Results 1 to 23 of 23
Thread: Using Teensy 3.5 Built-in SD card reader for data acquisition
    Nov 2019
    13
    Hi, I am trying to use Teensy 3.5 to write data that I acquire from two sensors (encoder and an EMG). I found that there are previous forum mentioning about this too and I've also tried it. I tried changing the code from the forum. It does made new file in my SD card but the data sensor isn't saved, so basically it's just an empty csv data.
    I use the SdFat library.
    This is the code
    #include <SdFat.h>
    #define outputA 5
    #define outputB 6
    #define RawEMG A0
    #define MaxCount 10000
    int counter = 0;
    int derajat = 0;
    int EMG;
    int aState;
    int aLastState;
    SdFatSdio sd;
    File file;
      pinMode (outputA, INPUT_PULLUP);
      pinMode (outputB, INPUT_PULLUP);
      //Reads the initial state of the outputA
      aLastState = digitalRead(outputA);
      if (!sd.begin()) {
        sd.initErrorHalt();
    void doLogging(uint32_t timeStamp, int *data1,int *data2, int *data3, int nb)
      // following is for logging
      static uint32_t ifl = 0;
      static uint32_t count = 0;
      char filename[32];
      if(!count)
         //open file
         sprintf(filename,"Data.csv",ifl); ifl++;
         if (!file.open(filename, O_RDWR | O_CREAT)) {
           sd.errorHalt("open failed");
         count=1;
      if(count>0)
        // write to file
        file.print(timeStamp);
        for(int ii=0; ii<nb; ii++)
        { file.print(',');
          file.print(data1[ii]);
          file.print(',');
          file.print(data2[ii]);
          file.print(',');
          file.print(data3[ii]);
        file.println();
        count++;
        if(count>MaxCount) count=0;
      if(!count)
         // close file
         file.close();
      uint32_t t0 = millis();
      EMG = analogRead(RawEMG); //reads EMG sensor
      //float EMG = EMG * (5.0 / 1023.0);
      aState = digitalRead(outputA); //reads the 'current' state of the outputA
      //if outputB state is different to the outputA state, that means the encoder is rotating clockwise
      if (aState != aLastState){
        if (digitalRead(outputB) != aState){
          counter ++;
          counter --;
        if (counter > 2048 or counter < -2048) //omron sebelumnya 1200 yang 600ppr, resolusi x 2
          counter = 0;
        derajat = counter * 360/2048;
       aLastState = aState;
       Serial.print(counter);
       Serial.print(",");
       Serial.print(derajat);
       Serial.print(",");
       Serial.println(EMG);
      doLogging(t0,&counter, &derajat, &EMG,1); //insert data (?)
    Is there anything wrong with it? How can I make it work? I think there's something wrong with the dologging void but I'm not entirely sure how to work my way around. Please help me, thank you.
    2,447
    I would first apply the following change
    //open file
         sprintf(filename,"Data%03d.csv",ifl); ifl++;
    than can you tell us what the serial monitor is printing
    Nov 2019
    13
    //open file
    Thank you for replying. I've tried your code but it doesn't have any effect. It was saving empty csv files instead and there were a lot of it. When I run your code, I have this warning.
    SaveToSDCard: In function 'void doLogging(uint32_t, int*, int*, int*, int)':
    C:\Users\HP\Documents\Arduino\SaveToSDCard\SaveToSDCard.ino:37:41: warning: format '%d' expects argument of type 'int', but argument 3 has type 'uint32_t {aka long unsigned int}' [-Wformat=]
    The serial monitor is actually printing the values of the sensors this can be seen from the loop void.
       Serial.print(",");
       Serial.print(",");
    I would like to save the values of the sensors to SD card within a range of time that we can change, but still maintain its frequency sampling.
    2,447
    next thing I would try is to move the print to serial adjacent to prints to file move from loop into doLogging
        { file.print(',');
          file.print(',');
          file.print(',');
       Serial.print(",");
       Serial.print(data1[ii]);
       Serial.print(",");
       Serial.print(data3[ii]);
       Serial.print(",");
       Serial.println(data3[ii]);    }
    to see what is exactly coming into subroutine
    2,296
    your logic around the file.open() is flawed. You only would set count = 1 if the open() failed! so count is never set to 1, and all your dologger() does is open the file then close the file. Your flawed logic doesn't write any data to the file.
    2,447
    I completely missed that.
    For me that is the reason, why I never liked '{' at the end of the line. I prefer that in line with '}'.
    10,332
    Keeping code formatted helps - doing it manually of course is suspect to seeing things like that. In the IDE a Ctrl+T will do formatting the their uniform standard.
    That is an easy way to find missing syntax thingies. Very handy as the IDE cascades problems from the syntax error into who knows what.
    Most other IDE's have such things - for Sublimetext I found it and mapped to Ctrl+Alt+F.
    Nov 2019
    13
    Hi, thank you for your reply. I realized that the dologger() function is not right. But I had seen it from a forum, he said that it works for him. I thought it would work for me too. Is there any suggestion on how I should change the code? I'm actually not good with this.
    Nov 2019
    13
        { file.print(',');
          file.print(',');
          file.print(',');
       Serial.print(",");
       Serial.print(",");
       Serial.print(",");
    Nothing happens when I try to comment my serial.print in the loop function and tried the code that you suggested. The serial monitor didn't show anything.
    10,332
      while( !Serial ); // Add this when seeing output is needed  // or to wait 2 seconds // while( !Serial && millis()<2000 );
    2,447
    Quote Originally Posted by AmeliaLita View Post
    Simply use
      if(!count)
         //open file
         if (!file.open(filename, O_RDWR | O_CREAT))  sd.errorHalt("open failed");
         count=1;
    Nov 2019
    13
    Thank you! Your suggestions work! Just a quick question, is there a way to add an id and a column title? I am also wondering if using an SD card to record a data would have a fix frequency sampling?
    2,447
      if(!count)
         //open file
        // write header to file
        file.println("timeStamp,counter,derajat,EMG");
        // flag open file
        count=1;
    And No the sampling rate in not fixed, it is as fast as 'loop() and ADC allow
    If you need precise sampling then you need a more complex program with timed interrupt.
    But I would simply try it out, you have a timestamp, so you can assess the regularity of the ADC
    2,447
    what is your expected data rate?
    The following code may be a start
    #define SDFAT_BETA 0
    #if SDFAT_BETA == 0
      #include <SdFat.h>
    #else
      #include <SdFat-beta.h> // latest SdFat needed for SDIO and (renamed SdFat.h into SdFat-beta.h)
    #define outputA 5
    #define outputB 6
    #define RawEMG A0
    uint32_t t0 = 0;
    int counter = 0;
    int derajat = 0;
    int EMG = 0;
    int aState;
    int aLastState;
    #if SDFAT_BETA == 0
      SdFatSdio sd;
      File file;
    #else
      SdFs sd;
      FsFile file;
    #define SD_CONFIG SdioConfig(FIFO_SDIO)
    #define F_SAMP 500
    #define PIT_PERIOD (F_BUS/F_SAMP)
    uint32_t ADC_ready=0;
    uint32_t ADC_overflow=0;
    void ADC_input(void)
      t0 = millis();
          counter ++;
          counter --;
          counter = 0;
       ADC_ready=1; //flag to loop that we have new data
    void ADC_Trigger_isr(void)
      PIT_TFLG2=1;
      static uint16_t busy;
      digitalWriteFast(13,!digitalReadFast(13));
      if(busy && ADC_ready) { ADC_overflow++; return; }
      busy=1;
      ADC_input();
      busy=0;
    void ADC_Trigger_init(void)
    {  // check with AudioStream if we are responsable for updates
      const int prio=10;
      // assign local function as ISR
      _VectorsRam[IRQ_PIT_CH2 + 16] = ADC_Trigger_isr;
      NVIC_SET_PRIORITY(IRQ_PIT_CH2, prio*16);
      NVIC_ENABLE_IRQ(IRQ_PIT_CH2);
      // turn on PIT clock
      SIM_SCGC6 |= SIM_SCGC6_PIT;
      // turn on PIT
      PIT_MCR = 0x00;
      // Timer 0
      PIT_LDVAL2 = PIT_PERIOD;
      PIT_TCTRL2 = 2; // enable Timer 2 interrupts
      PIT_TCTRL2 |= 1; // start Timer 2
      while(!Serial);
      if (!sd.begin(SD_CONFIG)) {
        sd.initErrorHalt(&Serial);
      pinMode(13,OUTPUT);
      ADC_Trigger_init();
      char filename[32];
      if(!count)
         //open file
         sprintf(filename,"Data%03u.csv",(unsigned int)ifl); ifl++;
         Serial.println(filename);
         // flag open file
         count=1;
      if(count>0)
        // write to file
        { file.print(',');
          file.print(',');
          file.print(',');
        file.println();
        count++;
      if(!count)
      {  Serial.print("Overflow: "); Serial.println(ADC_overflow);
         ADC_overflow=0;
         // close file
         file.close();
      if(ADC_ready)
      { doLogging(t0,&counter, &derajat, &EMG,1); //insert data (?)
        ADC_ready=0;
    Nov 2019
    13
    I have tried your code but there's an error in #define SD_CONFIG SdioConfig(FIFO_SDIO). Is that a library that I need to download? Where can I download it?
    I was expecting a sampling rate that can acquire both sensors values properly without any data missing I hope.
    2,447
    Sorry, that is my fault.
    I'm using the latest (beta) version of SdFat.
    You could change code to become
    #if SDFAT_BETA == 0
      SdFatSdio sd;
      File file;
    #else
      SdFs sd;
      FsFile file;
    and
    #if SDFAT_BETA == 0
      if (!sd.begin()) {
        sd.initErrorHalt();
    #else
    Nov 2019
    13
    #if SDFAT_BETA == 0
      SdFatSdio sd;
      File file;
    #else
      SdFs sd;
      FsFile file;
    and
    #if SDFAT_BETA == 0
      if (!sd.begin()) {
        sd.initErrorHalt();
    #else
    Where should I paste this? I have tried running the first code with the previous code you shared and the error is that FIFO_SDIO was not declared.
    10,332
    Looking at Post #14 code - it looks like nothing gets pasted - but the line
    is removed
    2,447
    lets try again:
    actually post #14 says
    #if SDFAT_BETA == 0
      SdFatSdio sd;
      File file;
    #else
      SdFs sd;
      FsFile file;
    that should become
    #if SDFAT_BETA == 0
      SdFatSdio sd;
      File file;
    #else
      SdFs sd;
      FsFile file;
    you see the difference?
    also later in the code we have in setup()
    this should become
    #if SDFAT_BETA == 0
      if (!sd.begin()) {
        sd.initErrorHalt();
    #else
    Why this changes?
    this allows me to run the code with latest SdFat-beta library and using ExFAT formatted disks, and you with the older SdFat library, by simply changing a number
    use old SdFat library:
    use new SdFat-beta
    #define SDFAT_BETA 1
    clearer now?
    Nov 2019
    13
    Okay, thanks. It's more clearer now and I've changed the code. There is no error when I compiled it but I tried printing the sensor values using the code below.
     if (count > 0)
        // write to file
        for (int ii = 0; ii < nb; ii++)
        { file.print(',');
          file.print(',');
          file.print(',');
          Serial.print(data1[ii]); //counter
          Serial.print(",");
          Serial.print(data2[ii]); //derajat
          Serial.print(",");
          Serial.println(data3[ii]); //EMG
    But there's nothing printed in the serial monitor and when I checked the SD card, there's no file saved there.
    2,447
    which seems to indicate, that opening files fails.
    I'm on travel for a week and have no Teensy with me, so I cannot check the program.
    Nov 2019
    13
    Hi, it's okay. I can wait and while at it, I will find other ways. I think I will try to compare with the previous code that works.
    Nov 2019
    13
    Hi, so I had help from a friend and have found a way to save to the SD car while also having a stable frequency rate. I would like to share it with everyone just in case someone encounter the same problem as I am.
    #include <SoftwareSerial.h>
    #include <SdFat.h>
    //========================================= inisiasi
    #define outputA 5 //untuk encoder
    #define outputB 6
    #define RawEMG A0
    int counter = 0;
    int derajat = 0;
    int EMG;
    int aState;
    int aLastState;
    long timenow = 0 ;
    long timeprev = 0;
    //========================================= variable
    int timesampling = 20;
    int encoderPPR = 2048;                             // real ppr*2
    SdFatSdio sd;
    File file;
      if (!sd.begin()) {
        sd.initErrorHalt();
    void doLogging(uint32_t timeStamp, int *data1, int *data2, int *data3, int nb)
      //================================================= init
      char filename[32];
      if (!count)
        //open file
        sprintf(filename, "Data1207-01-%03d.csv", ifl); ifl++;
        // flag open file
        count = 1;
      if (count > 0)
        // write to file
        { file.print(',');
          file.print(',');
          file.print(',');
          Serial.print(",");
          Serial.print(",");
        file.println();
        count++;
        if (count > MaxCount) count = 0;
      if (!count)
        Serial.println("SAVING DATA................");
        file.close();
      //========================================= read data
      EMG = analogRead (RawEMG);                       //reads EMG sensor
      //========================================= do ... every "timesampling"
      timenow = millis();
      if (timenow - timeprev > timesampling) {
        timeprev = timenow;
    //    Serial.print(counter);
    //    Serial.print(",");
    //    Serial.print(derajat);
    //    Serial.println(EMG);
        doLogging(t0, &counter, &derajat, &EMG, 1);    // Save data
      //========================================= counter encoder to degrees
      if (aState != aLastState) {
        if (digitalRead(outputB) != aState) {
          counter ++;
          counter --;
        if (counter > encoderPPR or counter < -encoderPPR)
          counter = 0;
      derajat = counter * 360 / encoderPPR;
    As you can see, the code tries to limit the looping process so it won't go faster than the time sampling variable.
