Results 1 to 12 of 12
Thread: MIDI Message Toggle in Code
    Nov 2019
    Johnson City TN
    10
    I'm trying to create a momentary button that will alternate/toggle between two fixed MIDI messages in code.
    I'm using the Bounce Library and would like to use either Falling or Rising edge to trigger this alternating behavior.
    The code i've got is just sending a continuous stream of alternating note numbers. My programming knowledge is
    pretty limited but trying to learn along the way. Any suggestion or guidance is greatly appreciated.
    // Button Toggle In Code
    #include <Bounce.h>
    const int channel = 1;
    int StateOne = HIGH;
    int StateTwo = HIGH;
    int toggleState = HIGH;
    Bounce button0 = Bounce(0, 10);
      pinMode(0, INPUT_PULLUP);
      button0.update();
      if(button0.fallingEdge() != StateTwo && StateOne == 1 && toggleState == 0) {
        usbMIDI.sendNoteOn(60, 99, channel);
        toggleState = 1;
       else if(button0.fallingEdge() != StateTwo && StateOne == 1 && toggleState == 1); {
        usbMIDI.sendNoteOn(61, 99, channel);
        toggleState = 0;
      while (usbMIDI.read()) {
    Apr 2017
    Florida
    457
    Does it only send a stream when pressing the button or constantly?
    Nov 2019
    Johnson City TN
    10
    Hi Vj,
    Thanks so much for chiming in here. It appears to start streaming as soon as the sketch starts. I'm watching the output with MIDI monitor.
    Nov 2017
    Belgium
    188
    What about this?
    #include <Bounce.h>
      if(button0.update()){
        if(button0.fallingEdge()){
          usbMIDI.sendNoteOn(60, 99, channel); //midi on fallingEdge
        }else{
          usbMIDI.sendNoteOn(61, 99, channel); //midi on risingEdge
      while (usbMIDI.read()) {}
    Apr 2017
    Florida
    457
    Delete this part from the if statements and it should work:
    != StateTwo
    .fallingEdge() returns true if it’s a falling edge so you shouldn’t test if it’s not high.
    Nov 2019
    Johnson City TN
    10
    Hi Neuro,
    thanks for the reply and code .... nice little snippet for sure !! .. but, I'm hoping to toggle/alternate using only fallingEdge or risingEdge .. if that makes sense?
    Nov 2019
    Johnson City TN
    10
    Hi VJ,
    trying this now ... Still continuous stream but a single note number ...
    1,197
    Get rid of StateOne, StateTwo and toggleState.
      if(button0.fallingEdge()) {
       if(button0.risingEdge()) {
    Note also that I got rid of a bug in your code:
    The semicolon shouldn't be there.
    Pete
    Nov 2019
    Johnson City TN
    10
    Hey Pete !
    Thanks for the corrections .... I'm looking to get this behavior at each fallingEdge if that makes sense ? ... so fallingEdge, Note 60 Next fallingEdge Note 61.
    Nov 2017
    Belgium
    188
    Quote Originally Posted by digitalelements View Post
    Hi Neuro,
    oops, misunderstood the question.
    correction:
    #include <Bounce.h>
    bool toggleState = false;
      if(button0.update() && button0.fallingEdge()){
        if(!toggleState){
          toggleState = true;
        }else{
    Apr 2017
    Florida
    457
    This should do the trick:
    #include <Bounce.h>
    boolean toggleState = HIGH;
      button0.update();
        if(toggleState) usbMIDI.sendNoteOn(60, 99, channel);
        else usbMIDI.sendNoteOn(61, 99, channel);
        toggleState = !toggleState;
    I haven't tested it, but it compiles and the logic looks right to me.
    Nov 2019
    Johnson City TN
    10
    Ahhhhhh ... thank you very much ... Both solutions ( Neuro & VJ ) are working as I had hoped.
