Page 2 of 2 FirstFirst 1 2
Results 26 to 45 of 45
Thread: ILI9341 CAN Display - Gauge rendering on display
  1. #26
    Finland
    183
    Quote Originally Posted by Rezo View Post
    I will have to sample the data twice in each loop, correct?
    No, just once (gauge_value).
    Think of gauge_shown as the needle in the gauge, dragged around by the sampled gauge_value , but limited to a maximum rate of change.
    If the sampled value jitters, and you want to smooth that out, you'll need to instead implement a smoothing filter.
    The two most commonly used filtering schemes for this sort of stuff are exponential and windowed.
    Exponential is the simplest, but may take some experimentation to find the optimum coefficient. The code itself is trivial:
    #define  GAUGE_COEFFICIENT  0.75  /* between 0.5 and 1 */
    gauge_shown = GAUGE_COEFFICIENT * gauge_value + (1.0f - GAUGE_COEFFICIENT) * gauge_shown;
    This is called exponential (often exponential smoothing) because the shown value is essentially a mix of samples thus far, with exponentially decaying weights.
    The optimum GAUGE_COEFFICIENT depends on the amount of jitter, and how rapidly the shown gauge should react to large changes. The smaller, the smoother; the closer to one, the faster it reacts.
    Windowed filtering involves keeping a short queue of sampled values, always replacing the oldest one with the new sample, and showing their average:
    #define  GAUGE_SAMPLES  20
    float  gauge_sample[GAUGE_SAMPLES];
    unsigned int  gauge_sample_index = 0;
    int i;
    /* Add a new sample */
    gauge_sample[gauge_sample_index++] = gauge_value;
    if (gauge_sample_index >= GAUGE_SAMPLES)
    /* Calculate average */
    gauge_shown = 0.0f;
    for (i = 0; i < GAUGE_SAMPLES; i++)
        gauge_shown += gauge_sample[i];
    gauge_shown /= GAUGE_SAMPLES;
    The optimum window size (GAUGE_SAMPLES) depends on the jitter in gauge_value samples.
    The window size also determines the amount of latency (delay in registering a change) the shown gauge has.
    For example, if the samples are first all zeroes, and then suddenly change to one, it takes GAUGE_SAMPLES updates before the shown gauge gets to one. It will rise there linearly.
    Sometimes the window is also weighted, but I would guess that in this kind of application the exponential filter will work better (than a weighted windowing filter).
  2. #27
    Finland
    183
    Perhaps this illustration of 100 samples (a sine wave plus noise) gives you some idea:
    The same data, but with different coefficient and window size:
  3. #28
    Great info!. A lot of cloth to cut!.
    This is my approach to smoothing readings. The key is the data acquisition interval; I think that 1 second is more than acceptable to have real-time information from any of the sensors that you want to monitor.
    float Lect, Lect1, Lect2, DeltaL, VelL, LectA;
    long previousMillis=0, updateMillis=1000;
    void Sensor1()
      unsigned long currentMillis = millis();
      if(currentMillis - previousMillis > updateMillis)
        previousMillis = currentMillis;
        Lect=random(0,100);
        Lect2= Lect;
        DeltaL=Lect2-Lect1;
        if(DeltaL>0){VelL=1;}else{if(DeltaL<0){VelL=-1;}else{VelL=0;}}
       if(LectA==Lect2){LectA=Lect2;}else{LectA = LectA + VelL;}
       GD.cmd_gauge(50, 180, 40, 0, 4, 7, LectA, 100);
       GD.cmd_gauge(GD.w-50, 180, 40, 0, 4, 7, Lect, 100);
       Lect1= LectA;
  4. #29
    So, I never got around to testing this - just haven't had time, and I've also been working on getting the 2nd gauge to display as I want. As well as other things in parallel.
    I went with a very simple approach that seems to have really smoothed out the reading, especially on the gauge..
    In my loop, after sampling the data, I do an average of the last reading and the current reading like so:
    boost_pressure = canData [0]; // Data from the CAN Bus
    boost_pressure = (boost_pressure + lastBoostPressure) / 2; // merge and average current value with last value
    lastBoostPressure = boost_pressure; // Save the current value to use in the next calculation
    And here you can see the smoother response on the gauge in this video
    Alternatively, I could also do this:
    lastBoostPressure = canData [0]; // Save the current live value to use in the next calculation
    Which would be more accurate?
  5. #30
    Apr 2017
    230
    I need to update my gage library--yours look like a million times better that mine!
  6. #31
    Quote Originally Posted by KrisKasprzak View Post
    Please do share what you have built! Happy to provide the graphics code if you’d like. But just note that its a work in progress and I am no expert. I learn more C++ with every new challenge I tackle on this project.
  7. #32
    Finland
    183
    First one is exponential filtering with coefficient 0.5, the second is windowed filter with 2 sample window. They are equally valid.
    How to define "accuracy"? The main purpose is to smooth out noise, so the needle doesn't jitter like a ferret on crack.
    (You should use (boost_pressue+lastBoostPressure+1)/2 in both cases to get correct rounding, though, since the values are unsigned integers.)
    A step change takes seven updates with the exponential filtering. With the two-sample window, two updates. The final result is the same, so both are equally accurate; they just smooth the jitter differently.
    Love the gauges, by the way. I might have made the right-side one with two black lines surrounding a green/yellow/red block or line instead of the light circle on white, for better visibility, but the left-side one is just about perfect in my opinion!
  8. #33
    Quote Originally Posted by Nominal Animal View Post
    I shall try that later on today
    EDIT: actually, both variables are floats, so I don't think I'll need to add +1 for the corrections.
    Thank you! And I've already started working on what you mentioned earlier this week. I hate that white background - so it's going to be filled black with a white outline - will be much easier to read.
    I'm really impressed with how well this whole thing works. It runs just as well with the T4 set to at lower clock speed (<400Mhz) as the main bottle neck is the SPI bus speed (20Mhz) and the sample rate from the CAN network (every 12ms) - but still providing great performance
  9. #34
    Dec 2016
    Montreal, Canada
    3,336
    Rezo, the CAN library is using a public circular buffer which includes variance, deviation and mean(average) built in. Since it's already included in your code you don't need to add function code to do the same work
    Only one constructor for a circular queue
    Only one call to queue a value (oldest item removed)
    Only one call to retrieve the variance/deviation/mean result
    CAN is using circular arrays, but circular buffers exist within same library
  10. #35
    Hey Tony, is there and documentation on this? Sounds really interesting!
  11. #36
    Dec 2016
    Montreal, Canada
    3,336
  12. #37
    So it would look like this more or less?
    Obviously it will take 4 initial pushes to fill the buffer and get a proper average
    Circular_Buffer<float, 4> boostPressure;
    float canData [3]; // placing 3 different PID data types but only using 1st in this case
    float boostAvrg;
    void loop(){
    boostPressure.push_front(canData [0]);
    boostAvrg = (boostPressure.mean(), 4);  // or just boostPressure.mean(); ?
  13. #38
    Dec 2016
    Montreal, Canada
    3,336
    Just mean(). A float value would be returned and boostAvrg would be set with it
    Normally we push_back, or write(val), push_front was made for a priority queue system but it'll still work pushing things in queue from opposite end
    If you share the queue within interrupts and loop(), it's recommended to write in back and read from front
  14. #39
    Alright, so I implemented it. Works well with the constructor setting the circle at 2,4,8 (didn't try anything higher). 1,5,6,7 messed up the readings.
    TBH the responsiveness looks almost the same as my previous implementation, but I might reuse the circular buffer to smooth out some other reading as well, perhaps the 2nd gauge too.
  15. #40
    Dec 2016
    Montreal, Canada
    3,336
    Yeah the buffer must be a power of 2: 1, 2, 4, 8, 16, 32, etc or undefined behaviour would result and responses would be wrong
  16. #41
    Finland
    183
    Correct.
    (You could replace the division by a power of two (2, 4, 8, 16) by a multiplication with the exact reciprocal (0.5f, 0.25f, 0.125f, 0.0625f). I've actually expanded on this in this answer I wrote at StackOverflow, which shows how to check how correct the Markstein approach -- replacing the division by a constant with two multiply-adds, as multiplication of floating-point values is much faster than division -- if you happen to need the efficiency. You do not, as you have ample computing power to even reduce the system clock, so better keep the code easily maintained and understandable instead.)
    Even better than my suggestion!
    Note that the circular buffer implementation is really trivial. For example:
    #define  BOOST_SAMPLES  5  // Minimum is 1
    static float  boost_sample[BOOST_SAMPLES];
    static unsigned int  boost_sample_index;
    // Call this to initialize or reset the boost sample buffer to a fixed value it starts from.
    void boost_init(float value)
        for (int i = 0; i < BOOST_SAMPLES; i++) {
            boost_sample[i] = value;
        boost_sample_index = 0;
    float boost_update(float sample)
        float  average = sample;
        // Increment and wraparound the sample index.
        boost_sample_index = (boost_sample_index + 1) % BOOST_SAMPLES;
        // Trick: we use one extra sample by doing the average (sum) now.
            avg += boost_sample[i];
        // Note: avg = sample plus sum of BOOST_SAMPLES in boost_sample[]
        // Update sample buffer.
        boost_sample[boost_sample_index] = sample;
        // Return average.
        return avg / (BOOST_SAMPLES + 1.0f);
    Then, in your code, you just call boost_init(0.0f) in setup(), then in loop(), boost_pressure=boost_update(can[0]); and you have the BOOST_SAMPLES+1 -averaged boost pressure value. Just change the macro definition on the first line to see which sample count works best.
    If you were tight on processing power, we could do something about the division and the modulo, but since they are only done when the display is updated, they really are utterly, completely neglible.
    All this said, I still cannot say whether I like the exponential or the window filter approach better!
    The best description for their difference that I can think of, is that the exponential reacts faster to large changes, but takes longer to arrive at the steady-state value, as it slows its approach as it comes closer; whereas windowed takes a linear path to the target value. If you want large changes to be visible faster, but filter out smaller noise, use exponential; just find the proper coefficient for your use case. The windowed gives a much more calm, stately progression to different values; its behaviour is completely dependable and unsurprising, trust-inspiring. Both are correct; it's just that they take a different path to the steady state. Exponential is like a revving engine, whereas windowed is the dependable, well-behaved one. It really depends which feel you want your gauge to have!
  17. #42
    I think there might be an even quicker way to maintain a running average that *should* be the same as:
        // Return average.
    Instead of polling every element of BOOST_SAMPLES each time the average is updated (with that 'for' loop), you can update it by simply using the newest and oldest BOOST_SAMPLES entries. The benefit here might be negligible on powerful processors, but it means the performance shouldn't change with the size of the data array... maybe helpful if you wanted a very slow moving average (i.e. large array), like if you have a noisy sensor on a stable system (like your coolant temp). I've also included a similar strategy for building the initial array.
    #define  BOOST_SAMPLES  5  // Minimum is 2
    static unsigned int  boost_sample_index = 0;
    float average = 0.0f;
    int n = 0; //used for initial filling of the data array, indicates number of elements in array (actually one less...)
    void boost_init(float value) {   //keeps accurate initial average for first few samples
        boost_sample_index = n;
        boost_sample[n] = value;
        average += (value - average) / (n + 1);
        n++;
    float boost_update(float value) {   //discards oldest sample from average and updates with newest
        boost_sample_index = (boost_sample_index + 1) % BOOST_SAMPLES;   //go to oldest index
        average += (value - boost_sample[boost_sample_index]) / (BOOST_SAMPLES);   //i.e. avg_new = avg_old + (newest_sample - oldest_sample) / BOOST_SAMPLES
        boost_sample[boost_sample_index] = value; //set oldest index to newest value
        if(n < BOOST_SAMPLES) {   //only run for first BOOST_SAMPLES iterations
            boost_init(can[0]);
        else {   //after BOOST_SAMPLES iterations, use update function instead
        updateDisplay(average);
  18. #43
    Senior Member JarkkoL's Avatar
    Jul 2013
    116
    @mikey.antonakakis It's all good, but you shouldn't use floats or you'll end up having float rounding issues. i.e. over time the average will drift away from the real average of the values. Convert to use fixed point instead and just maintain sum of the values, and divide by the total number of samples when querying the average.
  19. #44
    Quote Originally Posted by JarkkoL View Post
    Good advice, thanks!
  20. #45
    With recent events of the COVID-19 virus, I've been working from home for the past week.
    I found some spare time to continue working on this project in between.
    I want to thank anyone and everyone that has assisted me with code and guidance so far - I know I can be a bug at times but I just love this stuff and the people here!
    This is what the current UI layout looks like so far:
    All readings in red are peaks, white is realtime.
    Readings with a decimal point are aligned to the decimal point., those that are integers are aligned to the right (lots of if else statements to change curser position).
    Screen updates take roughly 20ms in the loop and it responds quite well for live data - this is thanks to the optimised HXD8357D_t3n library using a frame buffer and clipping areas to update portions of the screen.
    Parts:
    T4.0 @ 450mhz
    Adafruit HXD8357D 3.5" display (480x320)
    Waveshare SN65HVD230 CAN transceiver @ 500kbps.
    Next step is design a PCB to mount the T4, SN65HVD230 and a DC-DC power supply behind the display to keep the assembly as slim as possible. Will probably do this via OSHPark when I find some spare time, as well as 3D print a small case.
    I still want to enhance my CAN code, as I am currently requesting each data set individually, but I can do up to 6 at the time, which should increase data refresh rate by quite a bit.
    Overall this is an ongoing learning experience for me, and an enjoyable one too!
