Results 1 to 6 of 6
Thread: String toDouble not working on Teensy?
    Dec 2016
    Buena Park ca
    73
    Is that true?
    I tried newX = newX_St.toDouble(); and I got a "No class member toDouble"
    Too bad I need the precision,
    I tried the next best thing, ToFloat and it works.
    BUT:
    I can not use the modulo in a float.
    Why not?
    Tried:
    new_Th = newTh_St.toFloat();
    new_Th = new_Th % 90.00;
    and I get:
    invalid operands of types 'float' and 'float' to binary 'operator%'
    It worked fine as an integer, but I need the precision.
    Please help.
    Mitch
    5,967
    Sorry it may help me and others to help you, if you showed a complete example, for example what are new_Th and newTS_St defined as?
    Dec 2016
    Buena Park ca
    73
    I defined them as doubles, but was impossible to convert from string.
    I also tried define them as Floats, but the modulo operand did not work.
    TNKS
    1,195
    In C/C++, the remainder % operator is only defined for use when both operands are integers. You could calculate it yourself for floating point operands and I presume you could even define an overload for the % operator.
    Pete
    To convert a c-string to double try using atof() function. Also %-operator doesn't work with floats (only ints like you found out) but you should use fmod() function
    Dec 2016
    Buena Park ca
    73
    Thanks everyone
    fmod worked really nice
    new_Th= fmod (new_Th,90); // first is the Number and second is the Factor
    I did not have to ad any library, just added
    #include "math.h". at the top, that has it
