Sd2Card card;
    SdVolume volume;
    File f1, f2, f3, f4;
    char buffer[512];
    boolean status;
    unsigned long usec, usecMax;
    elapsedMicros usecTotal, usecSingle;
    int i, type;
    float size;
    // wait for the Arduino Serial Monitor to open
    while (!Serial) ;
    delay(50);
    // Configure SPI
    SPI.setMOSI(SDCARD_MOSI_PIN);
    SPI.setSCK(SDCARD_SCK_PIN);
    Serial.println("SD Card Test");
    Serial.println("------------");
    // First, detect the card
    status = card.init(SPI_FULL_SPEED, SDCARD_CS_PIN);
    if (status) {
    Serial.println("SD card is connected :-)");
    Serial.println("SD card is not connected or unusable :-(");
    return;
    type = card.type();
    if (type == SD_CARD_TYPE_SD1 || type == SD_CARD_TYPE_SD2) {
    Serial.println("Card type is SD");
    } else if (type == SD_CARD_TYPE_SDHC) {
    Serial.println("Card type is SDHC");
    Serial.println("Card is an unknown type (maybe SDXC?)");
    // Then look at the file system and print its capacity
    status = volume.init(card);
    if (!status) {
    Serial.println("Unable to access the filesystem on this card. :-(");
    return;
    size = volume.blocksPerCluster() * volume.clusterCount();
    size = size * (512.0 / 1e6); // convert blocks to millions of bytes
    Serial.print("File system space is ");
    Serial.print(size);
    Serial.println(" Mbytes.");
    // Now open the SD card normally
    status = SD.begin(SDCARD_CS_PIN);
    if (status) {
    Serial.println("SD library is able to access the filesystem");
    Serial.println("SD library can not access the filesystem!");
    Serial.println("Please report this problem, with the make & model of your SD card.");
    Serial.println(" http://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports");
    // Open the 4 sample files. Hopefully they're on the card
    f1 = SD.open("SDTEST1.WAV");
    f2 = SD.open("SDTEST2.WAV");
    f3 = SD.open("SDTEST3.WAV");
    f4 = SD.open("SDTEST4.WAV");
    // Speed test reading a single file
    if (f1) {
    Serial.println("Reading SDTEST1.WAV:");
    if (f1.size() >= 514048) {
    usecMax = 0;
    usecTotal = 0;
    for (i=0; i < 1000; i++) {
    usecSingle = 0;
    f1.read(buffer, 512);
    usec = usecSingle;
    if (usec > usecMax) usecMax = usec;
    reportSpeed(1, 1000, usecTotal, usecMax);
    Serial.println("SDTEST1.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST1.WAV on this card");
    return;
    // Speed test reading two files
    if (f2) {
    Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV:");
    if (f2.size() >= 514048) {
    f1.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    f2.read(buffer, 512);
    usec = usecSingle;
    reportSpeed(2, 1000, usecTotal, usecMax);
    Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV staggered:");
    f1.seek(0);
    f2.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    usec = usecSingle;
    Serial.println("SDTEST2.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST2.WAV on this card");
    return;
    // Speed test reading three files
    if (f3) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:");
    if (f3.size() >= 514048) {
    f1.seek(0);
    f2.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    f3.read(buffer, 512);
    usec = usecSingle;
    reportSpeed(3, 1000, usecTotal, usecMax);
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:");
    f1.seek(0);
    f2.seek(0);
    f3.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    usec = usecSingle;
    Serial.println("SDTEST3.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST3.WAV on this card");
    return;
    // Speed test reading four files
    if (f4) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:");
    if (f4.size() >= 514048) {
    f1.seek(0);
    f2.seek(0);
    f3.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    f4.read(buffer, 512);
    usec = usecSingle;
    reportSpeed(4, 1000, usecTotal, usecMax);
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:");
    f1.seek(0);
    f2.seek(0);
    f3.seek(0);
    f4.seek(0);
    usecMax = 0;
    usecTotal = 0;
    usecSingle = 0;
    usec = usecSingle;
    Serial.println("SDTEST4.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST4.WAV on this card");
    return;
    unsigned long maximum(unsigned long a, unsigned long b,
    unsigned long c, unsigned long d)
    if (b > a) a = b;
    if (c > a) a = c;
    if (d > a) a = d;
    return a;
    void reportSpeed(unsigned int numFiles, unsigned long blockCount, unsigned long usecTotal, unsigned long usecMax)
    float bytesPerSecond = (float)(blockCount * 512 * numFiles) / usecTotal;
    Serial.print(" Overall speed = ");
    Serial.print(bytesPerSecond);
    Serial.println(" Mbyte/sec");
    Serial.print(" Worst block time = ");
    Serial.print((float)usecMax / 1000.0);
    Serial.println(" ms");
    Serial.print(" ");
    Serial.print( (float)usecMax / 29.01333);
    Serial.println("% of audio frame time");
    void loop(void) {
    // do nothing after the test
    Nov 2017
    Belgium
    188
    The spi pin definitions in above code are for T3.x and audioshield revC.
    see: https://www.pjrc.com/store/teensy3_audio.html
    Try this
    Oct 2019
    5
    Quote Originally Posted by neurofun View Post
    Try this
    I have try this pin definitions with the same result.
    Nov 2017
    Belgium
    188
    I just successfully ran the SdCardTest sketch on the sd adapter of a rev.C audioshield connected to a T4.0 with the modified spi pin definitions.
    Did you check the connections of pins 10, 11, 12, 13 between the teensy and the auidioshield with a multimeter?
    SD Card Test
    Card type is SDHC
    File system space is 15560.87 Mbytes.
      Overall speed = 0.73 Mbyte/sec
      Worst block time = 1.38 ms
        47.60% of audio frame time
      Overall speed = 0.51 Mbyte/sec
      Worst block time = 3.34 ms
        115.19% of audio frame time
      Worst block time = 2.77 ms
        95.37% of audio frame time
      Overall speed = 0.55 Mbyte/sec
      Worst block time = 5.04 ms
        173.54% of audio frame time
      Worst block time = 3.93 ms
        135.32% of audio frame time
      Overall speed = 0.57 Mbyte/sec
      Worst block time = 6.72 ms
        231.62% of audio frame time
      Overall speed = 0.56 Mbyte/sec
      Worst block time = 4.79 ms
        164.92% of audio frame time
    Oct 2019
    5
    Yes I just did and the connections are OK.
    Maybe it's the SD Card that is not compatible, I did try with 2 others card : a core micro 2gb and a Kinsgten 32 gb without success.
