Results 1 to 8 of 8
Thread: flip flop out put is quiet slow
    I need to generate a +- 22MHZ pulse
    and strangely enough digitalWrite functions are extremely slow compared to the teensy 3.6 working frequency (240Mhz)
    #define MCLK 9
    byte pulse=0;
      pinMode(MCLK,OUTPUT);
      digitalWrite(MCLK,pulse); pulse=1-pulse;
    with this code I can only achieve around 600khz
    I know I can do pwm, but out of curiosity, why is it so slow ???
    thanks
    Dec 2013
    259
    Try digitalWriteFast.
    There is of course other caveats such as loop() overhead and pin slew rate limiting, which is on by default on teensy 3.x.
    Dec 2013
    259
    From LINK: STRANGE GPIO speed perfomance with digitalWriteFast() (ring oscillator example)
      pinMode(9, OUTPUT);
      CORE_PIN9_CONFIG = PORT_PCR_MUX(1); // no slew rate limit
      noInterrupts();  // look pretty for the oscilloscope trigger
      while (1) {
        digitalWriteFast(9, HIGH);
        digitalWriteFast(9, LOW);
    thx I'll give it a try
    apparently digitalWriteFast does not output anything , I get a flat line until I replace it by the usual usual digitalWrite
    I tried with pwm, I barely reach 10Mhz and the signal is more a sine than a CLK signal
    #define MCLK 9
      analogWriteFrequency(MCLK, 10000000);
      analogWrite(MCLK, 128);
    5,994
    Works for me...
    I modified your code slightly as to remove the overhead of calling main:
    #define MCLK 9
    byte pulse = 0;
      pinMode(MCLK, OUTPUT);
      while (1) {
        digitalWriteFast(MCLK, pulse); pulse = 1 - pulse;
    I could manage to have 20Mhz !! but the signal barely comes back to zero even with a pull down
      analogWriteResolution(2);
      analogWriteFrequency(MCLK, 20000000 );
      analogWrite(MCLK, 2);
    yes I tried your code, it works ... now the signal is really gross (no matter the code)
    I actually try to have a CS5343 working (as master, at first) becos so far when the teensy is the master, the chip does not answer at all
    and looking at the clock, no wonder why (I'll try with a digital analyser as you did)
