Results 1 to 5 of 5
Thread: increment operator bug with globals?
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,238
    int i;
      i=i++;
      Serial.println(i);
    Doesn't increment.
    Ard. 1.8.5/ Td1.48
    578
    That is correct. i++ is a post increment operator. I.e. it increments after the assignment. If you use ++i it should work.
    Anyway, you probably meant i++, instead of the unusual i = i++; ?
    Edit: actually it is undefined behaviour. (see https://stackoverflow.com/a/949443/1842762)
    Feb 2013
    1,238
    Right. Bone-head
    I knew it works with locals but that's 'cause I use correctly there.
    Apr 2017
    Florida
    424
    What would be the reasoning behind using i=i++ as opposed to just i++? For pointers I understand the difference, but I’m lost as far as regular variables go.
    Feb 2013
    1,238
    Bone-head is the reason... I should think a bit before posting
