Results 1 to 4 of 4
Thread: Teensy 3.1, i2c and raspberry pi (4)
    The raspberry pi (at least version 3 and older) has this problem with clockstretching in i2c. Communication then doesn't work with the avr arduino (maybe other arduinos as well, have not tried yet).
    Now I'm looking for an MCU that can be programmed in the Arduino environment (because of availability of all those libraries) with which i2c to the raspberry pi works fine (note: HARDWARE i2c, not the software/emulated i2c).
    Is this possible with Teensy 3.1?
    Regards
    Never mind, I should've done more googling first.
    20,813
    In case anyone finds this question later by search, I2C clock stretching is supported on all Teensy 3.x and 4.0 boards.
    But there is a timeout which limits the maximum clock stretch, so a hung or crashed I2C device can't cause your program to stall indefinitely.
    Good point.
    I'd like to add that i2c with RPI 3 and earlier probably won't work due to the clock-stretching, but from what I've heard (but not verified yet) the rpi4 should be fine.
