Hi guys, i'm trying to control a led matrix of ws2812 with a teensy.
I wanted to reuse crees's code to control my matrix through sacn packets but at the moment i don't have an ethernet shield.
So i've tried to use esp8266. The idea is to receive udp packets with the esp8266 and then send them to the teensy using serial transmission with this code:
UDPSendReceive.pde:
This sketch receives UDP message strings, prints them to the serial port
and sends an "acknowledge" string back to the sender
A Processing sketch is included at the end of file that can be used to send
and received messages for testing with a computer.
created 21 Aug 2010
by Michael Margolis
This code is in the public domain.
adapted from Ethernet library examples
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#ifndef STASSID
#define STASSID ""
#define STAPSK ""
unsigned int localPort = 5568; // local port to listen on
// buffers for receiving and sending data
byte packetBuffer[638]; //buffer to hold incoming packet,
WiFiUDP Udp;
Serial.begin(500000);
pinMode(D2, INPUT);
WiFi.mode(WIFI_STA);
WiFi.begin(STASSID, STAPSK);
while (WiFi.status() != WL_CONNECTED) {
Serial.print('.');
Serial.print("Connected! IP address: ");
Serial.println(WiFi.localIP());
Serial.printf("UDP server on port %d\n", localPort);
Udp.begin(localPort);
// if there's data available, read a packet
//Serial.write(digitalRead(D2));
if (!digitalRead(D2)){
int packetSize = Udp.parsePacket();
if (packetSize) {
int n = Udp.read(packetBuffer, 638);
Serial.write(packetBuffer,638);
// E1.31 Receiver and pixel controller by Chris Rees (crees@bearrivernet.net) for the Teensy 3.2 This code was modified from
// Andrew Huxtable base code. (andrew@hux.net.au)
// This code may be freely distributed and used as you see fit for non-profit
// purposes and as long as the original author is credited and it remains open
// source
// Please configure your Lighting product to use Unicast to the IP the device is given from your DHCP server
// Multicast is not currently supported at the moment
// You will need the, Teensy utility installed with the added Ethernet One Socket and FastLed Libraries from:
// https://www.pjrc.com/teensy/teensyduino.html
// https://github.com/mrrees/MegaPixel-One-Socket-Ethernet
// https://github.com/FastLED/FastLED/releases
// Please note the one socket library may throw errors in compiling. The error was in realation to the chip speed detection and using the
// correct SPI speed.
// The Teensy with the Octows2811 and FastLED will allow up to 5440 Pixels (32 Universes) to run. One thing to note is if you desire
// high frame rates your pixel count must not exceed over 680 Pixels per Octo Pin. The reason why is the ammount of time to write out to
// these LED's takes time to shift from one LED to the next. The more LED's per SPI or Octo Pin the more time it takes and the less frame
// rate you will acheive. In the Pixel Controller Wolrd 680 per SPI port is the desired balance. For the Teensy this is a perfect balance
// any more pixels and memory starts to become an issue. Those who whish to push more pixels per port can do so but must sacrifice the
// fastLED and or Octows2811 libraries to free up buffer space.. but your on your own and we welcome you to share your improved methods
// with the community!
// in the code structure there is some serial feedback. Please note enableing serial feedback will interrupt with the pixel performance
// and will slow it down. use only for debugging and omit during production run.
#define USE_OCTOWS2811
#define HWSERIAL Serial1
#include<OctoWS2811.h>
#include<FastLED.h>
#include <EEPROM.h>
// enter desired universe and subnet (sACN first universe is 1)
#define DMX_SUBNET 0
//#define DMX_UNIVERSE 1 //**Start** universe
// Set a different MAC address for each controller IMPORTANT!!!! you can change the last value but make sure its HEX!...
//DEFINES for at Compile time.
//Leave this alone. At current a full e1.31 frame is 636 bytes..
#define ETHERNET_BUFFER 636 //540 is artnet leave at 636 for e1.31
#define NUM_LEDS_PER_STRIP 680 //170
#define NUM_STRIPS 1
///GLOBALS
int a = 0;
int unsigned DMX_UNIVERSE = 1; //**Start** universe 1, 9, 17, 25, 33, 41
int unsigned UNIVERSE_COUNT = 2; //How Many Universes 8, 8, 8, 4, 8, 8
int unsigned UNIVERSE_LAST = 2; // List the last universe typically its sequencially from start but does not have to. 8, 16, 24, 28, 32, 40
int unsigned CHANNEL_COUNT = 510; //max channels per dmx packet
byte unsigned LEDS_PER_UNIVERSE = 170; // Max RGB pixels
int unsigned NUM_LEDS = UNIVERSE_COUNT * LEDS_PER_UNIVERSE; // with current fastLED and OctoWs2811 libraries buffers... do not go higher than this - Runs out of SRAM
// BEGIN Dont Modify unless you know what your doing below
// Define the array of leds
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
// Pin layouts on the teensy 3:
// OctoWS2811: 2,14,7,8,6,20,21,5
unsigned char packetBuffer[ETHERNET_BUFFER];
int c = 0;
float fps = 0;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
//SD CARD INITIALIZE
pinMode(10, OUTPUT); // For SD Card Stuff
//digitalWrite(10, HIGH); // de-select WIZ820io
//pinMode(4, OUTPUT); //SD Card Stuff
//digitalWrite(4, HIGH); // de-select the SD Card
digitalWrite(10, LOW);
//Serial Port Stuff
HWSERIAL.begin(500000);
delay(10);
// Using different LEDs or colour order? Change here...
LEDS.addLeds<OCTOWS2811>(leds, NUM_LEDS_PER_STRIP);
LEDS.setBrightness(50); //value should be 0-255 Very Bright after 100 default is 50 to save on current and eyes!
Serial.print("red");
//pins 3,4,22 are to the RGB Status LED
//Ethernet.init(1); //-> 1 Socket with 16k RX/TX buffer for ethernet3
//Once the Ethernet is initialised, run a test on the LEDs
initTest();
static inline void fps2(const int seconds){
// Create static variables so that the code and variables can
// all be declared inside a function
static unsigned long lastMillis;
static unsigned long frameCount;
static unsigned int framesPerSecond;
// It is best if we declare millis() only once
unsigned long now = millis();
frameCount ++;
if (now - lastMillis >= seconds * 1000) {
framesPerSecond = frameCount / seconds;
Serial.print("FPS @ ");
Serial.println(framesPerSecond);
frameCount = 0;
lastMillis = now;
static inline void pixelrefresh(const int syncrefresh){
static unsigned long frametimestart;
static unsigned long frametimeend;
static unsigned long frametimechk;
static unsigned long frameonce;
unsigned long now = micros();
//start frame time
frametimestart = now;
//Serial.println(frametimechk)
//If we have framed no need to frame again update time to most recent
if (syncrefresh == 1){
frametimeend = frametimestart;
frameonce = 1;
//If we havent framed this will increment via time and at some point will be true,
//if so we need to frame to clear out any buffer and the hold off untill
//we receive our next valid dmx packet. We use the pixel protocol to get a general rule of timing to compare to.
frametimechk = frametimestart - frametimeend;
// num leds time 30us + 300us reset to simulate the time it would take to write out pixels.
//this should help us not loop to fast and risk premature framing and jeopordize ethernet buffer
if (frametimechk >= (NUM_LEDS * 30) + 300){
if (frameonce == 1){
LEDS.show();
Serial.println ("Partial framing detected");
frameonce = 0;
void sacnDMXReceived(unsigned char* pbuff, int count) {
static unsigned long uniloopcount;
if (count > CHANNEL_COUNT) count = CHANNEL_COUNT;
byte b = pbuff[113]; //DMX Subnet
if ( b == DMX_SUBNET) {
b = pbuff[114]; //DMX Universe
//Serial.print("uni");
//Serial.println(b);
byte s = pbuff[111]; //sequence
static unsigned long ls; // Last Sequence
if (s > ls){
uniloopcount = 0;
ls = s;
//turn framing LED OFF
//Serial.print("UNI ");
//Serial.println(count );
if ( b >= DMX_UNIVERSE && b <= UNIVERSE_LAST) {
if ( pbuff[125] == 0 ) { //start code must be 0
int ledNumber = (b - DMX_UNIVERSE) * LEDS_PER_UNIVERSE;
// sACN packets come in seperate RGB but we have to set each led's RGB value together
// this 'reads ahead' for all 3 colours before moving to the next led.
for (int i = 126;i < 126+count;i = i + 3){
byte charValueR = pbuff[i];
byte charValueG = pbuff[i+1];
byte charValueB = pbuff[i+2];
leds[ledNumber] = CRGB(charValueR,charValueG,charValueB); //RBG GRB
ledNumber++;
uniloopcount ++;
//Serial.print("UNILOOP");
//Serial.println(uniloopcount);
//if (b == UNIVERSE_LAST){
if (uniloopcount >= UNIVERSE_COUNT){
//Turn Framing LED ON
digitalWrite(4, LOW);
LEDS.show();
pixelrefresh(1);
uniloopcount = 0;
//Frames Per Second Function fps(every_seconds)
fps2(5);
int checkACNHeaders(unsigned char* messagein, int messagelength) {
//Do some VERY basic checks to see if it's an E1.31 packet.
//Bytes 4 to 12 of an E1.31 Packet contain "ACN-E1.17"
//Only checking for the A and the 7 in the right places as well as 0x10 as the header.
//Technically this is outside of spec and could cause problems but its enough checks for us
//to determine if the packet should be tossed or used.
//This improves the speed of packet processing as well as reducing the memory overhead.
//On an Isolated network this should never be a problem....
if ( messagein[1] == 0x10 && messagein[4] == 0x41 && messagein[12] == 0x37) {
int addresscount = (byte) messagein[123] * 256 + (byte) messagein[124]; // number of values plus start code
//Serial.print("frameok - ");
//Serial.print(messagein[114]);
//Serial.println(addresscount);
if (addresscount > 513) {
HWSERIAL.clear();
return 0;
return addresscount -1; //Return how many values are in the packet.
HWSERIAL.clear();
return 0;
void initTest() //runs at board boot to make sure pixels are working
LEDS.showColor(CRGB(255, 0, 0)); //turn all pixels on red
LEDS.showColor(CRGB(0, 255, 0)); //turn all pixels on green
Serial.print("resd");
LEDS.showColor(CRGB(0, 0, 255)); //turn all pixels on blue
Serial.print("r3d");
LEDS.showColor(CRGB(0, 0, 0)); //turn all pixels off
//Process packets
if (HWSERIAL.available() > 0) {
packetBuffer[a] = HWSERIAL.read();
a++;
if(a == 638){
Serial.println("a=638");
Serial.println(packetBuffer[1]);
int count = checkACNHeaders(packetBuffer, 638);
if (count) {
sacnDMXReceived(packetBuffer, count); //process data function
a=0;
//pixelrefresh(0);
And i have another if that checks the length of the packet inside of checkACNHeaders function.
It seems to work for 2-3 seconds, then i encounter sync problems: the teensy can't recreate the packet in the same order because it probably misses some bytes so discards the packet.
This produces a random stutter in the animation of 2-3 seconds.
I know that my implementation is really simple, but is the sync problem solvable using serial or i need to use some other communication protocol?
