Results 1 to 9 of 9
Thread: T4 Data in Flash
    Germany
    718
    T4 Data in Flash
    I'm confused about how to place data in the Flash.
    What I understood so far:
    const char buffer[500*1024] = {0};
       Serial1.println(buffer);
    void loop(){}
    places 500kB in the flash. The startup code tries to copy this to DTCM which will fail because there is not enough space in DTCM. Compiling this code indeed gives a linker error complaining about an overflow. Here the linker output:
    Memory region         Used Size  Region Size  %age Used
           ITCM:        6772 B       512 KB      1.29%
           DTCM:      524992 B       512 KB    100.13%
            RAM:          0 GB       512 KB      0.00%
          FLASH:      525012 B      1984 KB     25.84
    c:/toolchain/gcc/gcc-arm-none-eabi-5_4-2016q3-20160926-win32/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: address 0x200802c0 of .vsteensy/build/TestProject.elf section `.bss' is not within region `DTCM'
    If I add PROGMEM to the buffer definition it should not copy the buffer to the RAM
    PROGMEM const char buffer[500*1024] = {0};
    void loop(){}
    Which it doesn't, according to the linker output:
    [LD]  .vsteensy/build/TestProject.elf
                DTCM:       12992 B       512 KB      2.48%
               FLASH:      525012 B      1984 KB     25.84%
    User code built and linked to libraries
    [HEX] .vsteensy/build/TestProject.hex
    [LST] .vsteensy/build/TestProject.lst
    Sucessfully built project
    So far so good. However, Teensy.exe as well as tyTools complain that the file is too large and don't upload. Any idea what I misunderstood?
    Here a snippet from the Teensy.exe log
    21:36:54.542 (post_compile 24): Sending command: comment: Teensyduino 1.48-beta3 - WINDOWS (teensy_post_compile)
    21:36:54.638 (loader): File "sketch_sep07a.ino.hex". 525012 bytes, 200% used
    21:36:54.638 (loader): File contains data beyond chip size, yikes!
    21:36:54.653 (loader): remote cmd from 3772: "dir:C:\Users\lutz\AppData\Local\Temp\arduino_build_879626\"
    21:36:54.653 (loader): remote cmd from 3772: "file:sketch_sep07a.ino.hex"
    10,588
    Was that to upload to a T_4 and not a 3.6 or 3.5 ?
    Give a bit more console output ...
    SEE FOLLOWING POST
    Last code compiled for me - but did FAIL upload as follows with TyCommander:
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-size" -A "T:\\TEMP\\arduino_build_891711/forum.ino.elf"
    Sketch uses 525664 bytes (25%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 24512 bytes (2%) of dynamic memory, leaving 1024064 bytes for local variables. Maximum is 1048576 bytes.
    T:\TyComm\TyCommanderC.exe upload --autostart --wait --multi T:\TEMP\arduino_build_891711/forum.ino.TEENSY40.hex
    Waiting for user selection
    Firmware 'T:\TEMP\arduino_build_891711\forum.ino.TEENSY40.hex' has too many segments
    An error occurred while uploading the sketch
    From Teensy.exe I get this 'VERBOSE' - with no upload:
    13:41:04.767 (ports 1): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    13:41:04.768 (ports 1): remove: loc=usb:0/140000/0/4/6
    13:41:04.768 (ports 1): usb_remove: usb:0/140000/0/4/6
    13:41:04.768 (ports 1): nothing new, skipping HID & Ports enum
    13:41:04.839 (ports 1): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:41:04.840 (ports 1): nothing new, skipping HID & Ports enum
    13:41:04.841 (loader): Device went offline
    13:41:05.089 (loader): HID/win32:  vid:1B80 pid:B406 ver:0100
    13:41:05.089 (loader): HID/win32:  vid:046D pid:C534 ver:2901
    13:41:05.099 (loader): HID/win32:  vid:1B80 pid:B406 ver:0100
    13:41:05.099 (loader): HID/win32:  vid:0764 pid:0501 ver:0001
    13:41:05.129 (ports 1): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    13:41:05.131 (ports 1): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0008fc81#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:41:05.131 (ports 1): found_usb_device, loc=usb:0/140000/0/4/6    Port_#0006.Hub_#0004
    13:41:05.131 (ports 1): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0105
    13:41:05.131 (ports 1): found_usb_device, devinst=0000001d
    13:41:05.131 (ports 1): add: loc=usb:0/140000/0/4/6, class=HID, vid=16C0, pid=0478, ver=0105, serial=0008fc81, dev=\\?\usb#vid_16c0&pid_0478#0008fc81#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    13:41:05.131 (ports 1): hiddev_from_devinst_list: iface=0
    13:41:05.132 (ports 1): found_usb_device complete
    13:41:05.133 (ports 1): usb_add: usb:0/140000/0/4/6  [no_device] (Teensy 4.0) Bootloader
    13:41:05.161 (ports 1): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:41:05.162 (ports 1): hid, found devinst=0000001E
    13:41:05.162 (ports 1): hid, path=\\?\hid#vid_16c0&pid_0478#7&206ffd9d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:41:05.162 (ports 1): hid,  opened handle
    13:41:05.162 (ports 1):  devinst=0000001E, location=usb:0/140000/0/4/6
    13:41:05.162 (ports 1):  vid=16C0, pid=0478, ver=0105, usepage=FF9C, use=0024
    13:41:05.162 (ports 1):  devpath=\\?\hid#vid_16c0&pid_0478#7&206ffd9d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    13:41:05.162 (ports 1): usb_add: usb:0/140000/0/4/6  hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
    13:41:05.217 (ports 1): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    13:41:05.218 (ports 1): nothing new, skipping HID & Ports enum
    13:41:05.339 (loader): Device came online, code_size = 2031616
    13:41:05.339 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.05
    13:41:05.339 (loader): ihex: parse error line 1
    13:41:05.350 (loader): set background IMG_ONLINE
    13:41:05.598 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
    EDIT > Teensy will upload and this is the full verbose:
    But it doesn't seem to RUN as I see no print?
      while(!Serial);
    void loop(){}
    10,588
    I got it to upload with TyCommander
    When code changed to this:
      while(!Serial);
       Serial.println(micros());
    void loop(){}
    Linking everything together...
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TT:\\arduino-1.8.9t4\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "T:\\TEMP\\arduino_build_891711/forum.ino.elf" "T:\\TEMP\\arduino_build_891711\\sketch\\forum.ino .cpp.o" "T:\\TEMP\\arduino_build_891711/..\\arduino_cache_331422\\core\\core_2d2ac97583686 748de40bdc1fd01841a.a" "-LT:\\TEMP\\arduino_build_891711" -larm_cortexM7lfsp_math -lm -lstdc++
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "T:\\TEMP\\arduino_build_891711/forum.ino.elf" "T:\\TEMP\\arduino_build_891711/forum.ino.eep"
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "T:\\TEMP\\arduino_build_891711/forum.ino.elf" "T:\\TEMP\\arduino_build_891711/forum.ino.hex"
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "T:\\TEMP\\arduino_build_891711/forum.ino.elf" "T:\\TEMP\\arduino_build_891711/forum.ino.TEENSY40.hex"
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/stdout_redirect" "T:\\TEMP\\arduino_build_891711/forum.ino.lst" "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "T:\\TEMP\\arduino_build_891711/forum.ino.elf"
    "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/stdout_redirect" "T:\\TEMP\\arduino_build_891711/forum.ino.sym" "T:\\arduino-1.8.9t4\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "T:\\TEMP\\arduino_build_891711/forum.ino.elf"
    Sketch uses 13440 bytes (0%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 24464 bytes (2%) of dynamic memory, leaving 1024112 bytes for local variables. Maximum is 1048576 bytes.
    upload@5889290-Teensy Uploading to board '5889290-Teensy' (Teensy 4.0)
    upload@5889290-Teensy Triggering board reboot
    upload@5889290-Teensy Firmware: forum.ino.TEENSY40.hex
    upload@5889290-Teensy Flash usage: 14 kiB (0.9%)
    upload@5889290-Teensy Uploading...
    upload@5889290-Teensy Sending reset command
    Germany
    718
      while(!Serial);
    void loop(){}
    Yes, because you don't use the array the compiler optimized it completely away...
    Here the linker output for your changed code:
                ITCM:        6708 B       512 KB      1.28%
                DTCM:       12960 B       512 KB      2.47%
               FLASH:       12948 B      1984 KB      0.64%
    6,091
    For what it is worth, this built and run on T4...
      while(!Serial && millis() < 5000);
      uint32_t sum = 0;
      for (uint32_t buffer_index = 0; buffer_index < sizeof(buffer); buffer_index++) {
        sum += buffer[buffer_index];
       Serial.printf("size:%u, sum: %u\n", (uint32_t)sizeof(buffer), sum);
    void loop(){}
    Output:
    size:512000, sum: 0
    Build info, my extended version:
    FlexRAM section ITCM+DTCM = 512 KB
        Config : aaaaaaab
        ITCM :  22880 B	(69.82% of   32 KB)
        DTCM :  12992 B	( 2.64% of  480 KB)
        Available for Stack: 478528
    OCRAM: 512KB
        DMAMEM:   8272 B	( 1.58% of  512 KB)
        Available for Heap: 516016 B	(98.42% of  512 KB)
    Flash: 544272 B	(26.79% of 1984 KB)
    10,588
    I just got the latest github.com/KurtE/imxrt-size - will need to get that back into my build so I can see such things.
    Good follow up KurtE … was in a rush to get back on task and have lunch ready
    Indeed it did initially FAIL - and got odd result from Teensy.exe - quickly extended it dropping the buffer and reposted without looking.
    Germany
    718
    @Kurt, tried your sketch, it kind of uploads when uploaded from the IDE (you see the process in the verbose log) but it then breaks (timeout?) and never reboots.
    Loading the same hex file directly with Teensy.exe immediately fails.
    01:14:14.734 (loader): Open File event
    01:14:16.385 (loader): File "sketch_sep07a.ino.hex". 543788 bytes, 207% used
    01:14:16.385 (loader): File contains data beyond chip size, yikes!
    I can't help it it looks like there is something not working correctly if the flash size gets larger than the 512kB.
    Germany
    718
    Ok, I know whats wrong: I had a old version of Teensy.exe. Updated to the current version now everything works as it should.
    Sorry for the noise....
    10,588
    Something seemed off for first post #2 comment :: Was that to upload to a T_4 and not a 3.6 or 3.5 ?
    Still odd that I got odd behavior from TyComm - not having any Valid print made it unsure when the code loaded to run too:
      while(!Serial);
