Results 1 to 2 of 2
Thread: Calculating fuel consumption averages from can bus data
    Sep 2019
    UK
    22
    The challenge:
    To take consecutive readings from bytes 2 and 3 of frame 0x480 of can bus and calculate average fuel consumption. Bytes 2 & 3 give a continuous incremental reading of fuel consumed in microlitres. (Note: the first bit of data is just a marker bit so the data is only 15 bits long).
    Requirements:
    To get accurate timestamp of data
    To keep a rolling average to smooth out data
    To deal with rollover of time and fuel data. e.g. as fuel consumption data is 15 bit it reaches hex 7FFFFFF (dec 32767 ) before rolling back to zero
    Managed so far:
    To obtain continuous output from 0x480 with flexcan timestamp
    Sample data:
    Timestamp-- bin-- dec
    31910-- 111111111101111-- 32751
    41943-- 111111111110100-- 32756
    51976-- 111111111111001-- 32761
    62008-- 111111111111110-- 32766
    6506-- 11-- 3
    16537-- 1000-- 8
    26569-- 1101-- 13
    36602-- 10010-- 18
    46636-- 10111-- 23
    56668-- 11100-- 28
    Code theory:
    	fuel = ((( inMsg.buf[3]&0b01111111)<<8)+inMsg.buf[2]);
    	if fuel2>fuel1
    	fuelused = fuel2-fuel1
    	else fuelused=((fuel2+32767)-fuel1)
    	if time2>time1
    	timediff = time2-time1
    	else timediff=((time2+65535)-time1)
    	fuelrate = (360/timediff)*fuelused
    Question:
    How do I get sequential readings from 0x480 so that I can obtain fuel1, fuel2, time1 & time 2 to then perform my calculation?
    How do I keep a rolling average of the readings to smooth the data?
    Main code for reference:
    void PollEngineCAN(){ //function to poll engine data
      CAN_message_t inMsg;
      if (Can1.available()>0){
          Can1.read(inMsg); //read message into inMsg
          switch ( inMsg.id ) { //a type of if process that can check for multiple conditions
            case 0x280:
              torque = ( inMsg.buf[1]*0.39 );
              rpm = ((( inMsg.buf[3]<<8)+inMsg.buf[2])/4);
              LastRPM=millis(); //timestamp the last rpm reading
            case 0x288:
              coolant = (( inMsg.buf[1]*0.75)+225.15); //convert from C to K (-48 + 273.15 = 225.15)
    //        case 0x480:
    //        if/else required here
    //        e.g. if fuel2>fuel1 then fuelused = fuel2-fuel1 else fuelused=((fuel2+32767)-fuel1)
    //        fuel = ((( inMsg.buf[3]&0b01111111)<<8)+inMsg.buf[2]); //factor into l/h
    //        break;
            case 0x588:
              boost = ( inMsg.buf[4]*1000 ); //convert from bar to Pa (*0.01 x 100,000 = 1000)
    Dec 2016
    Montreal, Canada
    3,701
    Check out the circular buffer example for average() usages
    https://github.com/tonton81/Circular...cal_Values.ino
    Just keep pushing the value in the buffer, and the averages will adjust. The oldest value in the list is rolled over, so no need to purge older values
