Results 1 to 4 of 4
Thread: extend Queue object for Teensy 4.0 to more blocks
    Senior Member DD4WH's Avatar
    Oct 2015
    Central Europe
    516
    There was a need for more audio blocks to be queued in my Teensy 4.0 SDR project in order to use larger FFT sizes for steeper filtering [I needed 64 blocks of 128 samples at each time for processing].
    So I modified:
    record_queue.h and record_queue.cpp in the audio lib which have the hard-coded restriction of 53 blocks.
    Would it make sense to increase the number of blocks permanently in the next version of Teensyduino for the Teensy 4.0 ? Memory is not a serious issue for the T4.0 with 64 blocks. [AFAIK the AudioMemory uses DMAMEM in T4 ?]
    If yes, I could try to do a pull-request (if my git skills allow that, not sure . . .)
    Germany NRW
    5,943
    Quote Originally Posted by DD4WH View Post
    So I modified:
    Yes, definitely!
    21,135
    I've committed larger queue limits on github. It will be in 1.49-beta4.
    https://github.com/PaulStoffregen/Au...f0dcc62a95d2fa
    2,478
    As I usually use most ram for data queue, I modified recordQueue to use Template arguments and include class implementation in an include file.
