Results 1 to 14 of 14
Thread: Troubleshooting trying to get MIDI out to work..
    Nov 2019
    5
    I want to send Midi data through a 5-pin Din connector with Teensy LC. I attached a 47 ohm resistor 0.25w 5% on both pin 1(TX) and 3.3v. And i have ground connected to the middle DIN pin (have tested it, ground is there) I have double checked the schematic as to which pins on the DIN connector to connect them to and they seem to be accurate, like the pins aren't wrongly attached... I was thinking maybe 5% resistance might be the problem, like its too much? But I wanted to ask to see if someone knew. I tried using the example BASIC_IO from the arduino MIDI library and testing with a midi cable connected to an instrument capable of receiving midi (2 different instruments actually, which i have tested and they can receive midi sent from each other so I know the problem isnt on their side, but with the DIN jack or maybe something else on the Teensy side). I was unsuccessful using the example i also tried the one on the Midi Arduino page, unsuccessful as well.
    Does any 5-pin DIN connector work as a Midi jack or is there a specific kind?
    The code is for a midi bass pedal project (another one). I want the Teensy to be able to send both Midi from the DIN connector and usbMidi. (usbMidi works, have tested, just not the DIN midi):
    HTML Code:
    #include <MIDI.h>
    MIDI_CREATE_DEFAULT_INSTANCE();
    #define DEBOUNCE 1500
    struct key
      int pin;
      int midiKey;
      int debounce;
    struct key keys[] =
      { 2, 24, 0 },  // C  brown
      { 3, 25, 0 },  // Db red
      { 4, 26, 0 },  // D  red
      { 5, 27, 0 },  // Eb orange
      { 6, 28, 0 },  // E  orange
      { 7, 29, 0 },  // F  yellow
      { 8, 30, 0 },  // Gb green
      { 9, 31, 0 },  // G  green
      { 10, 32, 0 },  // Ab blue
      { 11, 33, 0 },  // A  blue
      { 12, 34, 0 },  // Bb violet
      { 13, 35, 0 },  // B  violet
      { A0, 36, 0 },  // high C  brown
      { 0, 0, 0 }     // end of list marker
    const int octaveUp_button_pin = A2;
    const int octaveDown_button_pin = A3;
    const int velpin = A1;
    int octave = 0;
    int octave_prev = 0;
    int octaveUp_Button_Voltage = 0;
    int octaveDown_Button_Voltage = 0;
    int last_octaveUp_Button_Voltage = 0;
    int last_octaveDown_Button_Voltage = 0;
    int time1;
    int time2;
    int interval;
    bool velpin_state = {true};
    bool velpin_prev_state = {true};
    int channel = 3;
      for (int i = 0; keys[i].pin != 0; ++i)
        pinMode(keys[i].pin, INPUT_PULLUP);
      pinMode(octaveUp_button_pin, INPUT_PULLUP);
      pinMode(octaveDown_button_pin, INPUT_PULLUP);
      pinMode(velpin, INPUT_PULLUP);
      MIDI.begin(3);
      Serial.begin(9600);           // set up Serial library at 9600 bps
      Serial.println("Setup complete");
      millis();
    void noteOn(int midiKey)
      Serial.print("Note On: ");
      Serial.println(midiKey);
    void noteOff(int midiKey)
      Serial.print("Note Off: ");
      MIDI.sendNoteOff(midiKey + octave, 0, channel);
      usbMIDI.sendNoteOff(midiKey + octave, 0, channel);
      //determine octave
      if (octave > octave_prev) {
        //    midiInst.sendControlChange(AllNotesOff, 0,  channel);
        for (int i = 0; keys[i].pin != 0; ++i) {
          noteOff(keys[i].midiKey + octave - 12);
        } octave_prev = octave;
        if (octave < octave_prev) {
            noteOff(keys[i].midiKey + octave + 12);
          octaveUp_Button_Voltage = digitalRead(octaveUp_button_pin);
          // compare the buttonState to its previous state
          if (octaveUp_Button_Voltage != last_octaveUp_Button_Voltage) {
            // if the state has changed, increment the counter
            if (octaveUp_Button_Voltage == LOW) {
              // if the current state is HIGH then the button went from off to on:
              if (octave < 24) {
                octave += 12;
                Serial.println("Octave Up +1 ");
                Serial.print("(Transpose + ");
                Serial.print(octave);
                Serial.println(")");
              // if the current state is LOW then the button went from on to off:
            // Delay a little bit to avoid bouncing
            delay(50);
          // save the current state as the last state, for next time through the loop
          last_octaveUp_Button_Voltage = octaveUp_Button_Voltage;
          // read the pushbutton input pin 2:
          octaveDown_Button_Voltage = digitalRead(octaveDown_button_pin);
          if (octaveDown_Button_Voltage != last_octaveDown_Button_Voltage) {
            if (octaveDown_Button_Voltage == LOW) {
              if (octave > -24) {
                octave -= 12;
                Serial.println("Octave Down -1 ");
                Serial.print("Transpose + ");
            delay(50);
          last_octaveDown_Button_Voltage = octaveDown_Button_Voltage;
          int value;
            value = digitalRead(keys[i].pin);
            if (keys[i].debounce == 0) // Key has been off
              if (value == HIGH)       // Key is now on
                time1 = millis();
                Serial.println(time1);
                keys[i].debounce = DEBOUNCE;  // Set the note off debounce counter
            else                      // Key has been on
              if (value == LOW)      // Key has gone off
                if (--keys[i].debounce == 0) // If Key has remained off for DEBOUNCE scans,
                  noteOff(keys[i].midiKey + octave);
              else                    // Key has not gone off
                keys[i].debounce = DEBOUNCE;  // Reset debounce counter in case we got
              // a small number of key off scans
              velpin_state = digitalRead(velpin);
              if (velpin_state != velpin_prev_state)
                if (velpin_state == LOW)
                  time2 = millis();
                  Serial.println(time2);
                  interval = time2 - time1;
                  Serial.print("interval: ");
                  Serial.println(interval);
                  velocity = map(interval, 0, 700, 127, 0);
                  if (velocity < 0) {
                    velocity = 0; }
                  Serial.print("Velocity = ");
                  Serial.println(velocity);
                  noteOn(keys[i].midiKey + octave);      // Send the MIDI note on message
                  MIDI.sendNoteOn(keys[i].midiKey + octave, velocity, channel);
                  usbMIDI.sendNoteOn(keys[i].midiKey + octave, velocity, channel);
              velpin_prev_state = velpin_state;
    20,806
    I don't know what's wrong, but I can try to quickly answer these 2 questions.
    5% is perfectly fine.
    Any connector which mates properly and reliably connects to the 2 pins needed by MIDI should work.
    Even though you've double checked everything, sharing photos here might help. If we can see how you really connected everything, maybe someone will notice any issue?
    About 1 week ago there was a similar MIDI question. Looking at the photo, it turned out the resistor color wasn't right and it was actually a pair of 47K resistors instead of 47 ohm. Misunderstanding about which 2 pins to use on the DIN connector are a common problem. It's really easy to get them swapped if you look at a diagram for the front side while soldering wires to the back side.
    1,176
    Which pin are you using as the MIDI output? The MIDI library defaults to using the Serial1 Tx pin (pin 1). But also, that basic example will only send a midi note if it receives one.
    Try this code which continuously plays a midi note for one second and then off for one second - I know this works.
    #include <MIDI.h>
    // Simple tutorial on how to receive and send MIDI messages.
    // Here, when receiving any message on channel 4, the Arduino
    // will blink a led and play back a note for 1 second.
    static const unsigned ledPin = 13;      // LED pin on Arduino Uno
        pinMode(ledPin, OUTPUT);
        MIDI.begin(4);                      // Launch MIDI and listen to channel 4
    //    if (MIDI.read())                    // If we have received a message
            digitalWrite(ledPin, HIGH);
            MIDI.sendNoteOn(42, 127, 1);    // Send a Note (pitch 42, velo 127 on channel 1)
            delay(1000);		            // Wait for a second
            MIDI.sendNoteOff(42, 0, 1);     // Stop the note
            digitalWrite(ledPin, LOW);
    Pete
    Nov 2019
    5
    I found out they are actually 47kohm...
    So do you think that is the reason it wasn't working?
    1,176
    Almost certainly. Change them and see.
    Pete
    Nov 2019
    5
    I now have 47 ohm resistors on both non-ground pins on the midi/din connector. Still not receiving any MIDI data...I tried the code you posted too. I have received usbMIDI from the Teensy just not regular midi from the din connector...another thing I thought is: the 3.3v pin i am using is the one next to pin 23(A9). Could that be the reason?
Name:	Photo on 11-23-19 at 4.42 AM #2n.jpg
ID:	18248Click image for larger version.
Name:	Photo on 11-23-19 at 4.43 AM.jpg
    Apr 2017
    Florida
    421
    Are these pictures reversed from your webcam, based on the resistor photo it looks like it. If so then you have it wired backwards, hereís a photo from sparkfun that may help your orientation:
    Pin 5 is TX
    Pin 4 is 3.3v
    Pin 2 is shield/ground
    Nov 2019
    5
    sorry that photo made things more confusing. I have tried them both ways...currently have them attached to the pins indicated by the sparkfun photo.
    Nov 2017
    Belgium
    156
    @rusty113
    I could be wrong but looking at your first picture it seems your didn't solder the wires to the resistors. If so, how do you expect it to work?
    Aug 2019
    Melbourne Australia
    36
    Something like this is handy in the toolkit.
    Nov 2019
    5
    that looks useful. Did you make it?
    I thought that the wires just needed to be making contact for it to work...i didn't solder it yet because i am planning on putting it in a enclosure
    Apr 2017
    Florida
    421
    That would be especially useful if it had a bi-color LED so it would light up a different color when itís wired backwards, the circuitry is the exact same that you already have built just using a bi-color LED like this:
    Apr 2017
    Florida
    421
    As long as your wires have a solid connection you can get away without soldering for prototyping, I typically use alligator clips so I know the connection has some strength to it. If your Teensy is on a breadboard and you have an LED it’s easy enough to connect it straight to the TX pin to verify activity, you could also do a simple loop back test by connecting TX to RX on the Teensy without any other circuitry.
    Nov 2017
    Belgium
    156
    Quote Originally Posted by rusty113 View Post
    Physical contact does not mean electrical contact. There might be some glue residue from the paper tape at the extremities of the resistor legs.
