Results 1 to 3 of 3
Thread: AnalogReadRes() Unexpected Behaviour
    Nov 2019
    2
    Quick into: been loving Teensy for a couple years (5x boards, T3.2, T3.5, T4.0), doing various things with analog and digital sensors, LCD screens and relays/SSRs. My background is ME, but I've been tinkering with Arduino since 2008ish.
    Issue: I'm exploring analogReadRes() on a T4.0, and getting very odd results. In void loop() I increment analogReadRes() from 6 to 16 by 1, and cycle at 2Hz, with a basically constant input voltage. Results sent to serial monitor are mostly a long way from expected. I've searched/read this and other forums for over an hour, and consulted an EE friend, all verifying my understanding and resultant confusion.
    Details: hardware: T4.0 with Adafruit phototransistor collector connected to 3v3 upper right pin, emitter connected to A9 / 24k Ohm resistor, which is connected to G (upper right pin). Over 10sec, a DMM shows voltage at A9 varies between 3.1629V to 3.1634V (0.008%)
    Details: code: from Arduino IDE 1.8.9, using Teensyduino 1.48-beta1 (don't judge the coding. It's very simple, evolved from the first unexpected discovery and could/should be much more efficiently done. It is valid though, I believe.)
    #define lsPin A9
      analogReadAveraging(32);   //testing aReadAvg function
      uint32_t digitsTest = 65535;  // checking for roll-over or other variable size badness
      Serial.println(digitsTest);
      Serial.println("6\t7\t8\t9\t10\t11\t12\t13\t14\t15\t16");  // header
      analogReadRes(6);
      Serial.print(analogRead(lsPin)); Serial.print("\t");
      analogReadRes(7);
      analogReadRes(8);
      analogReadRes(9);
      analogReadResolution(10);
      analogReadResolution(11);
      analogReadResolution(12);
      analogReadResolution(13);
      analogReadResolution(14);
      analogReadRes(15);
      analogReadResolution(16);
      Serial.println(analogRead(lsPin));
    Details: analysis: Theory would suggest the following outputs: (sorry, can't make the table justify correctly )
    Res 6 7 8 9 10 11 12 13 14 15 16
    Max Counts 63 127 255 511 1023 2047 4095 8191 16383 32767 65535
    V_ref 3.2987
    V 3.1630 60 121 244 489 980 1962 3926 7854 15709 31419 62839
    but here's what i get:
    65535
    Teensy Output 6 7 8 9 10 11 12 13 14 15 16
    t=000ms 3934 3934 245 3934 983 3934 3934 3934 3935 3934 3934
    t=500ms 3934 3935 245 3934 984 3934 3934 3934 3934 3934 3934
    t=1000ms 3934 3933 246 3934 983 3935 3934 3936 3933 3934 3933
    t=1500ms 3932 3935 245 3934 983 3935 3934 3935 3934 3933 3933
    Read Error 3874 3813 1 3445 3 1973 8 -3919 -11775 -27485 -58906
    Everything I read (both Arduino and Teensy reference and forum sources) indicates I should be able to set from 1 to 16 bit resolution, and get the correctly scaled ADC count. The results above seem to indicate that I can only use 8, 10 and 12 bit resolution. I welcome another clear illustration of my (well established) stupidity, but please include a bit of edumacation, just to ward off a few more forehead bruises
    2,297
    Yep, read the T4 reference manual ch 65 (ADC), only 8, 10, 12 bit are supported -- also view core source at hardware/teensy/avr/cores/teensy4/analog.c
    Paul has warned that maybe only 10 bits are good, see https://forum.pjrc.com/threads/57911-Teensy-4-0-ADC
    Reference https://www.pjrc.com/teensy/datasheets.html
    Nov 2019
    2
    Thanks Manitou. That answers it fully. I expected something along the lines of a failure to read error on my part You definitely nailed it - I fizzled out around section 4.3 in that spec sheet once I found out just how delicate the drive is for pins (9mA won't drive my 15mA SSRs :/ ) and I didn't see the message you linked in my searches.
    Nice quick response, thank you.
