mjs513
Senior Member+
Recently have been getting back into robotics and started playing again with using LIDAR for obstacle avoidance and 3d Room Scanning. Experimented with using the Neato XV-11 and LidarLite v4LED but finally settled on using the LidarLite v3 (see Sparkfun product page: https://www.sparkfun.com/products/14032).
Doing a bit of googling found a project that exactly suited my needs that was done using the v3 and an Arduino, Arduino Based Lidar Scanner. Even came with a Processing sketch to display a PointCloud. So with a bit of modification to suit my needs was able to get it working on a T4. Not much really needed:
On the hardware side used an level shifter for two HS-645MG servos on the pan/tilt platform from ServoCity. For a power supply used a Anker power pak suppling 5v to the servos and the Lidar Lite v3. Here a couple of screen shots from the Processing sketch:
with a couple color schemes.
Next was to hack up a version of the initial sketch as a standalone project to use either a RA8875, ILI9488 or a ILI9341. For this test I am using a RA8875 display using a updated RA8875 library that supports the T4: https://github.com/mjs513/RA8875. You can check out this discussion on its development: https://forum.pjrc.com/threads/57280-RA8875-from-Buydisplay?highlight=RA8875. Also incorporated the ArduinoGL_t3 library at this point that supports basic OpenGL v1 features like rotation, scaling, and translating to try and mirror some of the commands in the Processing sketch.
Here is a photo of the setup for that piece of the project:
An initial screen shot of the scan on my desk is shown below:
Still working on improving the whole thing.
An initial commit for the project is on GitHub but with out much instructions yet though: https://github.com/mjs513/Lidar-Lite-v3-3d-Scanner
More to come soon.
EDIT:
Forgot to add.
For the ILI9488 you will need the ILI9488_t3 library: https://github.com/mjs513/ILI9488_t3
For the ILI9341 you will need the ILI431_t3n library: https://github.com/KurtE/ILI9341_t3n/ and the SPIN Library: https://github.com/KurtE/SPIN.
- Added Distance measurement to send to the Processing Sketch
- Modified the Processing to display points in various colors for points based on distance from the sensor
- Added about to save point cloud and read it back in to processing with out having to rescan.
- Deleted the output to LCD display and manual mode control in the Arduino sketch.
More to come soon.
EDIT:
Forgot to add.
