Page 12 of 14 FirstFirst ... 2 10 11 12 13 14 LastLast
Results 276 to 300 of 326
Thread: RA8876LiteTeensy For Teensy T36 and T40
  1. #276
    New York
    5,597
    @KurtE
    I just ran FontTest4 and something strange going on with screen rotation as well as GFX fonts not working with the existing library. Don't know if its me and messed something up or not. Can you give it a try when you get a chance and let me know if you are having problems.
    I did re-run the screen rotate sketch and that seemed to work without an issue.
  2. #277
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    294
    Good question. I only have an ER-TFT074. I was hoping somebody here could give it a shot.
    I'll change the graphics.ino back to defaulting to the original display. I'll also add a separate ER-TFT074 example.
  3. #278
    New York
    5,597
    Quote Originally Posted by blackketter View Post
    I did test the graphics.ino sketch from you updated library and while it works it looks like when it goes into Rotation 2 it clipping the text in the status bar. It looks like the screen in that rotation is being shifted down and to the left (using the new orientation). Thats how I noticed the issue with the FontTest4
  4. #279
    May 2015
    San Francisco
    294
    Thanks Which display did you see this behavior on? How is it different than before? (A pic might be helpful to me...)
  5. #280
    7,649
    @KurtE
    Yes it looks like some stuff is busted! Like you mention GFX Fonts are not working.
    I am pretty sure it has to do with GFX font file format changing... LadyAda mentioned that it could be undone as the person who did it was trying to get the stuff to work for extended fonts or the like and then went a different way. But I think I fixed it for some drivers... Need to look again, what I did and where.
    Then once screwed up, some of the rotation look bad as well.
  6. #281
    7,649
    EDIT: Found where I fixed in ST7735...
     // Lets see about supporting Adafruit fonts as well?
    #if __has_include(<gfxfont.h>)
      #include <gfxfont.h>
    Will see about it in this library.
    EDIT: So far NOT need to dig deeper!
  7. #282
    New York
    5,597
    Ok you lost me - that fix? is in the RA8876 library? Needed - not needed? Change?
  8. #283
    New York
    5,597
    Using the 7in RA8876 display (1024x600) from BuyDisplay.
    This is with the existing library:
    and this is what i am seeing with your mods:
    See the clipping at the bottom of the display?
  9. #284
    7,649
    Yep it was there... And I was pulling out my last few strands of hair. I then resorted to adding a #warning in the adafruit gfxfont.h file that said I was included...
    And the definitions were not included ... SO I searched my libraries folder and thought maybe another older file was included... There was one... But it was not included.
    (Getting more bald )
    Then finally did search in my libraries folder (sublime text global search:
    Searching 10447 files for "#define _GFXFONT_H_" (regex)
    C:\Users\kurte\Documents\Arduino\libraries\Ra8876LiteTeensy\src\RA8876Registers.h:
      849  // Lets see about supporting Adafruit fonts as well?
      850  #ifndef _GFXFONT_H_
      851: #define _GFXFONT_H_
      852  /// Font data stored PER GLYPH
      853  typedef struct {
    And found that we also had the gfxfont defined in this header file which is one of the first things included by RA8875_t3.h...
    So we were using the old format out of that file and as the define _GFXFONT_H_
    was defined, our include of the font file did nothing. ...
    So I removed the font definition out of this file and that part of the code was much happier.
  10. #285
    New York
    5,597
    @KurtE
    Yep = Saw that but it didn't register as usual. Also downloaded the changes and it works with the single rotation. Now to work on the other rotations Which i could have sworn we had working.
  11. #286
    7,649
    Me too... I know that at least at one point they were working.
    WIll take another quick look. My guess is one of our internal variables is not properly.
  12. #287
    New York
    5,597
    Yep = my guess too. Looking at it now but cant spot it that quickly
  13. #288
    7,649
    @mjs513 and ...
    Ok,
    My fix in PR #6 appears to fix the GFX problem.
    Rotation: works and does not work.
    That is if you run the rotation test (RA8876Rotate) it appears to be working.
    If you run the released ILI_Ada_FontTest4 it goes bonkers (I think that is the technical name for it )
    However if you comment out the line in the list:
    const ili_fonts_test_t font_test_list[] = {
    //  {nullptr, nullptr,  "Internal Font", RED, YELLOW},
      {&Arial_14, nullptr,  "Arial_14", WHITE, WHITE},
    i.e. don't use the system font.
    Then it appears to work.
    At least for me.
    So for now I will punt
  14. #289
    New York
    5,597
    @KurtE
    Went all through the code and couldn’t find it either. Was going to start commenting things out in the sketch in the morning. Was too hot and tired this evening. Your find does give me an idea on something to check in the morning though. If still can’t find it going to punt as well since not planning on using system fonts either.
  15. #290
    New York
    5,597
    @KurtE and others
    Going through the code again for "Internal Font" remembered something very critical - we can't rotate internal fonts - they are not set up as graphic fonts. Does this make sense.
  16. #291
    7,649
    @mjs513 - Totally! Which is why I punted Was thinking about
    a) having our test program not use this font in any other rotation than 0 and see if it still works.
    b)If not, is there something we need to do when we switch to a new rotation that if the system font was used to reset something....
    Or tell people don't do that!
  17. #292
    New York
    5,597
    @KurtE - Think we should just tell people if they want to do rotations just don't use internal fonts. We could put a test in the lib but then things may start getting confusing when we switch fonts automatically to the user. Think a warning would be better and modify the example. Thoughts?
  18. #293
    New York
    5,597
    @KurtE
    Ok. Played with the example sketch and fixed Internal Font to just for only rotation 0 and it works no problem. I changed the one line where it defaults to setFontDef to:
        else if(tft.getRotation() == 0 && font_test_list[font_index].font_name == "Internal Font") tft.setFontDef();
        else {
          tft.setFont(Chancery_24_Italic);
          tft.setTextColor(GREEN);
  19. #294
    7,649
    @mjs513 - I hacked mine slightly different, not sure which way is better.
      Serial.printf("\nRotation: %d\n", test_screen_rotation);
      tft.setRotation(test_screen_rotation);
      tft.fillScreen(RED);
      tft.setCursor(tft.width() / 2, tft.height() / 2, true);
      tft.printf("Rotation: %d", test_screen_rotation);
      test_screen_rotation = (test_screen_rotation + 1) & 0x3;
      tft.setCursor(200, 300);
      Serial.printf("  Set cursor(200, 300), retrieved(%d %d)",
                    tft.getCursorX(), tft.getCursorY());
      tft.setCursor(50, 50);
      tft.write('0');
      tft.setCursor(tft.width() - 50, 50);
      tft.write('1');
      tft.setCursor(50, tft.height() - 50);
      tft.write('2');
      tft.setCursor(tft.width() - 50, tft.height() - 50);
      tft.write('3');
      nextPage();
      for (uint8_t font_index = 0; font_index < (sizeof(font_test_list) / sizeof(font_test_list[0])); font_index++) {
        if (font_test_list[font_index].font_fg_color != font_test_list[font_index].font_bg_color)
          tft.setTextColor(font_test_list[font_index].font_fg_color, font_test_list[font_index].font_bg_color);
          tft.setTextColor(font_test_list[font_index].font_fg_color);
        if (font_test_list[font_index].ili_font) tft.setFont(*font_test_list[font_index].ili_font);
        else if (font_test_list[font_index].gfx_font)  tft.setFont(font_test_list[font_index].gfx_font);
        else if (test_screen_rotation != 1) continue;  // only on Page 0
        else  tft.setFontDef();
        tft.println(font_test_list[font_index].font_name);
        displayStuff1();
        nextPage();
    I started off changing the code that if we were not setting ILI or GFX and we were not rotation 0 (checked for 1 as we already incremented) than do a continue to bypass the rest... But this ended up with a blank page so then had to move around where I did the nextPage calls...
  20. #295
    7,649
    @mjs513 and ...
    I pushed up a version to my branch with the PR that is sort of a combination between our two fixes.
    That is I do what you did and display something, I use the font you mentioned, but instead of drawing the text page, I draw centered text telling user that the system font is only usable in rotation 0...
      tft.write('0');
      tft.write('1');
      tft.write('2');
      tft.write('3');
        nextPage();
        else if (test_screen_rotation != 1) {
          tft.setCursor(CENTER, CENTER);
          tft.println("*** Only works in Rotation 0 ***");
        displayStuff1();
      nextPage();
    See what you think
  21. #296
    Aug 2017
    309
    @kurtE, @mjs513, @blakketter - I did the pull requests. I have not had the time to test yet. I have to back up the original library locally because of the the issues with the scroll function that I fixed and a couple of other issues that I cannot remember now. Then I can download and test the PR's. Running "ILI_GFX_FontTest.ino" did not work to completion with Ardunio 8.13 and TD 1.53. It worked with Arduino 8.12 and TD 1.52 to completion. This was before the latest PR's. Things at this point are not working well but will will test withe latest PR's.
  22. #297
    New York
    5,597
    @mjs513 and ...
    ...See what you think
    Sorry didn't get back to you yesterday was kind of out of - think the heat got to me. Any will give it a try but from what I can see not a issue. Glad you did the PR.
    @wwatson - going to go through the other examples today as well. To be honest that LI_GFX_FontTest.ino sketch should probably be deleted it was an original debug test sketch.
  23. #298
    New York
    5,597
    @wwatson - @KurtE - @blakketter
    @wwatson = looks like you incorporated @blakketter PR after @KurtE's PR. Since some of the GFX font fixes were not captured correctly.
    @blakketter = @wwatson = was testing the new changes with PipTest and Scroll and there are problems. With scroll for instance, everytime it scrolls it looses a line of text and disappears completely for awhile then repeats and no status bar shows. With PipTest it doesn't seem to understand Screen_1 etc anymore so does not run. Can't really debug the issues since i dont have one of the landscape displays so for me going to revert to using the current version I have without the @blakketter changes.
  24. #299
    Aug 2017
    309
    I done a bad thing again didn't I? Can I revert back to my original library through GitHub or do I need to upload my working version of it and then go from there?
    Sorry for any inconvenience I probably caused
  25. #300
    Aug 2017
    309
    Decided to upload my working version. Please let me know if things are working correctly. Then I will do pull requests. Everything you guys have done is working on my display with all examples. No lockups or problems😀
