Results 1 to 7 of 7
Thread: Teensey 3.6 Native USB Host
    Nov 2019
    3
    Good morning all! I am trying to determine a library to use with the teensey 3.6 USB. I don't want to use the host shield for space reasons. I am struggling to find one that works with Xbox remotes and/or PS remotes. Does the USB Host Shield library support native USB? Thanks in advance.
    Apr 2017
    Florida
    457
    This is the library you want to use with the second USB port for host functions: https://github.com/PaulStoffregen/USBHost_t36
    I believe it already has support for Xbox and PS controllers.
    Nov 2019
    3
    Ok thanks. So the USB host shield library doesn't support it alone?
    Apr 2017
    Florida
    457
    You don’t need a shield so the library doesn’t apply to this.
    Nov 2019
    3
    Ok thanks! I'll take a look!
    Apr 2017
    Florida
    457
    USB controllers: https://forum.pjrc.com/threads/49099...Host-Joysticks
    Bluetooth controllers: https://forum.pjrc.com/threads/49358...Host-Bluetooth
    Looks like they work already.
    10,409
    @xman4242 - looking at this page shows what is needed for T_3.6's host function hardware connect: https://pjrc.com/store/cable_usb_host_t36.html
    Other cables the same - but that gets the hardware Native USB Host to a usable connection to plug in a simple device or to a Hub ( ideally powered to drive high current devices ). The USB Host device is on the Teensy processor and the T_3.6 board has some needed power control hardware to provide robust function - as long as the attached device can share and work off the power provided to the T_3.6.
    Given that hardware connectivity the indicated USBHost_T36 provides the software library that is common to T_3.6 and the T_4. The smaller T4 board doesn't have the robust support chips the T_3.6 does - and the Host pads are underside not brought out the same. This is noted because during the Teensy 4.0 beta there was a great deal of work and progress on USB Host support - so anything that works on one works on the other.
